    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 137.5k Views 85 Watching
    • ely862meE Offline
      ely862me
      i was waiting for something like this
      thx
      Elisei (sketchupper)
      Come and See EliseiDesign
      • chippwaltersC Offline
        chippwalters
        Very much appreciated!
        Currently working with Cross-Reality technologies
          CPhillips
          You're welcome. πŸ˜„
          Now back to GTA....
            lapx
            Chris you da man! 😎
            Thank you kindly!
              sepo
              Nifty and very useful script. Thank you for your kindness.
              • philemP Offline
                philem
                From Adelalide, South Australia...
                ONYA MATE !!! πŸ˜„
                Just do it, it might be fun.
                • erikBE Offline
                  erikB
                  Chris, thank you for this very usefull script !!! 😍 Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
                  erikB
                    remus
                    I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
                      CPhillips
                      Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
                        remus
                        heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
                        http://farm4.static.flickr.com/3084/2462110487_7f1bc07a0c.jpg?v=0
                        bevel crash.skp
                          Jorgensen
                          Hi Chris
                          Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters 😞
                          Jorgensen
                            kwistenbiebel
                            I just returned from a few days off at sea. Coming home is a delight πŸ˜„, finding this new plugin.
                            Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
                            Kudos for these nice contributions to the SU community. Appreciated!
                            Regards,
                            Kwistenbiebel
                              spc
                              Thanks Chris for share your talent, 😍
                                Daniel S
                                I find a way to reproduce this bug:
                                • Select something, right click and choose "Bevel".
                                • In the bevel selection dialog choose cancel.
                                • Then select the same or other geometry, right click and choose "Bevel" again.
                                Daniel S
                                  CPhillips
                                  Daniel S
                                  Ah, I see the problem. I will post a fixed version tomorrow.
                                  Thanks Daniel!
                                    mike d
                                    Thank you very much that will come in handy
                                    mike d
                                    The grass is always GREENER on the roof.
                                    • majidM Offline
                                      majid
                                      i tried this tool several times but it seems there is something wrong whit me ( or a bug ) that it doesn't works!!!!
                                        remus
                                        majid, are you doing the following:
                                        1)create shape (cone, box, cylinder etc,)
                                        2)select the entire shape
                                        3)right click and select bevel
                                        • W Offline
                                          watkins
                                          Dear Majid,
                                          Remember, the input is in inches. Try using a fraction like 0.01 inches.
                                          Regards,
                                          Bob
                                            CPhillips
                                            Remus is right, you need to select the whole mesh.
                                            There are really several different types of beveling. Mesh, face and edge. This plug-in just does mesh at the moment.
                                            • 2 / 8
