    Splitting down the middle and re-gluing
    5 Posts 4 Posters 1.1k Views 4 Watching
    • J
      johnd
      I have been attempting to make several symmetrical objects. I have done work and then tried to establish a gluing plane by intersecting the work with a large rectangular block... and cutting away everything I don't need.
      I use the move key to make a second copy and the scale tool set to minus 1 to reverse the object. I then slide everything back together and make it a group as best I can. Should not things that are put right next to each other lock onto their counterpart? Can I work on the boundary between the two "components" or "groups" without having to "explode?"
      It seems like things get out of line hours later when I discover there are two lines in some places.
      Thanks for any suggestions.
      John D.
      • G
        GreyHead
        To make a symmetrical shape, create half of it. Hide the edges that meet. Make it a component, copy and 'paste in place', then scale the copy by -1. To finish make the two components into a new component.
        Bob
        • G
          Gidon Yuval
          Bob, that's a beautifully presented explanation.
          How did you produce that page?
          If you don't know where you're going, you're never going to get there.
          • S
            Sawduster
            Yeah, that is very cool, compact, and probably pretty quick. I noticed Jean-Paul using a similar method. Screen exports maybe.
            May all your dimensions be the sum of their total.
            Jerry
            http://www.sawdustersplace.com
            • G
              GreyHead
              Thanks. Screen grabs and callouts with SnagIt; you have to use screen grabs or if you want to show any of the SU controls. Edited the final image in Xara because it make sit easy to re-size and shuffle on the page.
              Bob
