    Indigo'ing
    14 Posts 12 Posters 2.0k Views 12 Watching
    • majidM Offline
      majid
      put a layer over your first layer ,change the blending to lighten or screen . put ponit like triangle over the candles ( whit a light color like light yellow ) , use the gussian blur filter , change the opacity as needed .
      • marked001M Offline
        marked001
        the light coming through the windows is amazing!
        http://www.revision21vis.com
        instagram: revi21on
          kwistenbiebel
          Wow Irsuser ๐Ÿ˜ฒ ,
          This is really photographic ! amazing render.
          Very curious how many weeks this render cooked...
          • majidM Offline
            majid
            hi all! have you ever tried indigo? interesting and as i remember the last version of SKINDIGO has a clear panel ... but doesnt support RGBlight materials... u must use previous versions (but u can use last indigo renderer version)
              sketchy
              what a fantastic render! I am very impressed. Your clients must go nuts when they see it.
              • PixeroP Offline
                Pixero
                Here's a quickie in PS.
                  tomsdesk
                  WOW!
                  (and then speechless)
                  2.5D Trees & Shrubs!
                  • PixeroP Offline
                    Pixero
                    Looking good.
                    Any tips how to 'light up' those chandeliers in PS?
                    Here's a tip for you: In PS create a new layer at the top and fill it with black.
                    Set blend mode to Color dodge.
                    Choose a soft brush and set Opacity and flow to something low like 25.
                    Select a color, white or preferably a orange-yellow and paint away your lights!
                    The more you paint the more light.
                    • W Offline
                      Whaat
                      I will also add my ๐Ÿ‘ to this render. ๐Ÿ˜ฒ Definitely one of the best SU->Indigo renders I've seen. Awesome!
                        lrsuser
                        WOW!! Thanks for showing enthusiasm guys!! Very much appreciate the tips as well.
                        Pixero: that is exactly what I am looking for.
                        It took about 60 hrs to render at 2000x1200 before I was ok with 'noise' levels... ๐Ÿ˜ž
                        This project is on the back burner, so I'll be able to get back to it later this week
                        All window glass was set as exit portal. Environment is sun and sky
                        Outside image was added/adjusted in PS
                        and then finally slight adjustment using curves (actually a biebel trick if I can recollect properly)... ๐Ÿ˜„
                        ~e
                        • H Offline
                          huyvuvn
                          great !
                          but how long it takes you render that scene ? I heard that Indigo (and Maxwell) is very SLOW
                          happiness on the way, not in the destination.
