    [Plugin] SketchyFFD (Classic)
    412 Posts 153 Posters 539.8k Views 153 Watching
    • FletchF
      Fletch
      Can't wait to play with this, Chris, thank you from the bottom of my heart... been wishing for this for a loooong time.
      Fletch
      • C
        CPhillips
        This version supports NxN deforms. But more importantly it updates the mesh automatically when you move control points. That makes it a lot more usable.
        Also added status text progress when it is weighing and deforming the mesh.
        Making a curling wave with a 13x13x2 FFD.
        See the PluginStore for the download...
          remus
          cheers for the update chris, this will make an already powerful tool all the better.
            Daniel S
            Thank you Chris!!! 😍 😍 😍
            The Update FFD is obsolete now 😄
            Daniel S
              remus
              here a quick (30 mins or so) pear i knowcked up, partly using FFD.
              pear.skp
              • N
                notareal
                👍 Impressive, organic modelling did take a grand leap! Just if there where nice tool for subdivision surface... pokes Whaat
                • K
                  krash88
                  Great job! The auto update is very nice. But I have one problem... If I create a flat piece of geometry similar to your wave demo, then strange things happen. After moving a control point the geometry disappears and the camera goes nuts. It sticks me in an over-head view, miles away from the control points. After a zoom extents I can tell that the geometry is still there and is selectable, but not visible. Turning on hidden geometry doesn't help and any attempt to zoom in or out puts me back over-head at a great distance from the points. It seems to work great on geometry with thickness. Any help is appreciated and thanks again for the wonderful script!
                  Edit:
                  After looking back at your wave demo, I noticed that you have a vertical edge at one corner of the mesh to give it thickness and I assume that you have deleted the control points from the bottom also. I tried this and it works just fine. So thanks again for the script!
                  • ely862meE
                    ely862me
                    this is awsome for cars,until finding this i had on my car square from now i won t have any square,just litle mouvement with mouse and all is fine,,,,thank u very much
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                      Daniel S
                      Here i attach a video using FFD like a twist tool...
                      it would be easy to make this automatic with ruby?
                      i mean.. to set the center of rotation (like in TIG´s Grow.rb) and the rotation angle.
                      Daniel S
                      FFD Twist Video.zip
                        Ampa
                        Wow! This has now officially crossed the line from 'pretty darned impressive' to "stunning".
                        Thank you for sharing this with the community.
                        Ampa
                        • K
                          kwistenbiebel
                          Awesome guys !!!!!REALLY 😲 😲 😲
                          This together with Whaats 'polycount controller' (= subdivide and smooth plugin) is simply great stuff. So we can finally do some organics in SU ? 😍 😎
                          • W
                            Whaat
                            Looks amazing! 👍
                            Great job!
                            • K
                              krash88
                              I just wanted to post something to show how this has helped to add life to my renderings. Thanks again!
                              • K
                                kwistenbiebel
                                That's really cool Krash88.
                                The only little remark I have with current plugin (besides saying it is awesome 😄), is that after some manipulation, it starts to become difficult to see which points to move.
                                It would be great if the control points would stick more to the geometry...I am not sure if my explanation is clear.
                                Another thing is, I noticed that the outer limits of geometry gets changed by the plugin, even though only points were selected in the middle (no points located at the boundaries of an object). I experienced this issue as well while using the 'sandbox tool' in SU.
                                • K
                                  krash88
                                  I think every vertex in a piece of geometry holds some weight with every control point. Maybe adding an option for fall-off would help a little with both of your issues. It may be asking too much, but an option for "freezing" certain edges could help so that the weight calculations won't affect them(for your edge problem). Maybe creating a sub-group that doesn't include the edges you want to remain in place and then only deforming the rest of the geometry will solve the problem as well. I'll try that out later.
                                  • C
                                    CPhillips
                                    Daniel S
                                    Possible. But a fair amount of work. I'll look into it when I can spend more time on it.
                                    • C
                                      CPhillips
                                      Edit:
                                      You got it! FFD objects need to have at least some depth when you first start. But after that it is safe to delete unwanted geometry and control points.
                                      Thanks for all the positive comments everyone. 😄
                                      • C
                                        CPhillips
                                        The points need to be where they are. It was possible in the previous version to move the control point grid object away from the mesh you are deforming. That makes it a little easier. I think it is broke in this version but I will see if I can fix it.
                                        Not sure what you mean here. Maybe post and example?
                                        • Mike LuceyM
                                          Mike Lucey
                                          Wow!!!! Chris, I had not been keeping on eye on this thread of late but have just finished reading all. This is a fantastic tool for SketchUp. Thank you very much for all your hard work.
                                          Mike
                                          • G
                                            Gjenio
                                            Congratulation Chris, great work. It's an amazing tool. I hope sketchup developers would look at your script for the new realise of the software.
                                            We all appreciate your sweat
                                            • 20
                                            • 21
                                            • 2 / 21
