    Camera space question
    18 Posts 6 Posters 2.3k Views 6 Watching
      Jim
      I think you may be looking too deeply. How would you do it in model space?
      • PixeroP
        Pixero
        In "world space" I do it:
        newPos = Geom::Point3d.new(pos.x+Xdist, pos.y+Ydist, pos.z+Zdist)
        pos = newPos
          Jim
          This might work...
          xdist = 10
          pos = Geom;;Point3d.new(0,0,0)
          camera_axis = Sketchup.active_model.active_view.camera.xaxis
          camera_axis.length = xdist
          newPos = pos + camera_axis
          • AdamBA
            AdamB
            Ah, ok. So you need to transform your x-length,y-length,z-length into world space.
            camera_space_translation = Geom::Vector3d.new(xDist,yDist,zDist)
            then
            world_space_translation = Geom::Vector3d.new(view.camera.xaxis.dot(camera_space_translation),
            view.camera.yaxis.dot(camera_space_translation),
            view.camera.zaxis.dot(camera_space_translation))
            (do whatever with world_space_translation)
            BTW This is just a long hand vector-matrix multiply.
              Jim
              Adam,
              Is your method different than using the Transformarion.axis, which is a
              method is used to create a Transformation that goes from world coordinates to an arbitrary coordinate system
              Is the result the same? I could use a course on 3d mathematics, particularly as it applies in SketchUp.
              • AdamBA
                AdamB
                No different. Just wasn't sure whether you can get the camera matrix as a whole, so thought it just as easy to do 3 dot products. (And we do just want a 3x3 tranform here).
                • PixeroP
                  Pixero
                  Added Sketchup file to further explain above problem.
                  Camspace_weirdness.skp
                  • PixeroP
                    Pixero
                    First, sorry for not getting back earlier. Its been kind of hectic here.
                    Thanks for answering but I still have problems.
                    Adam, your way gives relly weird results. Either there is something wrong with your method or (more possibly) there is something wrong with me. 😉
                    When using your method and just translating the xDist it gets a transform also in th z axis and if I use the value 100 as xDist it gets moved a distance of 2540 mm?
                    Part of the code:
                    camSpaceTranslation = Geom;;Vector3d.new(xDist, yDist, zDist)
                    worldSpaceTranslation = Geom;;Vector3d.new(camera.xaxis.dot(camSpaceTranslation), camera.yaxis.dot(camSpaceTranslation), camera.zaxis.dot(camSpaceTranslation))
                    newEye = eye + worldSpaceTranslation
                    newTarget = target + worldSpaceTranslation
                    eye = newEye
                    target = newTarget
                    camera = camera.set(eye, target, up)
                    Once more to clearify what I'm after:
                    Moving along world axes is working but I want to numerically move the camera eye point and target point (the target shall just move the same amount as the eye) in the cameras sightline*(in/out),*left/right and up/down.
                    Any thoughts?
                    • AdamBA
                      AdamB
                      And how many millimeters in an inch (the native units of Sketchup) are there?
                      • jujuJ
                        juju
                        25.4mm to an inch.
                        • GaieusG
                          The "native" unit of mySketchUp is centimetre.
                            Jim
                            model = Sketchup.active_model
                            c = model.active_view.camera
                            eye = c.eye
                            up = c.up
                            target = c.target
                            xaxis = c.xaxis
                            yaxis = c.yaxis
                            zaxis = c.zaxis
                            model.entities.add_cpoint eye
                            model.entities.add_cpoint target
                            model.entities.add_text("eye", eye)
                            model.entities.add_text("target", target)
                            distance = 12
                            newEye = eye.offset(xaxis, distance)
                            model.entities.add_cpoint newEye
                            model.entities.add_text("newEye", newEye)
                            newTarget = target.offset(xaxis, distance)
                            model.entities.add_cpoint newTarget
                            model.entities.add_text("newTarget", newTarget)
                            c.set(newEye, newTarget, up)
                              RickW
                              Might I suggest AddPages as a reference script? It adds pages (scenes) orthographically (based on user-supplied x, y, and z offsets). If I understand the gist of the discussion, then AddPages has at its heart the transformation code in question.
                              RickW
                              www.smustard.com
                              • PixeroP
                                Pixero
                                Thanks all for helping! 😍
                                Now I got it working the way I want.
                                I'll be back when the script is done.
                                • PixeroP
                                  Pixero
                                  See this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1528&p=41330#p41330
                                  And once more, thanks for helping!
