    Some help please
    26 Posts 10 Posters 4.4k Views 10 Watching
    • jeff hammondJ
      i don't have time for a tut right now but i can show you how i did it later.. in the mean time, it looks like a lot of people are into trying this shape so maybe someone else can do it..
      for now, here's the skp of my version..
      ring.skp
      • jeff hammondJ
        ok, so i figured out how to draw it more to my liking but doing a tutorial for this thing might be a little bit much.. it would be about 25 scenes with weird to describe curve manipulations in there.. if someone really wants to see a step-by-step, i'll do it but i'm going to hold off for now.. it will probably take ~2hrs to put together..
        it's sort of similar to TIG's method except i used two circles to begin with instead of one (one inside of the other).. i then alternate between the two circles which allows for the weaving..
        here's the fixed version skp..
        ring2.skp
          With our combined IQ well in excess of 'genius' we have got some great ideas here.
          • Alan FraserA
            Alan Fraser
            I haven't had time to go through all of these, but it seems that you might also be able to do it by producing a ring of braid that is only skin-thick, then using Vector PP on it. Did anyone try it that way?
            3D Figures
            • EdsonE
              Edson
              eric,
              why step 8 (intersect with model)?
              http://www.mahfuz.arq.br
              • EdsonE
                Edson
                @tig said:
                Here's a Tutorial on doing it one way...
                TIG,
                great tut. could you tell me what happened from step 8 to 9? the circles are smoother and the proportions are different.
                  alpro
                  This is why I love this forum, so many people willing to share their time and expertise, that just doesn't happen on any other forum, this is definitely a community. This is also why I love SU, so many ways to get the end result.
                  Mike
                    @edson said:
                    TIG,
                    If you read the notes on page 8 you'll see that I based the steps on 8 sides with no scaling to make ellipses. Then I just re-did one on page 9 with 16 sides and scaled a bit flatter. I didn't show the steps as it would have taken too long... It's quick to do, but slow to de-construct into a tutorial step sheet...
                    • G
                      GreyHead
                      Here's a version done with Alan's suggestion for Vector PP. The model looks good.
                      Bob
                      • boofredlayB
                        boofredlay
                        @edson said:
                        eric,
                        Because if you do not then the points where the components intersect each other will be visible.
                        I tried the vector push pull but got some odd results. Maybe because my curves had a large number of segments.
                        • 2 / 2
