    20 ruby's you can't live without
    22 Posts 19 Posters 5.9k Views 19 Watching
    • jujuJ
      juju
      @jcdb said:
      @solo said:
      There are so many great ruby's available, however there are a few I use daily and others that I use specifically. I will say that 'Purge all' is my most used ruby for my day to day works and 'subsmooth', 'JPP', 'Surface tools' and 'FFD' used for all my freeform work (organics)
      FFD ❓
      which one is that?
      Free Form Deform.
        JuanV.Soler
        bit tricky
        • ibonI
          ibon
          I use very much 45ºShadows plugin for elevations, it's very fast and you don't have to move shadows and sun for each view 😉
          • EdsonE
            Edson
            @jcdb said:
            FFD ❓
            which one is that?
            SketchyFFD
            http://www.mahfuz.arq.br
            • boofredlayB
              boofredlay
              In no particular order, here are the ones I am grateful for.
              1. Mirror
              2. Purge
              3. Remove Materials
              4. Pipe along path
              5. Podium
              6. Subdivide & Smooth
              7. Sketchy Free Form Deformation
              8. STP Copy
              9. Weld
              10. Tools On Surface
              11. Joint Push Pull
              12. Round Edge
              13. Bevel
              14. Windowizer
              15. Make Faces
              16. Section Cut Face
              • EdsonE
                Edson
                1. Round Edge
                eric,
                i could not find any script called round edge. can you post it, please?
                • boofredlayB
                  boofredlay
                  It's right here on the first page of the Ruby forum.
                  404 Not Found
                  (www.sketchucation.com)
                  • V
                    viga1978
                    my indispensable Ruby scripts are:
                    1)Bezier Spline
                    2)Tube along path
                    3)Windowizer
                    4)Remove material
                    5)Section Cut Faces
                    6)3d Grid
                      dolphus
                      My most used scripts are
                      1 FFD
                      2 Extrude along path
                      3 Dome
                      4 Calculator
                      5 (CASF) Fun Shapes
                      6 Blezier Curves
                      7 TOOLS ON SURFACE
                        Matt666
                        Hi ! Good idea !
                        1. Purge
                        2. Mirror
                        3. Quick selection
                        4. Tools On Surface
                        5. Joint Push Pull
                        6. Round Edge
                        7. Beziersplines
                        8. FFD
                        9. Ruby panel
                        10. Global material change
                        11. Section Cut Face
                        12. Cut List And Materials
                        13. Vray
                        14. Make faces
                        15. Extrude lines
                        Frenglish at its best !
                        My scripts
                        • N
                          nerz
                          Well i think we could add to this list the script soapskin i use nearly for each of my projects...
                          • FletchF
                            Fletch
                            1 - make faces
                            2 - extrude lines up, extrude lines using 2 points, etc... all them extrude lines commands.
                            3 - Windowizer (creates a curtainwall)
                            4 - select all instances - is that a ruby, or built-in... I forget now...
                            5 - Joint Push Pull (for push-pulling curves)
                            6 - pushpull face in any direction (using 2 points), and other pushpull face commands... along normal, along Z, etc.
                            7 - stair generator
                            8 - SU2KT (SketchUp 2 Kerkythea)
                            9 - Proper Animation - (great for showing diff. options for furniture, or doors swinging open)
                            10 - Scene Exporter pro - once get used to having it... can't live without.
                            11 - Automated 2D Output
                            12 - Mirror Selection
                            13 - Deselect Edges (Deselect Faces) - I think these are rubies...
                            14 - Offset on surface (and tools on surface)
                            15 - Purge (this should be number 2)
                            16 - Layers and Materials plugin by Didier Bur
                            17 - Intersect overlapping lines
                            18 - Selection Memory
                            19 - Soap Skin Bubble
                            20 - Protrude (closest thing we have to greeble plugin for SU)
                            Fletch
