    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 73.1k Views 43 Watching
      JuanV.Soler
      any update for this plugin in the near future?
      Thank you very much.
      will love it ¡
      • xiombargX Offline
        xiombarg
        I'm surprised that more people don't use this. Having quick access for toggling on/off hidden geometry, work lines, hide rest of model, perspective and a few other of my most often used tools is invaluable to me. It saves me truckloads of time. Thanks Jim.
        • xiombargX Offline
          xiombarg
          Sorry... I meant thanks Dan.
          • panixiaP Offline
            panixia
            this is exactly the 50% of the reason why i stay with SU8 for now. 👍
              Why can't you do it with SU2013 or SU2014? I have keyboard shortcuts for toggling visibility of those things that were set up in SU6 and I've continued to use them for all versions since then.
              • BoxB Offline
                Plus you can customise native and plugin toolbars.
                And this plugin does work in 2014
                • panixiaP Offline
                  panixia
                  sure, i know you can do this by keyboard shortcuts.. but i like to do this sort of thing with toolbars buttons, having basically any sort ofshortcuts + modifier combo (ctr+alt+...) already assigned to tons of tools/plugins and so on..
                  • panixiaP Offline
                    panixia
                    😲 are you sure?
                    i didn't try 2014, but i remember when i tried 2013 it didn't work for me..
                    • BoxB Offline
                      @panixia said:
                      😲 are you sure?
                      I wouldn't answer a question if I hadn't checked the answer.
                      BTW it also works in 2013. and yes I have installed and checked it.
                      • xiombargX Offline
                        xiombarg
                        I like to have buttons for things that I use fairly often but not often enough that I have the shortcuts programmed into my fingertips. Thos being the case, it's faster for me to have the buttons instead of pausing to remember what the shortcut is and having to try a couple of keys before I finally get it.
                        Otherwise you are right. Shortcuts are always faster, as long as you remember what they are.
                        • X Offline
                          xkalvisx
                          And where is the key "Make component"?
                            Jim
                            Not all SketchUp commands are available from the Ruby API. If the API does not support a command, as it does not with Make Component, then the command will need to be recreated from the beginning. It is possible to recreate the Make Component command in Ruby. I will work on it this coming week, unless someone has already written such and and would be kind enough to share it. 😉
                            • BoxB Offline
                              I'm a bit confused Jim, Make component is available in your toolset.
                              Perhaps the question is what Key stroke is Make Component, the default for that is g.
                                Jim
                                Heh, so it is. it's called "makeComponent" of all things.
                                Unfortunately, it uses a send_action which does not appear to work in SketchUp 2014.
                                • BoxB Offline
                                  Works perfectly in my version of 2014.
                                    Jim
                                    Ah, it opens the dialog when loose geometry is selected. I had selected a Group. Thanks.
                                    • Bob JamesB Offline
                                      Bob James
                                      Tried both 'standard' plugin location and additional location.
                                        Jim
                                        Hello Bob,
                                        1. You need to install TIG's Purge All plugin.
                                        2. I thought I trapped that error.
                                        Will look into it. Thanks for taking time to report.
                                          Jim
                                          Bob, I posted a new version this morning in the Plugin Store, but didn't have time to mention it. Did you find and try the update?
                                          You still need to install TIG's purge_all plugin for the custum button to work.
                                          • dereiD Offline
                                            derei
                                            The "viewRedo" message for Sketchup.send_action, seems unimplemented in API and not present in standard Camera toolbar, but is available in Camera drop-down menu. May be just an omision from Trimble, or it was intended to not be available? Any reasons for that?
                                            I remember a time when it was, and I had it on my Custom Toolbar.
                                            DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
                                            • 6
                                            • 7
                                            • 5 / 7
