    [Plugin] CenterPointAll.rb
    34 Posts 18 Posters 44.9k Views 18 Watching
      @ship69 said:
      Does this video have sound? It's coming out silent on my PC.
      No. It's a silent video.
      • E Offline
        Einstein
        Thanks TIG 😄
        This simple tool helps me rotating components around their centerpoints which is quite complicated in SU.
        It would be even more handy if a created centerpoint was interactive, I mean: changed with scaling and moving component or group it's based on. But I realise that would be also much more complicated code.
        • BoxB Offline
          To rotate about the midpoint of a group or component, use the rotation handles that appear when you use the Move tool.
            sarkarshomit
            Can't get it working in sketchup 2018.working fine in skup16, but not in 18...any help if i am doing something wrong!!
              Evidently you are doing something wrong. I just installed it in SU2018 and ran it. It works fine. How did you install it? Where did you install it? Do you have Guides set to show in the View menu?
              Result of CenterPointAll
                sarkarshomit
                [attachment=0:9qktjmkx]<!-- ia0 -->Screenshot - 5_16_2018 , 5_31_16 AM.png<!-- ia0 -->[/attachment:9qktjmkx]
                Thanks for the help.
                Strangely in skup16, the plugin shows up in plugins menu named as "set centerpoint".
                And in skup18 it shows up in extensions menu as "Add centerpoint".
                So finally its working for me. Thanks again.
                • BoxB Offline
                  Sounds like you may have had a different extension installed in 2016. There is one called Set Centerpoint.
                  Tig's shows for me in 2016 as Add Centerpoint.
                    Rastus
                    Hate to appear thick but I can't install CenterPointAll in 2018 (vs 8.0.1...). Where do I need to place the plugin?
                    Thanks!!
                      Look here
                      https://sketchucation.com/pluginstore?pln=CenterPointAll
                      which gives you an RBZ which can be installed in v2018 using Window > Extension Manager > Install... [red-button]
                      No need to find the Plugins folder etc...
                      Almost all Plugins which include an old RB file in their thread will have an entry in the PluginStore, giving an easily installed RBZ for use in all current versions of SketchUp...
                      Even the now often unsupported v8 had these RBZ capabilities in later MRs,,,
                        Rastus
                        Thanks!
                        Been a while since I've used Sketchup. You made an invaluable plugin!
                        • kachuppK Offline
                          kachupp
                          For those who dislike using the plugin (Extensions) menu I've modified TIGs version to use
                          the context menu. I find it much faster than moving the mouse all the way too
                          the top menu bar click and click.
                          pick, right click, click "Point at Center" done.
                          UI.add_context_menu_handler {|menu|
                          	menu.add_item("Point at Center") {
                            	model=Sketchup.active_model
                            	entities=model.active_entities
                            	selection=model.selection
                            	model.start_operation("Add Centerpoint")
                            	selection.to_a.each{|e|entities.add_cpoint(e.bounds.center)}
                            	model.commit_operation
                            Michalis Barmpavasiloglou
                            Hallo, wie bekomme ich dies Plugin in das Scetchup Programm instaliert. Herunter geladen habe ich es schon aber ich sehe es nicht bei den Plugins nicht...ich würde mich echt freuen, wenn mir jemand helfen könnte.
                            Beste Grüße MB
                              Translated by Google
                              @michalis barmpavasiloglou said:
                              Hello, how do I get this plugin installed in the scetchup program. I already downloaded it but I don't see it in the plugins...I would really appreciate if someone could help me.
                              It depends upon what version of SketchUp are you really using. Your profile indicates a version that does not and never has existed.
                              If you are using SketchUp 2022 Pro, go to Extensions>Extension Manager and click on Install Extension. Then navigate to where you saved the extension, select it, and choose Open.
                              Better would be to download and install the Sketchucation ExtensionStore tool from Resources at the top of this page and use it to install extensions from Sketchucation.
                              • Y Offline
                                youbac @plot-paris
                                @plot-paris plugin = CLF Arc Centerpoint Finder
                                • 2 / 2
