    Marin Mountain Bike (WIP)
    62 Posts 27 Posters 10.3k Views 27 Watching
      rsw
      Another update:
      http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame7.jpg
      (Click to enlarge)
      It would be nice to place this weld tutorial you created over in the SU Tutorials Forum - it's a very good tut you created.
      Thanks! Tutorial created in the tutorials forum.
      Richard
        SchreiberBike
        Totally awesome. ๐Ÿ‘ I've spent a lot of time looking at bicycles and you are hitting everything right on. Of course, you can only get a reflection on a tire if you use ArmourAll on it and that's not good for the rubber. ๐Ÿ˜„
        Those welds are masterful, especially making them slightly inconsistent to show that it is hand work. Wow.
          dylan
          Thanks Richard ๐Ÿ‘
          http://dmdarchitecture.co.uk/
            rsw
            Continuing to make slow but steady progress with this...
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame9big.jpg
            (Click to enlarge!)
            I'm trying not to think about what the poly count and file size of this might be once its complete!
            Richard
              dylan
              Looking great. You have certainly got those welds perfected now ๐Ÿ˜„
              • monsterzeroM Offline
                monsterzero
                Thanks for the tutorial, Richard! This will add a lot to my vehicles!
                monsterzero
                My New Twitch Stream!
                https://www.twitch.tv/infinitestorylab
                infinitemachine.com
                  rsw
                  I'm going to have to do the first few again though, as they don't look as good as the most recent ones, and even though I've got the technique down to a fine art, its still quite time consuming.
                  Richard
                  • CraigDC Offline
                    CraigD
                    Hey Richard, I've been following your most excellent work! I have a question on your workflow; I see you are using groups for each weld...why not use components? With a component, the work you do on one, would be duplicated on many, leading to much quicker work. For randomness, you could create three or four weld components, and then copy them in a selectively random pattern.
                    If I understand your workflow properly, this could reduce some time. Just a thought!
                    Cheers,
                    • CraigD
                    Google SketchUp
                      rsw
                      Usually I would use components, but most of the welded joints are between two non-uniform shapes joined at odd angles which means that non of the individual welds are the same. If I was using a cyclinder and flat surafce for example (as in my brief tuturial) I would use components as the joint is uniform all the way around, but unfortunatly there are very few instances on this model where that occurs.
                      Richard
                      • CraigDC Offline
                        CraigD
                        That makes sense...I was thinking the same thing when I looked at the frame intersections.
                        Oh well, manual manipulation it is...just like real hand-made welds!
                        A very, very cool technique for sure!
                        Cheers,
                        • CraigD
                        Google SketchUp
                          rsw
                          Been on holiday, and haven't had much time since to spend working on this, but have had a little time this weekend to do some. As you can see from the second image the main elements of the frame are now done:
                          http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame10.jpg
                          http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame11.jpg
                          (Click to enlarge)
                          Richard
                          • boofredlayB Offline
                            boofredlay
                            Beautiful ๐Ÿ˜ฎ
                            • W Offline
                              Will03
                              killer work!
                              whats your file size at now? and what do you think it will be by the end?
                                rsw
                                @will03 said:
                                killer work!
                                At the moment the file size for the frame is about 8.5 Mb
                                The front wheel is about 1.3 Mb (which the majority of can be reused for the rear wheel)
                                So at the moment in total the file size is about 9.8 Mb
                                Taking into account all the parts that are still to model, by the time I finish I wouldn't be surprised if by the end it is over 50 Mb
                                At the moment it is probably smaller than I would have expected.
                                Richard
                                  rsw
                                  Started on the saddle now...
                                  http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle1.jpg
                                  http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle2.jpg
                                  [click to enlarge]
                                  I have since realised that what I thought were white lines are actually stitching, if I have time I might change the texture to show stitching instead, but for now I'm happy with it as it is.
                                  Richard
                                    Jon
                                    Wow! This model so far is incredible! What would be awesome is instead of textures of stitching on the saddle, actual 3d stitches. ๐Ÿ˜ฒ
                                    Jon
                                    KT Team member
                                      mateo soletic
                                      Amazing stuff Richard, keep it up.
                                      [Concept Illustrations](http://concept-illustrations.com/)
                                        Andrija Posariฤ‡
                                        I just love this kind of projects;-) really amazing work, and I like your attention to details, I am looking forward to seeing your update, just keep them coming;-) It is Friday, I am almost done with work, so I won't model anything this weekend, but you gave me a few pretty good ideas for the next week;-))
                                        Cheers and keep it up ๐Ÿ‘
                                        Cheers, Andrija
                                          rsw
                                          That did cross my mind (and will probably try it at a later date!..)
                                          In the meantime I've had a few minutes spare to model a brake disc rotor
                                          http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_disc brake.jpg
                                          Richard
                                            SchreiberBike
                                            You keep blowing my mind. As you can guess from my handle, I've spent a lot of time on bicycles and working on bicycles. (can't ride any more due to bad knees. ๐Ÿ˜  ๐Ÿ˜ข ๐Ÿ˜ž )
                                            Your model wants me to make up a custom lugged frame in SU. The brazers deserve some attention too.
                                            • 2 / 4
