    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 134.2k Views 85 Watching
      sepo
      Nifty and very useful script. Thank you for your kindness.
      • philemP Offline
        philem
        From Adelalide, South Australia...
        ONYA MATE !!! πŸ˜„
        Just do it, it might be fun.
        • erikBE Offline
          erikB
          Chris, thank you for this very usefull script !!! 😍 Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
          erikB
            remus
            I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
              CPhillips
              Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
                remus
                heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
                http://farm4.static.flickr.com/3084/2462110487_7f1bc07a0c.jpg?v=0
                bevel crash.skp
                  Jorgensen
                  Hi Chris
                  Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters 😞
                  Jorgensen
                  sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                  • K Offline
                    kwistenbiebel
                    I just returned from a few days off at sea. Coming home is a delight πŸ˜„, finding this new plugin.
                    Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
                    Kudos for these nice contributions to the SU community. Appreciated!
                    Regards,
                    Kwistenbiebel
                      spc
                      Thanks Chris for share your talent, 😍
                        Daniel S
                        I find a way to reproduce this bug:
                        • Select something, right click and choose "Bevel".
                        • In the bevel selection dialog choose cancel.
                        • Then select the same or other geometry, right click and choose "Bevel" again.
                        Daniel S
                          CPhillips
                          Daniel S
                          Ah, I see the problem. I will post a fixed version tomorrow.
                          Thanks Daniel!
                            mike d
                            Thank you very much that will come in handy
                            mike d
                            The grass is always GREENER on the roof.
                            • majidM Offline
                              majid
                              i tried this tool several times but it seems there is something wrong whit me ( or a bug ) that it doesn't works!!!!
                                remus
                                majid, are you doing the following:
                                1)create shape (cone, box, cylinder etc,)
                                2)select the entire shape
                                3)right click and select bevel
                                • W Offline
                                  watkins
                                  Dear Majid,
                                  Remember, the input is in inches. Try using a fraction like 0.01 inches.
                                  Regards,
                                  Bob
                                    CPhillips
                                    Remus is right, you need to select the whole mesh.
                                    There are really several different types of beveling. Mesh, face and edge. This plug-in just does mesh at the moment.
                                    • majidM Offline
                                      majid
                                      ok here is some tests over one shape... strange results!!! i guess it's bkz of rubies interfere
                                        CPhillips
                                        Looks like you are not selecting the whole mesh and/or using too large values for the amount of inset.
                                        I have beveled cylinders and it works ok if you keep the values small.
                                          sintra
                                          Thanks for your time and efforts on this it looks great 😎
                                          Kind regards
                                          Darren
                                            Dan
                                            Thanks a lot, Chris!
                                            Very useful and longtime missing tool.
                                            Can't wait to put it to work.
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
