    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
    • philemP
      philem
      From Adelalide, South Australia...
      ONYA MATE !!! ๐Ÿ˜„
      Just do it, it might be fun.
      • erikBE
        erikB
        Chris, thank you for this very usefull script !!! ๐Ÿ˜ Works as far as I can tell (only tried some simple forms) like a charme. Only, one question would it be difficult to implement a choice between inches and cm for the bevel width ?
        erikB
          remus
          I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
          • C
            CPhillips
            Thats too bad. Do you have any idea how to reproduce it? When I try it with a single face it doesn't do that.
              remus
              heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
              http://farm4.static.flickr.com/3084/2462110487_7f1bc07a0c.jpg?v=0
              bevel crash.skp
                Jorgensen
                Hi Chris
                Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters ๐Ÿ˜ž
                Jorgensen
                • K
                  kwistenbiebel
                  I just returned from a few days off at sea. Coming home is a delight ๐Ÿ˜„, finding this new plugin.
                  Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
                  Kudos for these nice contributions to the SU community. Appreciated!
                  Regards,
                  Kwistenbiebel
                    spc
                    Thanks Chris for share your talent, ๐Ÿ˜
                      Daniel S
                      I find a way to reproduce this bug:
                      • Select something, right click and choose "Bevel".
                      • In the bevel selection dialog choose cancel.
                      • Then select the same or other geometry, right click and choose "Bevel" again.
                      Daniel S
                      • C
                        CPhillips
                        Daniel S
                        Ah, I see the problem. I will post a fixed version tomorrow.
                        Thanks Daniel!
                          mike d
                          Thank you very much that will come in handy
                          mike d
                          The grass is always GREENER on the roof.
                          • majidM
                            majid
                            i tried this tool several times but it seems there is something wrong whit me ( or a bug ) that it doesn't works!!!!
                              remus
                              majid, are you doing the following:
                              1)create shape (cone, box, cylinder etc,)
                              2)select the entire shape
                              3)right click and select bevel
                              • W
                                watkins
                                Dear Majid,
                                Remember, the input is in inches. Try using a fraction like 0.01 inches.
                                Regards,
                                Bob
                                • C
                                  CPhillips
                                  Remus is right, you need to select the whole mesh.
                                  There are really several different types of beveling. Mesh, face and edge. This plug-in just does mesh at the moment.
                                  • majidM
                                    majid
                                    ok here is some tests over one shape... strange results!!! i guess it's bkz of rubies interfere
                                    • C
                                      CPhillips
                                      Looks like you are not selecting the whole mesh and/or using too large values for the amount of inset.
                                      I have beveled cylinders and it works ok if you keep the values small.
                                        sintra
                                        Thanks for your time and efforts on this it looks great ๐Ÿ˜Ž
                                        Kind regards
                                        Darren
                                          Dan
                                          Thanks a lot, Chris!
                                          Very useful and longtime missing tool.
                                          Can't wait to put it to work.
                                          • K
                                            kwistenbiebel
                                            The ruby works very well. ๐Ÿ˜„
                                            I love it that one can use it by simply right clicking the selected geometry.
                                            Very speedy.
                                            One little remark:
                                            The ruby seems to only bevel concave corners and not the convex ones.
                                            see image:
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/bevel2.jpg
                                            Besides the small hickups, this is a very fine ruby.
                                            Thank you Chris. ๐Ÿ‘
                                            @Majid,
                                            I believe the issue you experience indeed has to do with the bevel value set too high.
                                            • 2 / 8
