[Plugin] SketchyBevel 0.1(Updated May 11)
THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!THANK YOU!!!!
THAAANK YOU!!!
Whats left to say.........
....except THANK YOU again
i was waiting for something like this
thx
Very much appreciated!
You're welcome.
Now back to GTA....
Chris you da man!
Thank you kindly! -
Nifty and very useful script. Thank you for your kindness.
From Adelalide, South Australia...
ONYA MATE !!!
Chris, thank you for this very usefull script !!!
Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
erikB -
I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
Hi Chris
Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters
Jorgensen -
I just returned from a few days off at sea. Coming home is a delight
, finding this new plugin.Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
Kudos for these nice contributions to the SU community. Appreciated!Regards,
Kwistenbiebel -
Thanks Chris for share your talent,
I find a way to reproduce this bug:
- Select something, right click and choose "Bevel".
- In the bevel selection dialog choose cancel.
- Then select the same or other geometry, right click and choose "Bevel" again.
Daniel S
Daniel S
Ah, I see the problem. I will post a fixed version tomorrow.
Thanks Daniel!
Thank you very much that will come in handy
mike d
