    Indigo'ing
    14 Posts 12 Posters 1.9k Views 12 Watching
      lrsuser
      Its been a while I rendered...๐Ÿ˜„
      Dining room for a senior housing project in Colorado.
      C&C welcome.
      Any tips how to 'light up' those chandeliers in PS?
      I might want to show 'sparkle' shining from those horn lanterns.
      • soloS Offline
        Awesome looking render, pretty detailed looking too.
        Looks like you used an instancing tool for all those tables, which gives a very nice full look.
        The chandeliers look very Viking.
        Great job and fantastic lighting.
          Jon
          Woah ๐Ÿ˜ฒ
          This isn't a photo!? Amazing!!! ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฎ
          Jon
          KT Team member
          • majidM Online
            majid
            put a layer over your first layer ,change the blending to lighten or screen . put ponit like triangle over the candles ( whit a light color like light yellow ) , use the gussian blur filter , change the opacity as needed .
            • marked001M Offline
              marked001
              the light coming through the windows is amazing!
              http://www.revision21vis.com
              instagram: revi21on
                kwistenbiebel
                Wow Irsuser ๐Ÿ˜ฒ ,
                This is really photographic ! amazing render.
                Very curious how many weeks this render cooked...
                • majidM Online
                  majid
                  hi all! have you ever tried indigo? interesting and as i remember the last version of SKINDIGO has a clear panel ... but doesnt support RGBlight materials... u must use previous versions (but u can use last indigo renderer version)
                    sketchy
                    what a fantastic render! I am very impressed. Your clients must go nuts when they see it.
                    • PixeroP Offline
                      Pixero
                      Here's a quickie in PS.
                        tomsdesk
                        WOW!
                        (and then speechless)
                        2.5D Trees & Shrubs!
                        • PixeroP Offline
                          Pixero
                          Looking good.
                          Here's a tip for you: In PS create a new layer at the top and fill it with black.
                          Set blend mode to Color dodge.
                          Choose a soft brush and set Opacity and flow to something low like 25.
                          Select a color, white or preferably a orange-yellow and paint away your lights!
                          The more you paint the more light.
                          • W Offline
                            Whaat
                            I will also add my ๐Ÿ‘ to this render. ๐Ÿ˜ฒ Definitely one of the best SU->Indigo renders I've seen. Awesome!
                              lrsuser
                              WOW!! Thanks for showing enthusiasm guys!! Very much appreciate the tips as well.
                              Pixero: that is exactly what I am looking for.
                              It took about 60 hrs to render at 2000x1200 before I was ok with 'noise' levels... ๐Ÿ˜ž
                              This project is on the back burner, so I'll be able to get back to it later this week
                              All window glass was set as exit portal. Environment is sun and sky
                              Outside image was added/adjusted in PS
                              and then finally slight adjustment using curves (actually a biebel trick if I can recollect properly)... ๐Ÿ˜„
                              ~e
                              • H Offline
                                huyvuvn
                                great !
                                but how long it takes you render that scene ? I heard that Indigo (and Maxwell) is very SLOW
                                happiness on the way, not in the destination.
