    Curved wall w/ variable height
    22 Posts 8 Posters 5.1k Views 8 Watching
    • simon le bonS
      simon le bon
      Dear Boofredlay, thanks for your CurvedWallCut2.skp. I have found in what i was searching for. In re-doing your tut, in Scene3, you've Pushpulled the shape this way:
      http://img166.imageshack.us/img166/5895/yourpushpullwallsa3.th.jpg
      But the only pushpulled figure i can obtain is this one:
      http://img166.imageshack.us/img166/3845/mypushpullwallib2.th.jpg
      Can you explain how? ,, (great thanks for your all work in this place.)
        jfmalone
        I forgot about this posting I did. Thanks again for all the help. Here is the finished image.
        • boofredlayB
          boofredlay
          jfmalone, that is really nice. Thanks for giving us the final.
          Simon, I got the same result you did when pushing that face. Then I just erased the top and side faces so you could see the face that was passing through the curved wall. Hope that helps.
          • simon le bonS
            simon le bon
            Dear Boofredlay, at the end, after all my attempts and some thinking about, that was the conclusion i reached to.
            Hum!, elsewhere i haven't found a real Tut on Stitching. Perhaps one day, if you have little time...
              remus
              heres a very quick intro to stitching.
              stitching tut.skp
              • simon le bonS
                simon le bon
                Dear Remus,
                Sorry i had not saw your post. Thanks for this short, simple and clear tut on STITCHING.
                (we can find the ruby CurveStitcher script you've talking about here on Smustard:CurveStitcher v.2.2 by Rick Wilson )
                I just would like add this tip to do manual Stitch you can find on Boofredlay's CurvedWallCut2.skp .(Second post, just clic on picture to download)
                http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/Boofredlay_CurvedWallCut2.jpg
                simonlebon.
                  dtrarch
                  Hi All
                  Good topic and there is a solution.
                  Use the [extrudeLine] to pull up a single line and intersect for slice.
                  Then use the [joint pushpull] (tab=keep original faces) to extrude a face.
                  Check out the attached ☀
                  Looks flat to me.
                  dtr
                  Flat Top slope.skp
                  • P
                    pmiller
                    It may look flat to you, but the vertical surfaces (on the right side) are not vertical, nor is the top truly horizontal. Check by turning on display edges by axis (turn on hidden geometry).
                      dtrarch
                      P Miller
                      You are right and my error.
                      SU is just plain twisted.
                      Top/bottom ortho view does show the out of vertical.
                      Oh well.
                      dtr
                        dtrarch
                        Jim
                        Check this out.
                        Ends are on xy axis and walls are on z.
                        dtr
                        Flat & perpendicular.skp
                          dtrarch
                          P Miller
                          rong name but it's for your good eye
                          dtr
                          • 2 / 2
