    [Plugin][$] Tools On Surface - v2.6a - 01 Apr 24
    638 Posts 203 Posters 1.7m Views 202 Watching
    • fredo6F Offline
      fredo6
      NEW VERSION 1.5a - 17 Sep 09
      The main evolution is the addition of a Button palettefor better visualizing and modifying the various options of each tool. Freehandalso gets a Point & Click mode, which makes it equivalent to a Polyline On Surface, With and Without inferences (easier to draw over images).
      See attachment and documentation in main post of this thread at http://forums.sketchucation.com/viewtopic.php?f=180&t=11212#p76625
      ToolsOnSurface 1.5 requires to install LibFredo6 3.4 or higher.
      See post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 for download and installation.
      Fredo
      PS: Many thanks to Takeshi who helped to troubleshoot some issues on Mac.
        Ben Ritter
        Fredo6,
        I can't find the attachment.
        • fredo6F Offline
          fredo6
          It is at the end of the first post of this thread.
            Ben Ritter
            Never mind, I found it. My settings were preventing me from going back to the first page.
            By the way, thank you very much.
              Daniel S
              Fredo:
              I think that ZLoader__OnSurface.rb is missing in the .zip
              Daniel S
              • soloS Offline
                solo
                Yeah, I'm having an issue with z-loader also
                http://www.solos-art.com
                • CadFatherC Offline
                  CadFather
                  wow, Fredo is back - better sit down...
                  • fredo6F Offline
                    fredo6
                    @daniel s said:
                    Fredo:
                    Thanks Daniel, you are the best tester!
                    I included the file in the main post (v1.5b)
                    Fredo
                    • utilerU Offline
                      utiler
                      Thanks in advance, Fredo. You ROCK!!!!
                      Just Curious...
                      • X Offline
                        xrok1
                        KUDO'S 😍
                        β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        • EarthMoverE Offline
                          EarthMover
                          Wow Fredo. That freehand tool looks incredible. I'm wondering if a similar algorithm could be used to automatically extract a traced cutout from a transparent .png image....by locating the pixel data. Make a rectangle, drop a .png texture on it, run the plugin and be left with a polygon the shape of the transparent image.
                          Sorry for the digression, just thinking of how amazing that pixel identification technique is and what other purposes it could serve.
                          Thanks for the update for TOS!!! πŸ‘ πŸ‘
                          Content Creator at Skapeup
                          • fredo6F Offline
                            fredo6
                            No clue whether this can be done (but this would be very different from Freehand). The minimum would be to be able to read a PNG encoded file. There is a Ruby library for that (RMagick by Tim Hunter) but it's probably a lot of processing.
                            • kenK Offline
                              ken
                              Fredo
                              I believe Page 13, "Drawing without a surface" one of the following lines is incorrect.
                              LEFT: for vertical plane defined by Red and Blue axis
                              RIGTH: for vertical plane defined by Red and Blue axis - I think this should be Green and Blue axis
                              So thanks for the great plugin
                              Ken
                                Daniel S
                                Thank you Fredo!!!
                                Great update!!
                                Here I made alternative icons and cursors
                                Download from:
                                IMAGES_DanielS.zip
                                Tools On Surface has 13 tools... I'm not superstitious but I vote for a new tool (Tape measure on Surface?)
                                Daniel S
                                • fredo6F Offline
                                  fredo6
                                  Thanks Daniel,
                                  I integrated them in the version 1.5c, updated in the main post
                                  Fredo
                                  • soloS Offline
                                    solo
                                    Marvelous set of tools, Thanks a ton Fredo, these will empower me to push SU even further.
                                      Can the TOS_Dir_13 folder be removed?
                                        The Any button is brilliant! Save so much precious space. πŸ‘
                                        btw, how are you drawing the icons for your viewport toolbar? most of them looks like simple line drawinsgs - but some, like the exit button looks more complicated? bitmap?
                                        And how do you draw coloured filled areas?
                                        • N Offline
                                          notareal
                                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                                            CadFather
                                            to delete the old TOS_Dir_13 folder, it seems you must copy LibTraductor_20.rb from TOS_Dir_13 folder to your new TOS_Dir_15
                                            also need to change the line TOS_Dir_13 to TOS_Dir_15 in libfredo6.rb
                                            [require 'TOS_Dir_15/LibTraductor_20.rb' if Sketchup.find_support_file('TOS_Dir_13/LibTraductor_20.rb', "Plugins") #Compatibility]
                                            Fredo (Thanks) will know better but this works here
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
