    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 76.4k Views 43 Watching
      @dan rathbun said:
      This is a common request. But it is difficult to realize. We would have to get all plugin authors to adhere to a certain standard. It is not likely this feature will be included in the ver8 update. (But it's on the future list.)
      I got a snippet that overloads the UI, Menu, Command and Toolbar class which allows me to traverse the content of the custom UI elements. It is possible, but it needs proper testing and error catching.
      • dereiD Offline
        derei
        This "certain standard" is something that might limit the freedom in making the script, or is something easy to achieve and will not affect in any way the scripting manner?
        Why I am asking? Because your plugin is maybe the best method to customize SU interface. And maybe if you make a call to arms, there will be some (if not all) plugin masters who will join in this πŸ’š
        I must admit that I'd be most pleased if this would happen (I'm a little selfish, ain't I ? πŸ˜’ )
        DESIGNER AND ARTIST DEREI.UK
        • SiPieFaceS Offline
          SiPieFace
          @diego-rodriguez said:
          "I agree, this is the answer. To be able to drag & drop buttons to build Toolbars, and then drag & drop Toolbars in a window. It can be done, someone just needs to do it.
          There is a plugin named SU Tool that is very close to what I think is the best solution; but it is encrypted (or I'd have "borrowed" it already.) But SU Tool is likely close to what the ultimate solution will look like."
          this is the way the plugins PowerSutool organizer works.
          to arrange the toolbars.
          using a html interface, and a text editor
          Maybe this can help find a solution?
          http://www.dhtmlgoodies.com/scripts/drag-drop-nodes/drag-drop-nodes.html
          other solution
          http://www.dhtmlgoodies.com/index.html?page=dragDrop
          Diego, can you give more of an explanation of how this works? You mention an HTML editor and a text editor but there's not enough info for my non-programming brain to work out. Your links don't seem to relate to editing of the toolbars. I'm bugged by the standard UI (and I know I'm far from alone on this) and so want to be able to tweak the toolbars and icons so any info on how to do this would be very much appreciated. Thanks.
          • dereiD Offline
            derei
            any update for this plugin in the near future?
            Thank you very much.
            • urgenU Offline
              urgen
              Hi Jim, Many thanks for the plugin again!
              --pupil forever...------
                JuanV.Soler
                will love it Β‘
                • xiombargX Offline
                  xiombarg
                  I'm surprised that more people don't use this. Having quick access for toggling on/off hidden geometry, work lines, hide rest of model, perspective and a few other of my most often used tools is invaluable to me. It saves me truckloads of time. Thanks Jim.
                  • xiombargX Offline
                    xiombarg
                    Sorry... I meant thanks Dan.
                    • panixiaP Offline
                      panixia
                      this is exactly the 50% of the reason why i stay with SU8 for now. πŸ‘
                        Why can't you do it with SU2013 or SU2014? I have keyboard shortcuts for toggling visibility of those things that were set up in SU6 and I've continued to use them for all versions since then.
                        • BoxB Offline
                          Plus you can customise native and plugin toolbars.
                          And this plugin does work in 2014
                          • panixiaP Offline
                            panixia
                            sure, i know you can do this by keyboard shortcuts.. but i like to do this sort of thing with toolbars buttons, having basically any sort ofshortcuts + modifier combo (ctr+alt+...) already assigned to tons of tools/plugins and so on..
                            • panixiaP Offline
                              panixia
                              😲 are you sure?
                              i didn't try 2014, but i remember when i tried 2013 it didn't work for me..
                              • BoxB Offline
                                @panixia said:
                                😲 are you sure?
                                I wouldn't answer a question if I hadn't checked the answer.
                                BTW it also works in 2013. and yes I have installed and checked it.
                                • xiombargX Offline
                                  xiombarg
                                  I like to have buttons for things that I use fairly often but not often enough that I have the shortcuts programmed into my fingertips. Thos being the case, it's faster for me to have the buttons instead of pausing to remember what the shortcut is and having to try a couple of keys before I finally get it.
                                  Otherwise you are right. Shortcuts are always faster, as long as you remember what they are.
                                  • X Offline
                                    xkalvisx
                                    And where is the key "Make component"?
                                      Jim
                                      Not all SketchUp commands are available from the Ruby API. If the API does not support a command, as it does not with Make Component, then the command will need to be recreated from the beginning. It is possible to recreate the Make Component command in Ruby. I will work on it this coming week, unless someone has already written such and and would be kind enough to share it. πŸ˜‰
                                      • BoxB Offline
                                        I'm a bit confused Jim, Make component is available in your toolset.
                                        Perhaps the question is what Key stroke is Make Component, the default for that is g.
                                          Jim
                                          Heh, so it is. it's called "makeComponent" of all things.
                                          Unfortunately, it uses a send_action which does not appear to work in SketchUp 2014.
                                          • BoxB Offline
                                            Works perfectly in my version of 2014.
                                            • 5 / 7
