    🫛 Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 432.4k Views 153 Watching
      davecoopstl
      So i'm using SketchyFFD on a surface I created with SoapSkin Bubble.
      It works, however the FFD nodes are not aligned in the group that the surface is drawn. They are created next to the surface. So when I'm editing the nodes, I can't really tell which one is relative to which part of the surface.
      Why are my nodes not aligned with my group when they are created?
      Am I doing something wrong?
      Dave.
      Why are my nodes not aligned?
        CPhillips
        Try exploding and regrouping the geometry. The FFD script wants the geometry positioned in a certain way inside the group.
        Dave.
          davecoopstl
          CP - Thanks! That worked like a charm.
          I do think it would be easier to control if the nodes were directly ON the surfaces that you are trying to deform. So you knew EXACTLY what part of the surface the node controlled.
          At least they are in a relative position, now that I've exploded and re-grouped.
          Dave.
            CPhillips
            Dave.
            The math is such that the control points need to be created exactly on a 3d grid. 😞
              CPhillips
              I posted a new version with a few minor changes.
              Update Mar 21.
              -Moved all FFD right click menu items to a sub menu.
              -Fixed a bug that forced you to have a least 2 control point in each direction. You can now have do 2D grids. IE. 1x4x3.
              -Added an option to create a NxN 2d patch. A grid with a control point at each intersection.
              Get it here:
              http://www.sketchucation.com/forums/scf/download/file.php?id=6745
              • F Offline
                Fletch
                thank you Chris! the 2D grid ability is Key!
                Fletch
                Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                  alz
                  I mis-read this at first -- I thought you were saying you made it possible to encase the model in a grid box, rather than floating points (to help visualize the distances between points).
                  Great work over all! I'd love to see SU incorporate this as a scale tool (lattice) option.
                  --alz
                  • G Offline
                    GreenToaster
                    BEAUTIFUL!!! THANK YOU!!! 😍
                    If you really want something you won't ever stop pursuing it.
                    • K Offline
                      kwistenbiebel
                      I am having trouble with the new FFD.
                      I made a so called 'TIN', made a 4,4,4 FFD out of it and wanted to let the surface curve upwards so I selected the points of the short outer edge and moved them up.
                      The FFD result however is a mesh soup.... 😞
                      before:
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/ffdbefore.jpg
                      after:
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/ffd-after.jpg
                      • G Offline
                        GreenToaster
                        Hey, that's very cool . . .
                          remus
                          Looks kinda like a tornado to me.not quite what you were aiming for? 😛
                            CPhillips
                            Hrmmm. Not sure why that would fail. Could you post the model?
                            Also. Try a 4,4,1 FFD for that mesh.
                            before:
                            after:
                              Jorgensen
                              How does the "make Patch" work ?
                              When I use the default setting a get a mesh that is 762mm x 762mm. What do I do when I want it to be 20000mm x 20000mm ?
                              sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
                                CPhillips
                                Its number of cells in either direction and the width and height for each cell. I figured it would use whatever units were set but it doesn't sound like that is the case. Its probably in inches.
                                  justry
                                  I just wanted to say that your script is greaaaaaaaat Chris! Really! I was actually looking for something like this.
                                  I was messing around trying to model an airplane, and I was trying to make the front end of the body wider, but I couldn't do it with the sketchup scale tool. I kept googling for "sketchup distort tool plugin" with no success, till I remembered coming across this thread before, so I looked for it, downloaded the script, and it WORKS LIKE A CHARM! Really great!
                                  They should really be adding this to the functionality of the scale tool in sketchup 7. Like with a modifier key or something. You know, something like: "Alt to distort" or something like that.
                                    CPhillips
                                    Thanks Justry!
                                    Could you post a picture of your plane?
                                    Chris
                                      justry
                                      Well, it's still not finished, but if it looks good when I'm done (hopefully!) I'll post it!
                                        justry
                                        Well, here it is. Nothing fancy, I'm not that great a modeler 💚 .
                                        Another picture:
                                        Tweaking the body would have been a lot of work. Your script makes it a breeze!
                                          svetik
                                          HI! does it work for SU 5?
                                            CPhillips
                                            It might. I don't have SU5 so I cant test. But I don't think I use any SU6 features.
                                            • 6
                                            • 7
                                            • 20
                                            • 21
                                            • 5 / 21
