    File Sizes
    10 Posts 6 Posters 1.2k Views 6 Watching
      Clarencecat
      Can anyone help?
      i am creating a house model - it was starting to get slow, so i downgraded the images i was projecting
      which didn't make a lot of difference, so i tried experimenting by gradually taking parts away then saving,
      but the file is same size (its not a large model) 11.5mg i use a mac
      thanks
      • Alan FraserA Offline
        Alan Fraser
        Have you purged unused components and materials?
        3D Figures
          Clarencecat
          Yes i just checked that....
          • EdsonE Offline
            Edson
            if i am not wrong what really matters is the poly count (edges and faces). sometimes a big file behaves better than a small one because of that.
            http://www.mahfuz.arq.br
            • brodieB Offline
              brodie
              That sort of thing has happened to me before. Eventually I deleted the whole thing just to see what would happen and my file was still crazy big. What I did was turn on all the layers copy everything and paste it into a fresh skp file - sort of a super-purge!
              -Brodie
              • plot-parisP Offline
                plot-paris
                you are absolutely right, Edson.
                if you have structured your model well, with components where possible to reduce the file size, even a small model can bring your graphic card to it's limits.
                try scene 6 in this model for example. look at the file size (only about 130 kb). but the poly count is enormous and therefore your computer will have difficulties to cope with it...
                  In addition to purging unused components, you might need to purge unsued materials, too.
                    Alan Fraser
                    There's an echo in here. πŸ˜‰
                    3D Figures
                        Clarencecat
                        Thanks chaps, i'll try a few things
