    Curved wall w/ variable height
    22 Posts 8 Posters 3.8k Views 8 Watching
    • Wo3DanW Offline
      Wo3Dan
      Paul,
      About the twist when applying ‘Follow Me’ in NOT-coplanar curves I knew.
      Also about the handmade stitching method. It’s the ‘out of plumb’ result of Bob Janes solution that I was pointing out and that could lead to (serious) problems when just depending on the accuracy of the construction. The top isn’t that important.
      (I couldn’t believe my eyes seeing such a simple method for a curved ramp-like wall construction)
      cheers,
      Wo3Dan
        GreyHead
        There are some interesting things going on here - and mostly they follow from some gaps in the specification, what the designer didn't specify on the plan. Those have to be filled in somehow which means that some assumptions have to be made.
        The intersection method assumes that the degree of slope is uniform along the projection of the wall, not the length of the wall itself. In the case of jfmalone's wall that isn't going to make much difference, with my example with the sharper turn it will. In effect the end of the wall, which is in the green direction will have little or no slope.
        My method leaves the decision to the internal workings of SketchUp and I have no real idea how it deals with that. But it does keep the curve more or less uniform along the length of the wall.
        the top cross section line is slanted but here the wall is getting ‘out of plumb’
        I hadn't noticed that, both end of the wall top are exactly at 90 degrees, but, as you say, the middle of the wall is out of plumb (see below). I'm afraid I'm going to lay that off on to the SketchUp algorithm, as far as I can work out it should be possible to lower the top surface without any lateral movement.
        Neither the intersecting plan method nor follow-me will give you equal heights (90 angles at the tops of the wall).
        This is tricky, the ends of the wall do have equal height - for the space in between it depends on where you choose to measure. Because it's a curve the two sides have different lengths and there are no 'right places' to choose to have the right angles. Where they should be is a design assumption - and it looks like the SketchUp algorithm is quite a long way off ideal. Your assumption that they should be equispaced is probably a much better one.
        Bob
        • boofredlayB Offline
          boofredlay
          Here is a continuation on my tut. Sorry I did not get to it sooner.
          Yes, the top is not 90 deg and you have to manually fix it but unless you have a massively large poly count it is simple and fast.
          http://www.sketchucation.com/forums/scf/sas/ProUser/CurvedWallCut2.jpg
            jfmalone
            For what I needed, Boofredlay's system worked great and its looking good. I have some clean-up todo but here is the WIP.
              boofredlay
              Man that looks great. Glad I could help.
              • simon le bonS Offline
                simon le bon
                Dear Boofredlay, thanks for your CurvedWallCut2.skp. I have found in what i was searching for. In re-doing your tut, in Scene3, you've Pushpulled the shape this way:
                http://img166.imageshack.us/img166/5895/yourpushpullwallsa3.th.jpg
                But the only pushpulled figure i can obtain is this one:
                http://img166.imageshack.us/img166/3845/mypushpullwallib2.th.jpg
                Can you explain how? ,, (great thanks for your all work in this place.)
                  jfmalone
                  I forgot about this posting I did. Thanks again for all the help. Here is the finished image.
                    boofredlay
                    jfmalone, that is really nice. Thanks for giving us the final.
                    Simon, I got the same result you did when pushing that face. Then I just erased the top and side faces so you could see the face that was passing through the curved wall. Hope that helps.
                      simon le bon
                      Dear Boofredlay, at the end, after all my attempts and some thinking about, that was the conclusion i reached to.
                      Hum!, elsewhere i haven't found a real Tut on Stitching. Perhaps one day, if you have little time...
                        remus
                        heres a very quick intro to stitching.
                        stitching tut.skp
                          simon le bon
                          Dear Remus,
                          Sorry i had not saw your post. Thanks for this short, simple and clear tut on STITCHING.
                          (we can find the ruby CurveStitcher script you've talking about here on Smustard:CurveStitcher v.2.2 by Rick Wilson )
                          I just would like add this tip to do manual Stitch you can find on Boofredlay's CurvedWallCut2.skp .(Second post, just clic on picture to download)
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Boofredlay_CurvedWallCut2.jpg
                          simonlebon.
                            dtrarch
                            Hi All
                            Good topic and there is a solution.
                            Use the [extrudeLine] to pull up a single line and intersect for slice.
                            Then use the [joint pushpull] (tab=keep original faces) to extrude a face.
                            Check out the attached ☀
                            Looks flat to me.
                            dtr
                            Flat Top slope.skp
                              pmiller
                              It may look flat to you, but the vertical surfaces (on the right side) are not vertical, nor is the top truly horizontal. Check by turning on display edges by axis (turn on hidden geometry).
                                dtrarch
                                P Miller
                                You are right and my error.
                                SU is just plain twisted.
                                Top/bottom ortho view does show the out of vertical.
                                Oh well.
                                dtr
                                  dtrarch
                                  Jim
                                  Check this out.
                                  Ends are on xy axis and walls are on z.
                                  dtr
                                  Flat & perpendicular.skp
                                    dtrarch
                                    P Miller
                                    rong name but it's for your good eye
                                    dtr
                                    • 2 / 2
