    Marin Mountain Bike (WIP)
    62 Posts 27 Posters 12.5k Views 27 Watching
      dylan
      Thanks Richard ๐Ÿ‘
      http://dmdarchitecture.co.uk/
        rsw
        Continuing to make slow but steady progress with this...
        http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame9big.jpg
        (Click to enlarge!)
        I'm trying not to think about what the poly count and file size of this might be once its complete!
        Richard
          dylan
          Looking great. You have certainly got those welds perfected now ๐Ÿ˜„
          • monsterzeroM Offline
            monsterzero
            Thanks for the tutorial, Richard! This will add a lot to my vehicles!
            monsterzero
            I live stream my work on my graphic novel:
            https://www.youtube.com/@monsterz3r0
            http://infinitemachine.tv/
            https://www.aaatitle.xyz/
              rsw
              I'm going to have to do the first few again though, as they don't look as good as the most recent ones, and even though I've got the technique down to a fine art, its still quite time consuming.
              Richard
              • CraigDC Offline
                CraigD
                Hey Richard, I've been following your most excellent work! I have a question on your workflow; I see you are using groups for each weld...why not use components? With a component, the work you do on one, would be duplicated on many, leading to much quicker work. For randomness, you could create three or four weld components, and then copy them in a selectively random pattern.
                If I understand your workflow properly, this could reduce some time. Just a thought!
                Cheers,
                • CraigD
                Google SketchUp
                  rsw
                  Usually I would use components, but most of the welded joints are between two non-uniform shapes joined at odd angles which means that non of the individual welds are the same. If I was using a cyclinder and flat surafce for example (as in my brief tuturial) I would use components as the joint is uniform all the way around, but unfortunatly there are very few instances on this model where that occurs.
                  Richard
                  • CraigDC Offline
                    CraigD
                    That makes sense...I was thinking the same thing when I looked at the frame intersections.
                    Oh well, manual manipulation it is...just like real hand-made welds!
                    A very, very cool technique for sure!
                    Cheers,
                    • CraigD
                    Google SketchUp
                      rsw
                      Been on holiday, and haven't had much time since to spend working on this, but have had a little time this weekend to do some. As you can see from the second image the main elements of the frame are now done:
                      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame10.jpg
                      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame11.jpg
                      (Click to enlarge)
                      Richard
                      • boofredlayB Offline
                        boofredlay
                        Beautiful ๐Ÿ˜ฎ
                        • W Offline
                          Will03
                          killer work!
                          whats your file size at now? and what do you think it will be by the end?
                            rsw
                            @will03 said:
                            killer work!
                            At the moment the file size for the frame is about 8.5 Mb
                            The front wheel is about 1.3 Mb (which the majority of can be reused for the rear wheel)
                            So at the moment in total the file size is about 9.8 Mb
                            Taking into account all the parts that are still to model, by the time I finish I wouldn't be surprised if by the end it is over 50 Mb
                            At the moment it is probably smaller than I would have expected.
                            Richard
                              rsw
                              Started on the saddle now...
                              http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle1.jpg
                              http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle2.jpg
                              [click to enlarge]
                              I have since realised that what I thought were white lines are actually stitching, if I have time I might change the texture to show stitching instead, but for now I'm happy with it as it is.
                              Richard
                                Jon
                                Wow! This model so far is incredible! What would be awesome is instead of textures of stitching on the saddle, actual 3d stitches. ๐Ÿ˜ฒ
                                Jon
                                KT Team member
                                  mateo soletic
                                  Amazing stuff Richard, keep it up.
                                  Concept Illustrations
                                    Andrija Posariฤ‡
                                    I just love this kind of projects;-) really amazing work, and I like your attention to details, I am looking forward to seeing your update, just keep them coming;-) It is Friday, I am almost done with work, so I won't model anything this weekend, but you gave me a few pretty good ideas for the next week;-))
                                    Cheers and keep it up ๐Ÿ‘
                                    Cheers, Andrija
                                      rsw
                                      That did cross my mind (and will probably try it at a later date!..)
                                      In the meantime I've had a few minutes spare to model a brake disc rotor
                                      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_disc brake.jpg
                                      Richard
                                        SchreiberBike
                                        You keep blowing my mind. As you can guess from my handle, I've spent a lot of time on bicycles and working on bicycles. (can't ride any more due to bad knees. ๐Ÿ˜  ๐Ÿ˜ข ๐Ÿ˜ž )
                                        Your model wants me to make up a custom lugged frame in SU. The brazers deserve some attention too.
                                          bubbalove
                                          This whole thing has been a tease. I wanna see the finished bike already! Haha, no rush though.
                                          "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                            rsw
                                            I would love too see the finished bike too!! When I first thought about doing this I hadn't really intended to go into quite so much detail as I have, but I don't really have enough spare time to do as much as I'd like to with this.
                                            I'm glad I have gone into as much detail as I have, and I am determined to get this finished eventually!! but I will be glad when it's complete.
                                            Richard
                                            • 2 / 4
