    Need Help on SPIRALOID SHAPE
    25 Posts 9 Posters 6.2k Views 9 Watching
    • simon le bonS
      simon le bon
      Despite my many tests, I cannot draw correctly my end of spiral banisters. I have used a lot pushpull tool and move tool to reach at the end, after a laborious work, to approximative result that smell a bit too much the handmade.
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Spiraloid.jpg
      Here is the best i can do
      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Handmade_Spiraloid.jpg
      I am afraid that it is necessary to use a ruby script, but it still exceeds my abilities. If anybody thinks of an elegant solution, I am taker.
      Here is the file to work on it.
      DivShare File - HorseshoeStair.skp
      "Bien cordialement", simon le bon.
      • G
        GreyHead
        Do you have a sketch or a photo of what it 'should' look like? What are the constraints? For example, it looks as though the center should be a circle centered on the line of the outside of the main banister and the same height as the end of that line?
        Bob
        • GaieusG
          Hi Simon,
          Have a look at this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=15&t=6940&p=44916#p44855 - the guys have put a couple of links together there for a similar shape.
          • G
            GreyHead
            I had a go - but it's tricky, you need an volute(?) spiral where the spacing between the lines reduces as you get nearer the center. The spirals in both the other examples are equispaced. And that's before you get to the three dimensional part.
            Here's a version that moves in the right direction but is clearly wrong.
            Bob
            • simon le bonS
              simon le bon
              dear Gaieus, with you link, i have some funny work for one or two evenings before be back.
              dear GreHead, The only picture i possess is a personal micrograffiti on a stamp of paper: just a little idea.
              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoegraf_th.jpg
              The result you give seems good to me. Can you explain further your:"Here's a version that moves in the right direction but is clearly wrong" ?
              I thought appart that my wish is not a mathematic shape but is mostly dealing with sculpture. Like a natural shape in a way. So i thought that perhaps there is a solution using sandbox.tool (that i have never used: i'm going take a look on it)
              With my thanks to both of you, simon
              • G
                GreyHead
                Well perhaps I'm nearer than I thought I was . . .
                To give you the short version I cleaned up your main version, put a cylinder in place for the center, then drew a volute spiral using a RubyScript (K2 graphs - sorry about the maths).
                Added a few lines to make a closed face, scaled it to size, pulled it up with the Push/Pull tool, then intersected it with an inclined plane to line up with the top surface of the main balustrade.
                Easier to see than describe, there's a 'pictures only' tutorial attached -- too late to add words tonight.
                Bob
                horseshoe_2.skp
                • S
                  smartsizer
                  Starting from one section of your attached file, I adjusted the "pushpull" height of the various spiral segments. In my opinion, the volute looks better if it is a little higher than the point where the large curving sweep meets the spiral. I started working my way around the spiral, simplifying the curve from the outside in. I leave it to you to take it from there if you like the effect.
                  You might redraw your spiral so that it looks about the same from above, but the endpoints of the spiral segments fall on the same radii, so the segments get shorter the closer they get to the center. This will make it easier to fine tune the shape. If this doesn't make sense, let me know and I will draw a sample file.
                  Good luck!
                  HorseshoeStair2.skp
                  • G
                    GreyHead
                    I like that baluster sweep, much nicer to my eye than the intersected plane. Will have a look at the spiral script later and see if I can do anything useful. There has to be a first ruby script I guess.
                    Bob
                    • simon le bonS
                      simon le bon
                      -dear GreyHead i would like to apply your method but -(one: i am unable to find anywhere K2 graphs RubyScript (but this search had showed me how many exciting extensions we can use))
                      and -(two: i'm not sure of what to do with the last step of your horseshoe_2.skp). I'm afraid i need a scene number six
                      And else i agree with you: smartsizer's baluster look nice.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/GreyHead_volute.jpg
                      -dear smartsizer, your solutions gives me a new way to work :
                      -/creating multilevel facing -/intersected with a plane -/draw top lines of the wall
                      -/stitch so far we can in the volute.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step1-1.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step2-1.jpg
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_step3-1.jpg
                      And you're right, the shape i pretty better like that.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/smartsizer_idea.jpg
                      I'm glad to see i was far but not so far from this.
                      Are we in the real world? thanks a lot to give your freetime so friendly.
                      • G
                        GreyHead
                        Hi simon,
                        I'll try to add the extra step later this evening.
                        K2 Graphs seems to be here but I think I got it as part of whole bundle of scripts that I downloaded from here but now can't find.
                        Bob
                        • TIGT
                          K_tools.rb is what you need...
                          http://www.crai.archi.fr/rubylibrarydepot/ruby/fr_k_tools_50.rb
                          • simon le bonS
                            simon le bon
                              • -/ I feel Stupid - - -
                                In the hurry i had taken first step smartsizer' shape to follow his purpose. Eureka the result was great. But there is a secret. We can't obtain this shape with a simple intersection with a plane. The top of the wall is shaped with two helicoidal lines. And how smartizer have did that: it's a mystery. Probably to discover in Ruby arcanes... Also my enthusiasm, under your eyes in the board has been driven to a flop . And my poor Horseshoe stair is still on the paper.
                                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/NotsosimpleBalustre.jpg
                            dear GreyHead and tig thanks for K_tools.rb (ha! K-Two). Now i need little work to understand how use it.
                            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/coquille.jpg
                            • boofredlayB
                              boofredlay
                              Sorry I have not read all of the posts in this but would the Spiralizer help you???
                              404 Not Found
                              (www.sketchucation.com)
                              I am not sure you can get a flat top on it or not with the spiralizer but it is worth a try.
                              • G
                                GreyHead
                                😄 Keep going, I learn a lot by trying things out here and experimenting.
                                As far as I can see Smartsizer did it by creating that grid of lines on each side and drawing in diagonals by hand.
                                Bob
                                PS I'll take a look at Spiraliser
                                PPS I'm experimenting with a script to do some of this but it's slow work - a first script squeezed in odd moments. So far so good.
                                • simon le bonS
                                  simon le bon
                                  It appears that you are probably right dear GreyHead. Smartsizer seems have drawn his diagonals by hand.
                                  http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/diagsdrawbyhand-1.jpg
                                  I haven't found the way to draw your volute with k-tools.
                                  • S
                                    smartsizer
                                    Yes, the diagonals are drawn by hand. Details are shown in the Scenes in the attached skp. Scenes 24 and 25 illustrate a method I discovered to manipulate points in a mesh.
                                    HorseshoeStair tutorial.skp
                                    • G
                                      GreyHead
                                      My spiral was something like:
                                      K2 Graphs | 2D-Graph polar r=f(p)
                                      p-range from: 0.0 (default)
                                      p-Range to: 25.132741 (i.e. 8*pi)
                                      Stepwidth: 0.06283185 (default - 100 steps per turn)
                                      r = p**2 (default)
                                      Then scale down to a useful size.
                                      Bob
                                      • G
                                        GreyHead
                                        Bien fait ! Bravo !
                                        Bob
                                        PS You can get rid of those 'blue' segments at the bottom by selecting a 'white' area, right click and choose 'orient faces'.
                                        • simon le bonS
                                          simon le bon
                                          THAT'S IT!
                                          Here is my HORSESHOE STAIR with volute ramps.
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final3.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final4.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/horseshoestair_Final5.jpg
                                          The volute and the leading help of GreyHead, a working direction to follow by smartsizer, many mistakes repaired by fox hack, pair of things i haven't understood at all, and at last, still lot of hard handmade work!!
                                          (as you can see here)
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute-2.jpg
                                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/intermediatVolute_b.jpg
                                          (if someone is interested by this laborious travel: DivShare File - HorseshoeStairFinal.skp
                                          All my thanks (in order of apparition) to: Greyhead Gaieus smartsizer Tig Boofredlay. You where incredibly kind and perseverant by my side.
                                          At the end, smartsizer have given us a so beautiful lesson of drawing: so many strong solutions HorseshoeStair tutorial.skp. It surely have to be sent as a single post on the How To section: for great advantage of everybody interested in Sketchup (and 3D) modeling.
                                          . Well, for horseshoe stair, it's over. But i have another project i shall call "The Everythingcurved Stair". Just the good matter to take off with it.
                                                           simonlebon
                                          • Wo3DanW
                                            Wo3Dan
                                            Simon,
                                            I see that you finished your horse shoe shaped stairs, resulting in a very nice model.
                                            Thanks for sharing. Looking forward to what curved complex shape you have in mind now.
                                            cheers,
                                            Wo3Dan
                                            • 1 / 2
