    Splitting down the middle and re-gluing
    5 Posts 4 Posters 1.1k Views 4 Watching
      johnd
      I have been attempting to make several symmetrical objects. I have done work and then tried to establish a gluing plane by intersecting the work with a large rectangular block... and cutting away everything I don't need.
      I use the move key to make a second copy and the scale tool set to minus 1 to reverse the object. I then slide everything back together and make it a group as best I can. Should not things that are put right next to each other lock onto their counterpart? Can I work on the boundary between the two "components" or "groups" without having to "explode?"
      It seems like things get out of line hours later when I discover there are two lines in some places.
      Thanks for any suggestions.
      John D.
        GreyHead
        To make a symmetrical shape, create half of it. Hide the edges that meet. Make it a component, copy and 'paste in place', then scale the copy by -1. To finish make the two components into a new component.
        Bob
          Gidon Yuval
          Bob, that's a beautifully presented explanation.
          How did you produce that page?
          If you don't know where you're going, you're never going to get there.
            Sawduster
            Yeah, that is very cool, compact, and probably pretty quick. I noticed Jean-Paul using a similar method. Screen exports maybe.
            May all your dimensions be the sum of their total.
            Jerry
            http://www.sawdustersplace.com
              GreyHead
              Thanks. Screen grabs and callouts with SnagIt; you have to use screen grabs or if you want to show any of the SU controls. Edited the final image in Xara because it make sit easy to re-size and shuffle on the page.
              Bob
