    Camera space question
    18 Posts 6 Posters 1.8k Views 6 Watching
    • PixeroP Offline
      Pixero
      How do I move in camera space with ruby? (Along cam dir, sideways and up)
      I havent found any good info.
      • AdamBA Offline
        AdamB
        view.camera.xaxis
        view.camera.yaxis
        view.camera.zaxis
        give you the camera space frame. (xaxis is left/right, yaxis is up/down, zaxis is along camera dir).
        • PixeroP Offline
          Pixero
          Thanks, I've come that far. It's how to use those that I can't figure out.
          Here is an example of what I want to do.
          I have a position (a point3d) that I want to transform a distance of x-length, y-length and z-length in the camera space coordinate system.
          How do I set it up?
            Jim
            I think you may be looking too deeply. How would you do it in model space?
            • PixeroP Offline
              Pixero
              In "world space" I do it:
              newPos = Geom::Point3d.new(pos.x+Xdist, pos.y+Ydist, pos.z+Zdist)
              pos = newPos
                Jim
                This might work...
                xdist = 10
                pos = Geom;;Point3d.new(0,0,0)
                camera_axis = Sketchup.active_model.active_view.camera.xaxis
                camera_axis.length = xdist
                newPos = pos + camera_axis
                • AdamBA Offline
                  AdamB
                  Ah, ok. So you need to transform your x-length,y-length,z-length into world space.
                  camera_space_translation = Geom::Vector3d.new(xDist,yDist,zDist)
                  then
                  world_space_translation = Geom::Vector3d.new(view.camera.xaxis.dot(camera_space_translation),
                  view.camera.yaxis.dot(camera_space_translation),
                  view.camera.zaxis.dot(camera_space_translation))
                  (do whatever with world_space_translation)
                  BTW This is just a long hand vector-matrix multiply.
                    Jim
                    Adam,
                    Is your method different than using the Transformarion.axis, which is a
                    method is used to create a Transformation that goes from world coordinates to an arbitrary coordinate system
                    Is the result the same? I could use a course on 3d mathematics, particularly as it applies in SketchUp.
                    • AdamBA Offline
                      AdamB
                      No different. Just wasn't sure whether you can get the camera matrix as a whole, so thought it just as easy to do 3 dot products. (And we do just want a 3x3 tranform here).
                      • PixeroP Offline
                        Pixero
                        Added Sketchup file to further explain above problem.
                        Camspace_weirdness.skp
                        • PixeroP Offline
                          Pixero
                          First, sorry for not getting back earlier. Its been kind of hectic here.
                          Thanks for answering but I still have problems.
                          Adam, your way gives relly weird results. Either there is something wrong with your method or (more possibly) there is something wrong with me. 😉
                          When using your method and just translating the xDist it gets a transform also in th z axis and if I use the value 100 as xDist it gets moved a distance of 2540 mm?
                          Part of the code:
                          camSpaceTranslation = Geom;;Vector3d.new(xDist, yDist, zDist)
                          worldSpaceTranslation = Geom;;Vector3d.new(camera.xaxis.dot(camSpaceTranslation), camera.yaxis.dot(camSpaceTranslation), camera.zaxis.dot(camSpaceTranslation))
                          newEye = eye + worldSpaceTranslation
                          newTarget = target + worldSpaceTranslation
                          eye = newEye
                          target = newTarget
                          camera = camera.set(eye, target, up)
                          Once more to clearify what I'm after:
                          Moving along world axes is working but I want to numerically move the camera eye point and target point (the target shall just move the same amount as the eye) in the cameras sightline*(in/out),*left/right and up/down.
                          Any thoughts?
                          • AdamBA Offline
                            AdamB
                            And how many millimeters in an inch (the native units of Sketchup) are there?
                            • jujuJ Offline
                              juju
                              25.4mm to an inch.
                                The "native" unit of mySketchUp is centimetre.
                                  Jim
                                  model = Sketchup.active_model
                                  c = model.active_view.camera
                                  eye = c.eye
                                  up = c.up
                                  target = c.target
                                  xaxis = c.xaxis
                                  yaxis = c.yaxis
                                  zaxis = c.zaxis
                                  model.entities.add_cpoint eye
                                  model.entities.add_cpoint target
                                  model.entities.add_text("eye", eye)
                                  model.entities.add_text("target", target)
                                  distance = 12
                                  newEye = eye.offset(xaxis, distance)
                                  model.entities.add_cpoint newEye
                                  model.entities.add_text("newEye", newEye)
                                  newTarget = target.offset(xaxis, distance)
                                  model.entities.add_cpoint newTarget
                                  model.entities.add_text("newTarget", newTarget)
                                  c.set(newEye, newTarget, up)
                                    RickW
                                    Might I suggest AddPages as a reference script? It adds pages (scenes) orthographically (based on user-supplied x, y, and z offsets). If I understand the gist of the discussion, then AddPages has at its heart the transformation code in question.
                                    RickW
                                    www.smustard.com
                                    • PixeroP Offline
                                      Pixero
                                      Thanks all for helping! 😍
                                      Now I got it working the way I want.
                                      I'll be back when the script is done.
                                      • PixeroP Offline
                                        Pixero
                                        See this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1528&p=41330#p41330
                                        And once more, thanks for helping!
