πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Camera space question
18 Posts 6 Posters 1.4k Views 6 Watching
    Pixero
    How do I move in camera space with ruby? (Along cam dir, sideways and up)
    I havent found any good info.
      AdamB
      view.camera.xaxis
      view.camera.yaxis
      view.camera.zaxis
      give you the camera space frame. (xaxis is left/right, yaxis is up/down, zaxis is along camera dir).
        Pixero
        Thanks, I've come that far. It's how to use those that I can't figure out.
        Here is an example of what I want to do.
        I have a position (a point3d) that I want to transform a distance of x-length, y-length and z-length in the camera space coordinate system.
        How do I set it up?
          Jim
          I think you may be looking too deeply. How would you do it in model space?
            Pixero
            In "world space" I do it:
            newPos = Geom::Point3d.new(pos.x+Xdist, pos.y+Ydist, pos.z+Zdist)
            pos = newPos
              Jim
              This might work...
              xdist = 10
              pos = Geom;;Point3d.new(0,0,0)
              camera_axis = Sketchup.active_model.active_view.camera.xaxis
              camera_axis.length = xdist
              newPos = pos + camera_axis
                AdamB
                Ah, ok. So you need to transform your x-length,y-length,z-length into world space.
                camera_space_translation = Geom::Vector3d.new(xDist,yDist,zDist)
                then
                world_space_translation = Geom::Vector3d.new(view.camera.xaxis.dot(camera_space_translation),
                view.camera.yaxis.dot(camera_space_translation),
                view.camera.zaxis.dot(camera_space_translation))
                (do whatever with world_space_translation)
                BTW This is just a long hand vector-matrix multiply.
                  Jim
                  Adam,
                  Is your method different than using the Transformarion.axis, which is a
                  method is used to create a Transformation that goes from world coordinates to an arbitrary coordinate system
                  Is the result the same? I could use a course on 3d mathematics, particularly as it applies in SketchUp.
                    AdamB
                    No different. Just wasn't sure whether you can get the camera matrix as a whole, so thought it just as easy to do 3 dot products. (And we do just want a 3x3 tranform here).
                      Pixero
                      Added Sketchup file to further explain above problem.
                      Camspace_weirdness.skp
                        Pixero
                        First, sorry for not getting back earlier. Its been kind of hectic here.
                        Thanks for answering but I still have problems.
                        Adam, your way gives relly weird results. Either there is something wrong with your method or (more possibly) there is something wrong with me. πŸ˜‰
                        When using your method and just translating the xDist it gets a transform also in th z axis and if I use the value 100 as xDist it gets moved a distance of 2540 mm?
                        Part of the code:
                        camSpaceTranslation = Geom;;Vector3d.new(xDist, yDist, zDist)
                        worldSpaceTranslation = Geom;;Vector3d.new(camera.xaxis.dot(camSpaceTranslation), camera.yaxis.dot(camSpaceTranslation), camera.zaxis.dot(camSpaceTranslation))
                        newEye = eye + worldSpaceTranslation
                        newTarget = target + worldSpaceTranslation
                        eye = newEye
                        target = newTarget
                        camera = camera.set(eye, target, up)
                        Once more to clearify what I'm after:
                        Moving along world axes is working but I want to numerically move the camera eye point and target point (the target shall just move the same amount as the eye) in the cameras sightline*(in/out),*left/right and up/down.
                        Any thoughts?
                          AdamB
                          And how many millimeters in an inch (the native units of Sketchup) are there?
                          • jujuJ Offline
                            juju
                            25.4mm to an inch.
                              πŸ˜„
                              The "native" unit of mySketchUp is centimetre.
                                Jim
                                model = Sketchup.active_model
                                c = model.active_view.camera
                                eye = c.eye
                                up = c.up
                                target = c.target
                                xaxis = c.xaxis
                                yaxis = c.yaxis
                                zaxis = c.zaxis
                                model.entities.add_cpoint eye
                                model.entities.add_cpoint target
                                model.entities.add_text("eye", eye)
                                model.entities.add_text("target", target)
                                distance = 12
                                newEye = eye.offset(xaxis, distance)
                                model.entities.add_cpoint newEye
                                model.entities.add_text("newEye", newEye)
                                newTarget = target.offset(xaxis, distance)
                                model.entities.add_cpoint newTarget
                                model.entities.add_text("newTarget", newTarget)
                                c.set(newEye, newTarget, up)
                                  RickW
                                  Might I suggest AddPages as a reference script? It adds pages (scenes) orthographically (based on user-supplied x, y, and z offsets). If I understand the gist of the discussion, then AddPages has at its heart the transformation code in question.
                                  RickW
                                  [www.smustard.com](http://www.smustard.com)
                                    Pixero
                                    Thanks all for helping! 😍
                                    Now I got it working the way I want.
                                    I'll be back when the script is done.
                                      Pixero
                                      See this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1528&p=41330#p41330
                                      And once more, thanks for helping!
