    [Plugin] Round Edge - v1.0 (by Bezier)
    166 Posts 83 Posters 158.5k Views 83 Watching
      Copy the mesh before and if you don't like the result, just delete it and paste the original in place (of course it's just a workaround but in case it is not programmable...)
      • fredo6F Offline
        fredo6
        @thomthom said:
        If I undo right after the operation it only undo each drawing operation the script did. I'd have to press undo many times to restore the mesh.
        Do you mean that each Undo will cancel a call to the Round Edge script, or that you need several Undos for a single Round Edge operation ? (in this latter case, this is strange, because I don't have the problem).
        Thanks to advise
        Fredo
        • fredo6F Offline
          fredo6
          @borgman said:
          RayOchoa, I didn't make eacht half a component because I wanted to delete each and every line that is a result of pasting the two halves together and because of some non-symetrical parts. It's all done now, with the model being 20.9MB, but she renders quite nice πŸ˜‰
          Fredo, do you have paypal? I would like to make a small contribution for your efforts πŸ˜„
          Thanks very much for your appreciation of the script, and for your intention to reward the effort. I am not familiar with Paypal, but I do have an account at my email address fredosix@hotmail.com. Don't feel obliged, I am glad already with your kind recognition!
          Fredo
          • K Offline
            KustuRA
            thank you!
              CeBe
              That's great! Thank you Sir! πŸ˜„
                ar_angle
                Nice! Thanks!
                  Thanks to advise
                  Fredo
                  It was the latest V-Ray for SketchUp 1.00.74 that interfered with the undo. Using the original VfSU the Round Edge operation could be undone as expected. With the latest VfSU undoing would undo each step of the script operations one by one.
                  • P Offline
                    Pico
                    SOrry for interupting but can this be done with this ruby from Fredo?
                    I see only that corner problem (cube) thats stays sharp, has this been done?
                    • free agentF Offline
                      free agent
                      this has been an issue for me using this script too, the corners are sharp and not rounded
                      • P Offline
                        Pico
                        Then its still not fixed?
                        One question more, can you control number of faces that will be created, like e.g. if you want to fillet an edge between 2 surfaces, can you control how many faces (3 or 4 or 5 or 10...) will make that new "smooth" egde.
                          free agent
                          yes
                          • P Offline
                            Pico
                            Is Fredo maybe working on this "sharp corner" issue?
                              remus
                              Id imagine so, along with all the other stuff he's currently doing.
                              • P Offline
                                Pico
                                Any clue when will it be finished?
                                • CadFatherC Offline
                                  CadFather
                                  i made icon and cursors for my version of this plugin - here they are if anyone likes them too
                                  RDE_Dir.zip
                                  • boofredlayB Offline
                                    boofredlay
                                    Thanks for the icon!
                                      Daniel S
                                      Great Icons!
                                      A crazy ask: It is possible to make the plugin work in a future version with a variable radius along the edge? πŸ˜’
                                      Daniel S
                                      Variable RoundEdge Video.zip
                                      • fredo6F Offline
                                        fredo6
                                        Daniel S
                                        The question is indeed crazy. πŸ˜’
                                        Need to think about it.
                                        Actually I was more thinking of having the offset different for the upper and side faces. Variable curvature is going to be tough in the general case, actually because of the limited flexibility you have in Sketchup to do interactive inputs.
                                        Fredo
                                        • P Offline
                                          payam2000
                                          Hey guys!
                                          I was sooooooooooooo excited when I saw a solution and your plugin for round edges. I install it as noted, get the icon and everything, but then as soon as I highlight the edges and click on the icon, the windows for distance and etc comes up, as soon as I click on the icon, the whole scketchup window closes and I get the ScketchUp Error report (bug Splat) window... I have version 6.4.112
                                          Any suggestions?
                                            CadFather
                                            when i get these bugs i usually empty the plugins folder and try the ruby on its own - if it works then i know it is a conflict somewhere. then i try again, each time adding back small groups of the other scripts.. of course one needs to close/open sketchup everytime.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 4 / 9
