    [REQ] Displacement ruby
    32 Posts 14 Posters 5.4k Views 14 Watching
    • soloS Offline
      solo
      Okay ruby masters this is probably science fiction, nevertheless I will ask the question.
      Is it possible to create a physical mesh from lets say a bump image, similar to the way a Heightfield terrain is created?
      As most folk know it's possible to do this using displacement tool in many apps, as displacement creates actual mesh and not just an illusion of it as bump mapping does. Could such a feature be created in ruby?
      I include some images to help explain.
      Simple shape
      http://img231.imageshack.us/img231/2861/dis1jd1.jpg
      The above shape after 'Sub-smooth' with 3 iriterations.
      http://img329.imageshack.us/img329/4955/dis2nf3.jpg
      Now using an image as reference to displacement then create this?
      http://img399.imageshack.us/img399/2859/dis3ju6.jpg
      http://www.solos-art.com
      • I Offline
        ilay7k
        ha...millions... of faces
        Why?
        example, 1) for rhino: developers "hide" this behavior under rdk command(extractdisplmesh)/anyway scene will be so heavy/ it normally actions at rendering process
        2) for cinema4d: realtime engine for showing displ/map in mograph displ.deformer//i think you want such like this
        http://img329.imageshack.us/img329/2682/c4dzt3.th.jpg
        • W Offline
          Whaat
          I've thought about creating such a script. The main difficulty is getting the pixel (RGB) value from the texture at a given point. If anyone knows how do this, let me know.
          • I Offline
            ilay7k
            Dale, Highfield-map generator?
            maybe through ogl libs
            • soloS Offline
              solo
              Ilay7k, for landscapes and terrains it would be an SU killer for sure, but for other purposes like if you remember Silvershadows method of doing a cobble stone sidewalk, this would be a snap.
              It can also be used for product modeling where only one or two surfaces needs a physical relief.
              How about this use?
              http://img413.imageshack.us/img413/5622/planeju8.jpg
              • soloS Offline
                solo
                As mentioned above, cobblestones or such mesh could be achieved using a simple bump image and if you have a seamles image like below then a small or low poly mesh can be generated which can be made into a component and tiled to form a cobble road as below without killing the model.
                The image:
                http://img214.imageshack.us/img214/6815/cobblebumpzg3.jpg
                The resulting mesh:
                http://img228.imageshack.us/img228/7590/cobbl1qpc3.jpg
                The mesh made into a component and tiled:
                http://img214.imageshack.us/img214/1857/cobbledisplacementkq5.jpg
                • P Offline
                  princedragoncok
                  Your examples are highly convincing solo. I'm all support for a displacement ruby. It seems you already have it however.. how did you create those models?
                  • soloS Offline
                    solo
                    I used a third party app, Vue 6 xstream and used the displacement feature, then baked it to polygons and exported it as .3ds.
                    The workflow is a little tedious and was hoping that if we could apply a texture to a given surface then select the surface and have an option to 'turn to mesh' which would then through the miracle coding of someone like Whaat become a 3d mesh with an option to reduce the polys if neccesary (already a ruby)
                    Just thoughts .... dreams.
                    Another example.
                    http://img296.imageshack.us/img296/6533/weavean9.jpg
                    • tbdT Offline
                      tbd
                      some ideas:
                      1. convert texture to .raw and read it via ruby file commands (as I did it in 2004 Terolscript)
                      2. direct image parsing - too complicated (several formats, compression)
                      3. server based - image upload to server, converted to an Array and returned back to Ruby
                      SketchUp Ruby Consultant | Podium 1.x developer
                      http://plugins.ro
                      • plot-parisP Offline
                        plot-paris
                        solo, let me tell you, that your illustrations are impressive. it makes perfectly clear, what you want to achieve with that script and what the benefits are.
                        I would love to have such a ruby.
                        like you said:
                        @solo said:
                        ...but for other purposes like if you remember Silvershadows method of doing a cobble stone sidewalk, this would be a snap.
                        this would really help to push realism of SketchUp models much further (towards "Silvershadow-realism"... 😄 )
                        • jujuJ Offline
                          juju
                          OMG, I would SO pay for this, so long as it is not server based.
                          • K Offline
                            kwistenbiebel
                            It's a nice idea.
                            However, I think current Sketchup will have difficulties with the polycount.
                            I rather see some advanced uv-mapping tools to get displacement maps on complexer surfaces so we can render displacement with the photoreal render engine of choice.
                            But I can understand a displacement2mesh plugin could be useful to people that want to see the displacement in their default Sketchup output.
                            • bigstickB Offline
                              bigstick
                              What about Didier's heightfield generator script here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
                              The documentation is here:- http://www.crai.archi.fr/RubyLibraryDepot/Ruby/Heightfield_gen.pdf
                              I tried it because I wanted to generate a rippled water plane, but couldn't get it to work at all. As they say however, "your mileage may vary".
                              • K Offline
                                kwistenbiebel
                                I didn't know there was a ruby script like that.Thank you for the link Bigstick.
                                I just tried using Didiers script (heightfield.rb), but it doesn't do anything at all in my case.
                                I converted a greyscaled displacement .jpg texture to a Ascii .pgm pixel image in Xnview (as suggested in the tutorial) and tried to load it through the ruby. Maybe I am doing something wrong, but I couldn't get it to generate geometry out of it.
                                As the ruby was created in 2004, maybe it isn't adapted to sketchup 6?
                                • I Offline
                                  ilay7k
                                  Didier, thank you
                                  i have such problem with loading pgm(in skp 5):
                                  i attach images
                                  Format; P2 (PGM) Width; 828 x Height; 177 Greyscale; 256 levels.
                                  Number of points; 16
                                  Empty mesh initialized.
                                  Mesh altitude range; 100.0
                                  Patch Length X; 0.0476058993229746
                                  Patch Width Y; 0.223693629205114
                                  Altitude Step Z; 0.392156862745098
                                  Create group; Yes
                                  Destination layer; Layer0
                                  Error; #<NoMethodError; undefined method `*' for nil;NilClass>
                                  (eval);196;in `hf_create_points'
                                  (eval);193;in `upto'
                                  (eval);193;in `hf_create_points'
                                  (eval);181;in `upto'
                                  (eval);181;in `hf_create_points'
                                  (eval);28;in `hf_gen'
                                  (eval);324
                                  (eval);324;in `call'
                                  anybodies know any kind console convertor bmp2ansipgm or raw?
                                  add: i use total commander addition - image lister by ivory
                                  • soloS Offline
                                    solo
                                    Irfanview can do it, and it's a free app.
                                    IrfanView - Official Homepage - One of the Most Popular Viewers Worldwide
                                    IrfanView ... one of the most popular viewers worldwide.
                                    (www.irfanview.com)
                                    • Didier BurD Offline
                                      Didier Bur
                                      it is not, you are right. But it could be (one line of code to change...)
                                      I'm testing it right now. But it is sooooo sloooow !
                                      This kind of feature requests a C++ prog IMHO.100x100 pixels -> 19600 faces, execution time: 2mn (!)
                                      DB
                                        Didier Bur
                                        Hi Ilayk,
                                        The error comes from that the options providers have changed from SU5 to SU6.
                                        If you decrypted the script, go to line 110:
                                        u = opt[3][2]
                                        and change it to:
                                        u = opt[0][2]
                                        That's all, it will work after that,
                                        DB
                                        • I Offline
                                          ilay7k
                                          strange
                                          it's same(can't normally get size of mesh...)
                                          Format; P2 (PGM) Width; 1680 x Height; 1509 Greyscale; 256 levels.
                                          Patch Length X; 23.4485281358547
                                          Patch Width Y; 26.1074792706233
                                          Create group; Yes
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;196;in `hf_create_points'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `upto'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;193;in `hf_create_points'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `upto'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;181;in `hf_create_points'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;28;in `hf_gen'
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324
                                          D;/Program Files/gsu6/Plugins/heightfield_gen.rb;324;in `call'
                                            Didier Bur
                                            Ok I forgot this one, line 190:
                                            def hf_create_points
                                            opt = Sketchup.active_model.options
                                            # u = opt[3][2] Version 5
                                            u = opt[0][2] # Version 6
                                            DB
                                            • 1 / 2
