    [Plugin] Custom Toolbars Plugin
    121 Posts 43 Posters 76.9k Views 43 Watching
    • xiombargX Offline
      xiombarg
      @dave r said:
      Why can't you do it with SU2013 or SU2014? I have keyboard shortcuts for toggling visibility of those things that were set up in SU6 and I've continued to use them for all versions since then.
      I like to have buttons for things that I use fairly often but not often enough that I have the shortcuts programmed into my fingertips. Thos being the case, it's faster for me to have the buttons instead of pausing to remember what the shortcut is and having to try a couple of keys before I finally get it.
      Otherwise you are right. Shortcuts are always faster, as long as you remember what they are.
      • X Offline
        xkalvisx
        And where is the key "Make component"?
          Jim
          Not all SketchUp commands are available from the Ruby API. If the API does not support a command, as it does not with Make Component, then the command will need to be recreated from the beginning. It is possible to recreate the Make Component command in Ruby. I will work on it this coming week, unless someone has already written such and and would be kind enough to share it. 😉
          • BoxB Offline
            I'm a bit confused Jim, Make component is available in your toolset.
            Perhaps the question is what Key stroke is Make Component, the default for that is g.
              Jim
              Heh, so it is. it's called "makeComponent" of all things.
              Unfortunately, it uses a send_action which does not appear to work in SketchUp 2014.
              • BoxB Offline
                Works perfectly in my version of 2014.
                  Jim
                  Ah, it opens the dialog when loose geometry is selected. I had selected a Group. Thanks.
                  • Bob JamesB Offline
                    Bob James
                    Tried both 'standard' plugin location and additional location.
                      Jim
                      Hello Bob,
                      1. You need to install TIG's Purge All plugin.
                      2. I thought I trapped that error.
                      Will look into it. Thanks for taking time to report.
                        Jim
                        Bob, I posted a new version this morning in the Plugin Store, but didn't have time to mention it. Did you find and try the update?
                        You still need to install TIG's purge_all plugin for the custum button to work.
                        • dereiD Offline
                          derei
                          The "viewRedo" message for Sketchup.send_action, seems unimplemented in API and not present in standard Camera toolbar, but is available in Camera drop-down menu. May be just an omision from Trimble, or it was intended to not be available? Any reasons for that?
                          I remember a time when it was, and I had it on my Custom Toolbar.
                          DESIGNER AND ARTIST DEREI.UK
                          • Dan RathbunD Offline
                            Dan Rathbun
                            Yes it was removed in SU2013 or SU2014 (can't remember which.)
                            SketchUp used to remember a whole bunch of camera views, and the "viewUndo:" button would go backwards in the stack. The "viewRedo:" button would go forward in the stack.
                            Now only the current and previous views are saved. The "viewUndo:" ("View Previous") button just switches between them.
                            I don't remember why they said the memory stack was removed. We didn't like the change at the time. Could be that in practice not many used the feature, ie only went one view back, etc. Or they were just simplifying the codebase.
                            Hmmm.. thinking more,... I think the change had to do with avoiding ViewObserver crashes or complexities.
                            I'm not here much anymore.
                            • dereiD Offline
                              derei
                              I see, thanks for clearing it out. For me was a very good asset. It didn't remembered too many views. I think it was about 5. But it was helpful when experimenting with views, for rendering. Sometimes I just wanted to see if another view was better, but then, I decided to go back... Now I'll just have to stick to the current limitations.
                                Dan Rathbun
                                There might be some plugins... someone made a Camera Memory plugin I think.
                                • jgbJ Offline
                                  jgb
                                  I am almost converted to SU-15 from SU-8.
                                  I just realized that many of my SU-8 toolbars (especially "toggle/hidden") are not native SU but within Toolbars.rb.
                                  How can I import the toolbars.rb set to SU-15?
                                  I can't find the current file here.
                                  jgb
                                    glro
                                    http://sketchuptips.blogspot.com.es/2008/06/custom-toolbars-release-08-06-01.html[/anchor]
                                    i don't remember well, but i use it in SU15, and it seems to me no changes were needed from SU8
                                      driven
                                      A few posts above and over a year ago...
                                      You should get that version, and add updated additional plugins to it...
                                      • jgbJ Offline
                                        jgb
                                        Thanks for the replies.
                                        Yesterday I just copied the toolbars .rb and Dir from SU-8 to SU-15. Worked no problem. 👍
                                        I just reinstalled via Extension Mgr the (perhaps) updated version and noticed my toolbars were exactly the same. Yes, I changed the file type from ZIP to RBZ. 😒
                                        In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? 😕
                                        Oh, and what are these other plugins to be added to it are you referring too?
                                        jgb
                                          driven
                                          @jgb said:
                                          In the web page (noted above) one of the standard toolbars (Scenes) has an extra icon that my installed version does not. Did I do something wrong? :?
                                          your probably missing the 'Bottom' view?
                                          Possibly the code has change for it and you haven't actually updated or Jim left it out of the update...
                                          The whole point of custom toolbars is it lets you add other plugins to the toolbar, if you have no extra's then doing nothing is fine...
                                          • jgbJ Offline
                                            jgb
                                            When I get a chance I will compare the scripts of my SU-8 Toolbars to SU-15 and get back here with the findings.
                                            jgb
                                            • 5 / 7
