    Tapering top of square post cap
    5 Posts 4 Posters 1.6k Views 4 Watching
    • H
      Harry
      Need help creating the top of a fence post cap similar to the bottom one in the attached photo. I don't know how to taper the square top. Any help would be appreciated.
      Thanks,
      Harry
      • GaieusG
        Hi there,
        What I can figure out of that image, it has a "roof like" top, right?
        Well the easiest way is:
        1. draw a square (the top of your column)
          draw the diagonals (make sure to intersect them in the middle - just draw the second one in two pieces; from the corner to the midpoint of the first one an from there to the opposite corner)
        2. make sure nothing is selected and choose the move tool
        3. hover over the intersections of the two diagonals
        4. when you see the green inference and the tip "endpoint", grab it with the move tool
        5. hit the up arrow key (this will lock the move on the blue axis)
        6. move to the desired height.
          If it is not tapered that way, I'd need a better pic to see.
        • TIGT
          Here's a brief Tutorial - it applies to many things...
          FollowMeCap.skp
          • H
            Harry
            Gentlemen,
            Gaieus and Tig. Thanks for taking the time to share your expertise. I learn something new every time I use SketchUp but I couldn't figure that one out. Tig, the tutorial you provided was exactly what I needed to know. Now it's time to see if this Newbie can apply that information.
            Thanks again.
            Harry
            • H
              Harry
              Here’s the finished product. Just what was needed to complement the fence gate. Next step; make a real one with wood. Actually, the proper nomenclature is: “Post cranium cover”
              Thanks again, gentlemen.
              Harry
