    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 548.5k Views 153 Watching
    • jujuJ
      juju
      I'd take "really really slow" over "no such function at all" any day.
      • PixeroP
        Pixero
        I think its pretty clear what he means.
        He much rather have a slow tool that does what he wants then not having that tool at all.
        • C
          CPhillips
          The example in the pic takes a few seconds to deform.
          So do the points placed actually have different coordinates assigned to them? That's what I was asking in my previous post. I find it kinda hard to explain, I hope you know what I mean.
          Yes they do. Each construction point has its original position stored in an attribute. Thats how I know how far the point moved. But that is only 1/2 the equation. You also need the pre-calculated weight. That is what is missing when you copy a control point. Its that quick because it doesn't have all the calculated weights to process.
          If you want to try it with more control points do this:
          -Select the group you want to deform.
          -Open the ruby console and enter the following line:
          startFFD(Sketchup.active_model.selection[0],7.0)
          That will create a 8x8 control grid (8-1=7.0). Delete the points you don't intend to move to make it a bit faster.
          ffd9x9.skp
          • C
            CPhillips
            I made a new version that has a NxN FFD. That means you can select how many control points there are in each direction. It isn't as slow as I expected.
            Here is a 12x12x2. I am playing back my undo buffer so it looks faster than it is.
            Ill post it once I fix a bug or two.
            Just when I thought I was out they pull me back in.
            • jujuJ
              juju
              Juju, I find your replies are often cryptic. What's the bottom line?
              Exactly! Thanks for clearing that up for me.
              • FletchF
                Fletch
                Can't wait to play with this, Chris, thank you from the bottom of my heart... been wishing for this for a loooong time.
                Fletch
                • C
                  CPhillips
                  This version supports NxN deforms. But more importantly it updates the mesh automatically when you move control points. That makes it a lot more usable.
                  Also added status text progress when it is weighing and deforming the mesh.
                  Making a curling wave with a 13x13x2 FFD.
                  See the PluginStore for the download...
                    remus
                    cheers for the update chris, this will make an already powerful tool all the better.
                      Daniel S
                      Thank you Chris!!! ๐Ÿ˜ ๐Ÿ˜ ๐Ÿ˜
                      The Update FFD is obsolete now ๐Ÿ˜„
                      Daniel S
                        remus
                        here a quick (30 mins or so) pear i knowcked up, partly using FFD.
                        pear.skp
                        • N
                          notareal
                          ๐Ÿ‘ Impressive, organic modelling did take a grand leap! Just if there where nice tool for subdivision surface... pokes Whaat
                          • K
                            krash88
                            Great job! The auto update is very nice. But I have one problem... If I create a flat piece of geometry similar to your wave demo, then strange things happen. After moving a control point the geometry disappears and the camera goes nuts. It sticks me in an over-head view, miles away from the control points. After a zoom extents I can tell that the geometry is still there and is selectable, but not visible. Turning on hidden geometry doesn't help and any attempt to zoom in or out puts me back over-head at a great distance from the points. It seems to work great on geometry with thickness. Any help is appreciated and thanks again for the wonderful script!
                            Edit:
                            After looking back at your wave demo, I noticed that you have a vertical edge at one corner of the mesh to give it thickness and I assume that you have deleted the control points from the bottom also. I tried this and it works just fine. So thanks again for the script!
                            • ely862meE
                              ely862me
                              this is awsome for cars,until finding this i had on my car square from now i won t have any square,just litle mouvement with mouse and all is fine,,,,thank u very much
                              Elisei (sketchupper)
                              Come and See EliseiDesign
                                Daniel S
                                Here i attach a video using FFD like a twist tool...
                                it would be easy to make this automatic with ruby?
                                i mean.. to set the center of rotation (like in TIGยดs Grow.rb) and the rotation angle.
                                Daniel S
                                FFD Twist Video.zip
                                  Ampa
                                  Wow! This has now officially crossed the line from 'pretty darned impressive' to "stunning".
                                  Thank you for sharing this with the community.
                                  Ampa
                                  • K
                                    kwistenbiebel
                                    Awesome guys !!!!!REALLY ๐Ÿ˜ฒ ๐Ÿ˜ฒ ๐Ÿ˜ฒ
                                    This together with Whaats 'polycount controller' (= subdivide and smooth plugin) is simply great stuff. So we can finally do some organics in SU ? ๐Ÿ˜ ๐Ÿ˜Ž
                                    • W
                                      Whaat
                                      Looks amazing! ๐Ÿ‘
                                      Great job!
                                      • K
                                        krash88
                                        I just wanted to post something to show how this has helped to add life to my renderings. Thanks again!
                                        • K
                                          kwistenbiebel
                                          That's really cool Krash88.
                                          The only little remark I have with current plugin (besides saying it is awesome ๐Ÿ˜„), is that after some manipulation, it starts to become difficult to see which points to move.
                                          It would be great if the control points would stick more to the geometry...I am not sure if my explanation is clear.
                                          Another thing is, I noticed that the outer limits of geometry gets changed by the plugin, even though only points were selected in the middle (no points located at the boundaries of an object). I experienced this issue as well while using the 'sandbox tool' in SU.
                                          • K
                                            krash88
                                            I think every vertex in a piece of geometry holds some weight with every control point. Maybe adding an option for fall-off would help a little with both of your issues. It may be asking too much, but an option for "freezing" certain edges could help so that the weight calculations won't affect them(for your edge problem). Maybe creating a sub-group that doesn't include the edges you want to remain in place and then only deforming the rest of the geometry will solve the problem as well. I'll try that out later.
                                            • 20
                                            • 21
                                            • 2 / 21
