    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
    • Mike LuceyM
      Mike Lucey
      ....except THANK YOU again πŸ‘
      • ely862meE
        ely862me
        i was waiting for something like this
        thx
        Elisei (sketchupper)
        Come and See EliseiDesign
        • chippwaltersC
          chippwalters
          Very much appreciated!
          Currently working with Cross-Reality technologies
          • C
            CPhillips
            You're welcome. πŸ˜„
            Now back to GTA....
            • L
              lapx
              Chris you da man! 😎
              Thank you kindly!
                sepo
                Nifty and very useful script. Thank you for your kindness.
                • philemP
                  philem
                  From Adelalide, South Australia...
                  ONYA MATE !!! πŸ˜„
                  Just do it, it might be fun.
                  • erikBE
                    erikB
                    Chris, thank you for this very usefull script !!! 😍 Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
                    erikB
                      remus
                      I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
                      • C
                        CPhillips
                        Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
                          remus
                          heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
                          http://farm4.static.flickr.com/3084/2462110487_7f1bc07a0c.jpg?v=0
                          bevel crash.skp
                            Jorgensen
                            Hi Chris
                            Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters 😞
                            Jorgensen
                            • K
                              kwistenbiebel
                              I just returned from a few days off at sea. Coming home is a delight πŸ˜„, finding this new plugin.
                              Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
                              Kudos for these nice contributions to the SU community. Appreciated!
                              Regards,
                              Kwistenbiebel
                                spc
                                Thanks Chris for share your talent, 😍
                                  Daniel S
                                  I find a way to reproduce this bug:
                                  • Select something, right click and choose "Bevel".
                                  • In the bevel selection dialog choose cancel.
                                  • Then select the same or other geometry, right click and choose "Bevel" again.
                                  Daniel S
                                  • C
                                    CPhillips
                                    Daniel S
                                    Ah, I see the problem. I will post a fixed version tomorrow.
                                    Thanks Daniel!
                                      mike d
                                      Thank you very much that will come in handy
                                      mike d
                                      The grass is always GREENER on the roof.
                                      • majidM
                                        majid
                                        i tried this tool several times but it seems there is something wrong whit me ( or a bug ) that it doesn't works!!!!
                                          remus
                                          majid, are you doing the following:
                                          1)create shape (cone, box, cylinder etc,)
                                          2)select the entire shape
                                          3)right click and select bevel
                                          • W
                                            watkins
                                            Dear Majid,
                                            Remember, the input is in inches. Try using a fraction like 0.01 inches.
                                            Regards,
                                            Bob
                                            • 2 / 8
