    Camera space question
    18 Posts 6 Posters 2.2k Views 6 Watching
    • PixeroP
      Pixero
      In "world space" I do it:
      newPos = Geom::Point3d.new(pos.x+Xdist, pos.y+Ydist, pos.z+Zdist)
      pos = newPos
        Jim
        This might work...
        xdist = 10
        pos = Geom;;Point3d.new(0,0,0)
        camera_axis = Sketchup.active_model.active_view.camera.xaxis
        camera_axis.length = xdist
        newPos = pos + camera_axis
        • AdamBA
          AdamB
          Ah, ok. So you need to transform your x-length,y-length,z-length into world space.
          camera_space_translation = Geom::Vector3d.new(xDist,yDist,zDist)
          then
          world_space_translation = Geom::Vector3d.new(view.camera.xaxis.dot(camera_space_translation),
          view.camera.yaxis.dot(camera_space_translation),
          view.camera.zaxis.dot(camera_space_translation))
          (do whatever with world_space_translation)
          BTW This is just a long hand vector-matrix multiply.
            Jim
            Adam,
            Is your method different than using the Transformarion.axis, which is a
            method is used to create a Transformation that goes from world coordinates to an arbitrary coordinate system
            Is the result the same? I could use a course on 3d mathematics, particularly as it applies in SketchUp.
            • AdamBA
              AdamB
              No different. Just wasn't sure whether you can get the camera matrix as a whole, so thought it just as easy to do 3 dot products. (And we do just want a 3x3 tranform here).
              • PixeroP
                Pixero
                Added Sketchup file to further explain above problem.
                Camspace_weirdness.skp
                • PixeroP
                  Pixero
                  First, sorry for not getting back earlier. Its been kind of hectic here.
                  Thanks for answering but I still have problems.
                  Adam, your way gives relly weird results. Either there is something wrong with your method or (more possibly) there is something wrong with me. 😉
                  When using your method and just translating the xDist it gets a transform also in th z axis and if I use the value 100 as xDist it gets moved a distance of 2540 mm?
                  Part of the code:
                  camSpaceTranslation = Geom;;Vector3d.new(xDist, yDist, zDist)
                  worldSpaceTranslation = Geom;;Vector3d.new(camera.xaxis.dot(camSpaceTranslation), camera.yaxis.dot(camSpaceTranslation), camera.zaxis.dot(camSpaceTranslation))
                  newEye = eye + worldSpaceTranslation
                  newTarget = target + worldSpaceTranslation
                  eye = newEye
                  target = newTarget
                  camera = camera.set(eye, target, up)
                  Once more to clearify what I'm after:
                  Moving along world axes is working but I want to numerically move the camera eye point and target point (the target shall just move the same amount as the eye) in the cameras sightline*(in/out),*left/right and up/down.
                  Any thoughts?
                  • AdamBA
                    AdamB
                    And how many millimeters in an inch (the native units of Sketchup) are there?
                    • jujuJ
                      juju
                      25.4mm to an inch.
                      • GaieusG
                        The "native" unit of mySketchUp is centimetre.
                          Jim
                          model = Sketchup.active_model
                          c = model.active_view.camera
                          eye = c.eye
                          up = c.up
                          target = c.target
                          xaxis = c.xaxis
                          yaxis = c.yaxis
                          zaxis = c.zaxis
                          model.entities.add_cpoint eye
                          model.entities.add_cpoint target
                          model.entities.add_text("eye", eye)
                          model.entities.add_text("target", target)
                          distance = 12
                          newEye = eye.offset(xaxis, distance)
                          model.entities.add_cpoint newEye
                          model.entities.add_text("newEye", newEye)
                          newTarget = target.offset(xaxis, distance)
                          model.entities.add_cpoint newTarget
                          model.entities.add_text("newTarget", newTarget)
                          c.set(newEye, newTarget, up)
                            RickW
                            Might I suggest AddPages as a reference script? It adds pages (scenes) orthographically (based on user-supplied x, y, and z offsets). If I understand the gist of the discussion, then AddPages has at its heart the transformation code in question.
                            RickW
                            www.smustard.com
                            • PixeroP
                              Pixero
                              Thanks all for helping! 😍
                              Now I got it working the way I want.
                              I'll be back when the script is done.
                              • PixeroP
                                Pixero
                                See this thread: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1528&p=41330#p41330
                                And once more, thanks for helping!
