    Using 'instancing/proxies' is fun
    74 Posts 20 Posters 14.3k Views 20 Watching
      kwistenbiebel
      Thanks Ilay7k and Solo 😄
      @Solo,
      I think instancing and displacement are two of the newer features that can boost a render a lot. (displacement not available in Indigo yet)
      By the way, I am amazed with the things you pull off with Vue extreme, a technology I personally know zip about.
      @Ilay,
      I didn't use SSS on the leaves.
      In the Indigo render they are plain diffuse (the Fry versions has specularity assigned).
      I'll try the SSS feature later on, but I think render time will suffer from it.
      Thanks for your comments,
      Kwistenbiebel
      • FrederikF Offline
        Frederik
        What can I say...?!?
        Looks top dollar... 👍 😉
        Cheers
        Kim Frederik
          kwistenbiebel
          Thanks Stinkie and Frederick.
          I launched another view (Skindigo) and let it render the length of a game of squash 😉
          The roses seem to be slightly oversaturated. Not sure about the rotated view either:
          http://i140.photobucket.com/albums/r3/kwistenbiebel1/charette2-indigo.jpg
          • W Offline
            Whaat
            Dammit! I can't see your renders at my office computer. They are blocked!
            Here's something to try with vegetation in Indigo. Use a Phong material with SketchUp opacity at 35-50%. This blends the phong material with a diffuse transmitter material giving you a SSS effect without the huge render time. Changing the opacity slider will determine the relative amount of blending. The end result is a translucent material with specular highlights, perfect for leaves.
            • StinkieS Offline
              Stinkie
              Very nice! 👍
              • W Offline
                Whaat
                Beautiful render! Thanks for attaching!
                  kwistenbiebel
                  Thank you 😄
                  A try out using Vray. Unfortunately VfSU does not support instancing/proxies so I had to delete a lot of the 3D vegetation for this one to avoid crashes:
                  http://i140.photobucket.com/albums/r3/kwistenbiebel1/vizdepot-2-smallest.jpg
                  • AnssiA Offline
                    Anssi
                    I am again amazed about how consistent quality you get out of different render engines.
                    Anssi
                    • marked001M Offline
                      marked001
                      love the camera angle on those indigo images! where is this vegetation from?? i need to buy some..
                      btw, i'm using the a pre-release version of the new maxwell sketchup plugin that includes instancing and its working great so far 👍 i just need to look into using dummy components now..
                      http://www.revision21vis.com
                      instagram: revi21on
                      • StinkieS Offline
                        Stinkie
                        I pm'ed Pelias earlier today to get my hands on this baby. How's workflow?
                        Er, sorry for this, Kwisten. Bit of a hijack. 😳 Excellent image again - Asgvis should take a look at instancing.
                          DzineTech
                          They now have the ability to add proxies since Chaos Group updated the Vray SDK but they haven't worked out just how they are going to implement as yet; they seem to having a lot of difficulties coping with the way SU deals with a lot of other things at the moment (geometry, texture mapping etc..) but it looks like a great feature to get.
                            kwistenbiebel
                            Thanks for the nice comments guys.
                            @Marked:The vegetation I use comes from different sources (3d warehouse, evermotion, Xfrog).
                            Some of those models need poly shrinking (even when using instancing).
                            @Stinkie: no problem 😉. I hope instancing for Maxwell will work as it should. Sometimes I have the feeling that the development of the Maxwell plugin somewhat limbs behind...
                            @Dzinetech: I agree, instancing should be on the to do list for VfSU asap.
                            A little night shot update on the Indigo scene.
                            The pavement needs some work ...
                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/nachtview-indigo-small.jpg
                            • StinkieS Offline
                              Stinkie
                              There's some weird experimenting going on in that house, by the looks of them lights. Other than that: 👍
                              Like the reflections on the cobble stones (that the right word?). 👍
                              • soloS Offline
                                looks amazing, I love the specular reflections on the paving stones. I assume you used LEM lighting on window surfaces for lighting right?
                                  kwistenbiebel
                                  Thanks Stinkie and Solo.
                                  Indeed I used a light emitting material for those windows.
                                  Actually, for most unbiased engines, this is the only way to 'model' light (besides sun).
                                  • StinkieS Offline
                                    Stinkie
                                    Hence the 'hideout of the mad professor look'. 💚
                                      kwistenbiebel
                                      Doggy style 😆 (Skindigo):
                                      http://i140.photobucket.com/albums/r3/kwistenbiebel1/doggy-1-small.jpg
                                        rangerrick
                                        kwistenbiebel, I find all of your imagery to be outstanding! Very impressive and inspirational. Thanks for your posts.
                                          kwistenbiebel
                                          Thanks for the tip Whaat.
                                          I'll attach the next images internally so they don't get blocked by your browser:
                                          http://i140.photobucket.com/albums/r3/kwistenbiebel1/Charette-Vizdepot-indigo-smalli.jpg
                                            kwistenbiebel
                                            Thanks rangerrick,
                                            Here's the clay version:
                                            http://i140.photobucket.com/albums/r3/kwistenbiebel1/dog-clay-small1.jpg
                                            • 2 / 4
