    Indigo'ing
    14 Posts 12 Posters 2.1k Views 12 Watching
    • marked001M
      marked001
      the light coming through the windows is amazing!
      http://www.revision21vis.com
      instagram: revi21on
      • K
        kwistenbiebel
        Wow Irsuser ๐Ÿ˜ฒ ,
        This is really photographic ! amazing render.
        Very curious how many weeks this render cooked...
        • majidM
          majid
          hi all! have you ever tried indigo? interesting and as i remember the last version of SKINDIGO has a clear panel ... but doesnt support RGBlight materials... u must use previous versions (but u can use last indigo renderer version)
            sketchy
            what a fantastic render! I am very impressed. Your clients must go nuts when they see it.
            • PixeroP
              Pixero
              Here's a quickie in PS.
              • T
                tomsdesk
                WOW!
                (and then speechless)
                2.5D Trees & Shrubs!
                • PixeroP
                  Pixero
                  Looking good.
                  Any tips how to 'light up' those chandeliers in PS?
                  Here's a tip for you: In PS create a new layer at the top and fill it with black.
                  Set blend mode to Color dodge.
                  Choose a soft brush and set Opacity and flow to something low like 25.
                  Select a color, white or preferably a orange-yellow and paint away your lights!
                  The more you paint the more light.
                  • W
                    Whaat
                    I will also add my ๐Ÿ‘ to this render. ๐Ÿ˜ฒ Definitely one of the best SU->Indigo renders I've seen. Awesome!
                    • L
                      lrsuser
                      WOW!! Thanks for showing enthusiasm guys!! Very much appreciate the tips as well.
                      Pixero: that is exactly what I am looking for.
                      It took about 60 hrs to render at 2000x1200 before I was ok with 'noise' levels... ๐Ÿ˜ž
                      This project is on the back burner, so I'll be able to get back to it later this week
                      All window glass was set as exit portal. Environment is sun and sky
                      Outside image was added/adjusted in PS
                      and then finally slight adjustment using curves (actually a biebel trick if I can recollect properly)... ๐Ÿ˜„
                      ~e
                      • H
                        huyvuvn
                        great !
                        but how long it takes you render that scene ? I heard that Indigo (and Maxwell) is very SLOW
                        happiness on the way, not in the destination.
