    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 12.7k Views 20 Watching
    • FrederikF Offline
      Frederik
      http://www.kerkythea.net//users/Frederik/Anim-Icons/applause.gif
      Really impressive, Kwistenbiebel...
      http://www.kerkythea.net//users/Frederik/Anim-Icons/clap-above.gif
      Could fool many to believe this was a real photo... 😉
      Cheers
      Kim Frederik
        pibuz
        Hi master Kwisten 😄
        REALLY impressive images! I assume you've done an export from Sketch to fry, before the render: am i right?
        If so, i'd be very very very interested in how did you map the foliage on the plants and bushes. And I'd very like to know where the rose-bush component comes from...
        I've tried converting to ".3ds" some 3D trees i found for 3dsMax, but mapping every single leaf it's an endless work to do: how can you do that? If i can ask, obviously: this can be a little secret to keep, i'd understand you 😉
        Thank you so much, however!
        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
          kwistenbiebel
          Thanks.
          @Pibuz,
          Actually hitting 'render' in Fry exports the scene and automatically starts the rendering in the Fry standalone. But you can also choose 'export only' and start the rendering later on.
          In this case, because of the use of proxies, the export time was really short as the amount of geometry was kept low.
          I didn't model the vegetation myself, some are commercial and came with textures applied.
            kwistenbiebel
            Indigo instancing.
            The house model from Vizdepot (new Charette).
            3D vegetation added and instanced.
            http://i140.photobucket.com/albums/r3/kwistenbiebel1/outdoor-indigo-instancing.jpg
            • I Offline
              ilay7k
              no way 😲 ...
              i trick us, it's foto! 👍
              Ono and Whaat make new camera driver 😄
              • soloS Offline
                Dang!!
                Sweeeet!
                How the heck are we supposed to keep up with all the new features, i am still trying to master the old ones, if one has to try stay abreast with all the new developements the term 'starving artist' surely would be reality.
                Excellent visual there Chris.
                • I Offline
                  ilay7k
                  Chris, one question...have you try to add SSS-feature for leaves(in front of view, elight some dark sites) or postwork made grafik.editor?
                  i know it's slow...but...
                  • StinkieS Offline
                    Stinkie
                    Nice image. Indigo's good stuff.
                      kwistenbiebel
                      Thanks Ilay7k and Solo 😄
                      @Solo,
                      I think instancing and displacement are two of the newer features that can boost a render a lot. (displacement not available in Indigo yet)
                      By the way, I am amazed with the things you pull off with Vue extreme, a technology I personally know zip about.
                      @Ilay,
                      I didn't use SSS on the leaves.
                      In the Indigo render they are plain diffuse (the Fry versions has specularity assigned).
                      I'll try the SSS feature later on, but I think render time will suffer from it.
                      Thanks for your comments,
                      Kwistenbiebel
                      • FrederikF Offline
                        Frederik
                        What can I say...?!?
                        Looks top dollar... 👍 😉
                        Cheers
                        Kim Frederik
                          kwistenbiebel
                          Thanks Stinkie and Frederick.
                          I launched another view (Skindigo) and let it render the length of a game of squash 😉
                          The roses seem to be slightly oversaturated. Not sure about the rotated view either:
                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/charette2-indigo.jpg
                          • W Offline
                            Whaat
                            Dammit! I can't see your renders at my office computer. They are blocked!
                            Here's something to try with vegetation in Indigo. Use a Phong material with SketchUp opacity at 35-50%. This blends the phong material with a diffuse transmitter material giving you a SSS effect without the huge render time. Changing the opacity slider will determine the relative amount of blending. The end result is a translucent material with specular highlights, perfect for leaves.
                            • StinkieS Offline
                              Stinkie
                              Very nice! 👍
                              • W Offline
                                Whaat
                                Beautiful render! Thanks for attaching!
                                  kwistenbiebel
                                  Thank you 😄
                                  A try out using Vray. Unfortunately VfSU does not support instancing/proxies so I had to delete a lot of the 3D vegetation for this one to avoid crashes:
                                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/vizdepot-2-smallest.jpg
                                  • AnssiA Offline
                                    Anssi
                                    I am again amazed about how consistent quality you get out of different render engines.
                                    Anssi
                                    • marked001M Offline
                                      marked001
                                      love the camera angle on those indigo images! where is this vegetation from?? i need to buy some..
                                      btw, i'm using the a pre-release version of the new maxwell sketchup plugin that includes instancing and its working great so far 👍 i just need to look into using dummy components now..
                                      http://www.revision21vis.com
                                      instagram: revi21on
                                      • StinkieS Offline
                                        Stinkie
                                        I pm'ed Pelias earlier today to get my hands on this baby. How's workflow?
                                        Er, sorry for this, Kwisten. Bit of a hijack. 😳 Excellent image again - Asgvis should take a look at instancing.
                                          DzineTech
                                          They now have the ability to add proxies since Chaos Group updated the Vray SDK but they haven't worked out just how they are going to implement as yet; they seem to having a lot of difficulties coping with the way SU deals with a lot of other things at the moment (geometry, texture mapping etc..) but it looks like a great feature to get.
                                            kwistenbiebel
                                            Thanks for the nice comments guys.
                                            @Marked:The vegetation I use comes from different sources (3d warehouse, evermotion, Xfrog).
                                            Some of those models need poly shrinking (even when using instancing).
                                            @Stinkie: no problem 😉. I hope instancing for Maxwell will work as it should. Sometimes I have the feeling that the development of the Maxwell plugin somewhat limbs behind...
                                            @Dzinetech: I agree, instancing should be on the to do list for VfSU asap.
                                            A little night shot update on the Indigo scene.
                                            The pavement needs some work ...
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/nachtview-indigo-small.jpg
                                            • 2 / 4
