    [Plugin] Door-Lintel Update + Window-Sill
    73 Posts 32 Posters 55.7k Views 32 Watching
    • guanjinG
      guanjin @guanjin
      This post is deleted!
      • guanjinG
        guanjin @guanjin
        @guanjin said in [Plugin] Door-Lintel Update + Window-Sill:
        Thank you to Didier Bur for the source code, which successfully fixed the work in 2024 and modified the multi-faceted selection stretching.
        Thank you again, Didier Bur
        A 1 Reply Last reply
        • L
          lamngoaison
          i got a new problem. SU2025. any one fix it for SU2025 yet? please!!
          TIGT 1 Reply Last reply
          • TIGT
            TIG Moderator @lamngoaison
            @lamngoaison
            The linked post contains a ZIP file posted a few days ago
            link
            Which can be converted to an RBZ by changing its filetype suffix.
            It worked in v2024, so should also work in v2025 ?
            L 1 Reply Last reply
            • L
              lamngoaison @TIG
              @TIG thanks alot 😁
              • M
                memaridrue81
                hi Didier Bur,
                May I request an update for this extension for SketchUp 2023 and higher? it work well with my SKP 2022 but file crashes when I use it in skp 2023 😊
                Many thanks!
                • L
                  lamngoaison @guanjin
                  by unknown problem. it not work anymore in my SU2025. so bro, can you share this version of your with other. thanks alot!!!
                  • sumasterS
                    sumaster @guanjin
                    @guanjin
                    can you post a new updated script
                    thanks
                    Thank you,
                    SUmaster
                    • TIGT
                      The linked .ZIP file is still available in the earlier post.
                      Download it, then just change its filetype to .RBZ as previously explained.
                      Then install it...
                      sumasterS 1 Reply Last reply 👍
                      • sumasterS
                        sumaster @TIG
                        @TIG
                        yes thanks 👍
                        Thank you,
                        SUmaster
                        • A
                          Anentt1 @guanjin
                          @guanjin how to use this code for fix the issue
                          • L
                            luongtuan @Didier Bur
                            @Didier-Bur
                            Hello. Can you update SketchUp to 2026?
                            • TIGT
                              If it works in v2024 [see earlier posts] it'll probably work in v2026.
                              Try it.
                              To install an extension from a ZIP archive file rather than from an RBZ you will need either to change the file-type suffix, or even easier use the SketchUcation submenu item to install it from Archive, which works for both RBZ and ZIP archives...
                              • 4 / 4
