    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 11.7k Views 20 Watching
    • W Offline
      Whaat
      @kwistenbiebel said:
      I didn't use SSS on the leaves.
      In the Indigo render they are plain diffuse (the Fry versions has specularity assigned).
      I'll try the SSS feature later on, but I think render time will suffer from it.
      Dammit! I can't see your renders at my office computer. They are blocked!
      Here's something to try with vegetation in Indigo. Use a Phong material with SketchUp opacity at 35-50%. This blends the phong material with a diffuse transmitter material giving you a SSS effect without the huge render time. Changing the opacity slider will determine the relative amount of blending. The end result is a translucent material with specular highlights, perfect for leaves.
      • StinkieS Offline
        Stinkie
        Very nice! 👍
        • W Offline
          Whaat
          Beautiful render! Thanks for attaching!
            kwistenbiebel
            Thank you 😄
            A try out using Vray. Unfortunately VfSU does not support instancing/proxies so I had to delete a lot of the 3D vegetation for this one to avoid crashes:
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/vizdepot-2-smallest.jpg
            • AnssiA Offline
              Anssi
              I am again amazed about how consistent quality you get out of different render engines.
              Anssi
              • marked001M Offline
                marked001
                love the camera angle on those indigo images! where is this vegetation from?? i need to buy some..
                btw, i'm using the a pre-release version of the new maxwell sketchup plugin that includes instancing and its working great so far 👍 i just need to look into using dummy components now..
                http://www.revision21vis.com
                instagram: revi21on
                • StinkieS Offline
                  Stinkie
                  I pm'ed Pelias earlier today to get my hands on this baby. How's workflow?
                  Er, sorry for this, Kwisten. Bit of a hijack. 😳 Excellent image again - Asgvis should take a look at instancing.
                    DzineTech
                    They now have the ability to add proxies since Chaos Group updated the Vray SDK but they haven't worked out just how they are going to implement as yet; they seem to having a lot of difficulties coping with the way SU deals with a lot of other things at the moment (geometry, texture mapping etc..) but it looks like a great feature to get.
                      kwistenbiebel
                      Thanks for the nice comments guys.
                      @Marked:The vegetation I use comes from different sources (3d warehouse, evermotion, Xfrog).
                      Some of those models need poly shrinking (even when using instancing).
                      @Stinkie: no problem 😉. I hope instancing for Maxwell will work as it should. Sometimes I have the feeling that the development of the Maxwell plugin somewhat limbs behind...
                      @Dzinetech: I agree, instancing should be on the to do list for VfSU asap.
                      A little night shot update on the Indigo scene.
                      The pavement needs some work ...
                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/nachtview-indigo-small.jpg
                      • StinkieS Offline
                        Stinkie
                        There's some weird experimenting going on in that house, by the looks of them lights. Other than that: 👍
                        Like the reflections on the cobble stones (that the right word?). 👍
                        • soloS Offline
                          looks amazing, I love the specular reflections on the paving stones. I assume you used LEM lighting on window surfaces for lighting right?
                            kwistenbiebel
                            Thanks Stinkie and Solo.
                            Indeed I used a light emitting material for those windows.
                            Actually, for most unbiased engines, this is the only way to 'model' light (besides sun).
                            • StinkieS Offline
                              Stinkie
                              Hence the 'hideout of the mad professor look'. 💚
                                kwistenbiebel
                                Doggy style 😆 (Skindigo):
                                http://i140.photobucket.com/albums/r3/kwistenbiebel1/doggy-1-small.jpg
                                  rangerrick
                                  kwistenbiebel, I find all of your imagery to be outstanding! Very impressive and inspirational. Thanks for your posts.
                                    kwistenbiebel
                                    Thanks for the tip Whaat.
                                    I'll attach the next images internally so they don't get blocked by your browser:
                                    http://i140.photobucket.com/albums/r3/kwistenbiebel1/Charette-Vizdepot-indigo-smalli.jpg
                                      kwistenbiebel
                                      Thanks rangerrick,
                                      Here's the clay version:
                                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/dog-clay-small1.jpg
                                        kwistenbiebel
                                        👊 ....his failed science project turning against him, making its way towards the entrance:
                                        http://i140.photobucket.com/albums/r3/kwistenbiebel1/haunted.jpg
                                        • StinkieS Offline
                                          Stinkie
                                          lol Looks cool. 👍
                                            kwistenbiebel
                                            A quadzillion polygons. 😄
                                            All parts of the image are 3D .
                                            Didiers 'component spray tool' + Skindigo:
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/tripod-topviewkleiner.jpg
                                            • 2 / 4
