    [Plugin] SketchyBevel 0.1(Updated May 11)
    143 Posts 85 Posters 150.0k Views 85 Watching
      remus
      heres a quick mock up of the thing that made it crash. I was trying to bevel the top surface, but without hidden geometry turned on.
      http://farm4.static.flickr.com/3084/2462110487_7f1bc07a0c.jpg?v=0
      bevel crash.skp
        Jorgensen
        Hi Chris
        Thanks for this very usefull tool. I one question though, would it be possible to use it in Decimal/millimeters ? It seems to use inches, even if my drawing is set to use millimeters 😞
        Jorgensen
        • K
          kwistenbiebel
          I just returned from a few days off at sea. Coming home is a delight 😄, finding this new plugin.
          Thank you very much Chris. I'll be trying the script when working on a model for work tomorrow.
          Kudos for these nice contributions to the SU community. Appreciated!
          Regards,
          Kwistenbiebel
            spc
            Thanks Chris for share your talent, 😍
              Daniel S
              @remus said:
              I've found a bug: i tried just beveling a face (should have read the instructions...) and it gives me a dialog saying 'wrong arguement type false (expected array)', the problem is it is impossible to get this dialog to go away, you have to shut SU down form the task manager before you can use SU again.
              I find a way to reproduce this bug:
              • Select something, right click and choose "Bevel".
              • In the bevel selection dialog choose cancel.
              • Then select the same or other geometry, right click and choose "Bevel" again.
              Daniel S
              • C
                CPhillips
                Daniel S
                Ah, I see the problem. I will post a fixed version tomorrow.
                Thanks Daniel!
                  mike d
                  Thank you very much that will come in handy
                  mike d
                  The grass is always GREENER on the roof.
                  • majidM
                    majid
                    i tried this tool several times but it seems there is something wrong whit me ( or a bug ) that it doesn't works!!!!
                      remus
                      majid, are you doing the following:
                      1)create shape (cone, box, cylinder etc,)
                      2)select the entire shape
                      3)right click and select bevel
                      • W
                        watkins
                        Dear Majid,
                        Remember, the input is in inches. Try using a fraction like 0.01 inches.
                        Regards,
                        Bob
                        • C
                          CPhillips
                          Remus is right, you need to select the whole mesh.
                          There are really several different types of beveling. Mesh, face and edge. This plug-in just does mesh at the moment.
                          • majidM
                            majid
                            ok here is some tests over one shape... strange results!!! i guess it's bkz of rubies interfere
                            • C
                              CPhillips
                              Looks like you are not selecting the whole mesh and/or using too large values for the amount of inset.
                              I have beveled cylinders and it works ok if you keep the values small.
                                sintra
                                Thanks for your time and efforts on this it looks great 😎
                                Kind regards
                                Darren
                                  Dan
                                  Thanks a lot, Chris!
                                  Very useful and longtime missing tool.
                                  Can't wait to put it to work.
                                  • K
                                    kwistenbiebel
                                    The ruby works very well. 😄
                                    I love it that one can use it by simply right clicking the selected geometry.
                                    Very speedy.
                                    One little remark:
                                    The ruby seems to only bevel concave corners and not the convex ones.
                                    see image:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/SU/bevel2.jpg
                                    Besides the small hickups, this is a very fine ruby.
                                    Thank you Chris. 👍
                                    @Majid,
                                    I believe the issue you experience indeed has to do with the bevel value set too high.
                                    • StinkieS
                                      Stinkie
                                      Hm. Weird ...
                                        Daniel S
                                        It dosen´t work in all the cases... but still is very useful 😍
                                        • StinkieS
                                          Stinkie
                                          Yup, and it certainly is a step in the right direction. 😄
                                            marcociacci
                                            where is the file to download your plugin???
                                            ...i don't find it!!! please i need SketchyBevel!!!
                                            • 2 / 8
