    Marin Mountain Bike (WIP)
    62 Posts 27 Posters 14.0k Views 27 Watching
    • CraigDC
      CraigD
      Hey Richard, I've been following your most excellent work! I have a question on your workflow; I see you are using groups for each weld...why not use components? With a component, the work you do on one, would be duplicated on many, leading to much quicker work. For randomness, you could create three or four weld components, and then copy them in a selectively random pattern.
      If I understand your workflow properly, this could reduce some time. Just a thought!
      Cheers,
      • CraigD
      Google SketchUp
        rsw
        Usually I would use components, but most of the welded joints are between two non-uniform shapes joined at odd angles which means that non of the individual welds are the same. If I was using a cyclinder and flat surafce for example (as in my brief tuturial) I would use components as the joint is uniform all the way around, but unfortunatly there are very few instances on this model where that occurs.
        Richard
        http://img.userbars.pl/98/19554.png
        http://i158.photobucket.com/albums/t106/671GUAMDUDE/Animated---User-Green.gif
        • CraigDC
          CraigD
          That makes sense...I was thinking the same thing when I looked at the frame intersections.
          Oh well, manual manipulation it is...just like real hand-made welds!
          A very, very cool technique for sure!
          Cheers,
          • CraigD
          Google SketchUp
            rsw
            Been on holiday, and haven't had much time since to spend working on this, but have had a little time this weekend to do some. As you can see from the second image the main elements of the frame are now done:
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame10.jpg
            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_frame11.jpg
            (Click to enlarge)
            Richard
            • boofredlayB
              boofredlay
              Beautiful 😮
              • W
                Will03
                killer work!
                whats your file size at now? and what do you think it will be by the end?
                  rsw
                  @will03 said:
                  killer work!
                  At the moment the file size for the frame is about 8.5 Mb
                  The front wheel is about 1.3 Mb (which the majority of can be reused for the rear wheel)
                  So at the moment in total the file size is about 9.8 Mb
                  Taking into account all the parts that are still to model, by the time I finish I wouldn't be surprised if by the end it is over 50 Mb
                  At the moment it is probably smaller than I would have expected.
                  Richard
                    rsw
                    Started on the saddle now...
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle1.jpg
                    http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_saddle2.jpg
                    [click to enlarge]
                    I have since realised that what I thought were white lines are actually stitching, if I have time I might change the texture to show stitching instead, but for now I'm happy with it as it is.
                    Richard
                      Jon
                      Wow! This model so far is incredible! What would be awesome is instead of textures of stitching on the saddle, actual 3d stitches. 😲
                      Jon
                      KT Team member
                        mateo soletic
                        Amazing stuff Richard, keep it up.
                        Concept Illustrations
                          Andrija Posarić
                          I just love this kind of projects;-) really amazing work, and I like your attention to details, I am looking forward to seeing your update, just keep them coming;-) It is Friday, I am almost done with work, so I won't model anything this weekend, but you gave me a few pretty good ideas for the next week;-))
                          Cheers and keep it up 👍
                          Cheers, Andrija
                            rsw
                            That did cross my mind (and will probably try it at a later date!..)
                            In the meantime I've had a few minutes spare to model a brake disc rotor
                            http://www.rsw3d.co.uk/wp-content/gallery/marin-wolf-ridge/thumbs/thumbs_disc brake.jpg
                            Richard
                              SchreiberBike
                              You keep blowing my mind. As you can guess from my handle, I've spent a lot of time on bicycles and working on bicycles. (can't ride any more due to bad knees. 😠 😢 😞 )
                              Your model wants me to make up a custom lugged frame in SU. The brazers deserve some attention too.
                              • B
                                bubbalove
                                This whole thing has been a tease. I wanna see the finished bike already! Haha, no rush though.
                                "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
                                  rsw
                                  I would love too see the finished bike too!! When I first thought about doing this I hadn't really intended to go into quite so much detail as I have, but I don't really have enough spare time to do as much as I'd like to with this.
                                  I'm glad I have gone into as much detail as I have, and I am determined to get this finished eventually!! but I will be glad when it's complete.
                                  Richard
                                  • CraigDC
                                    CraigD
                                    Keep up the good work! We're all pulling for you!
                                    Cheers,
                                    • CraigD
                                    Google SketchUp
                                    • P
                                      pav_3j
                                      speechless.com\luciano
                                      unreal mate, absolutely unreal.
                                      pav
                                      (luciano)
                                      Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                                        rsw
                                        Just browsing the forum and noticed a recent reply to this...
                                        It's a shame that I haven't done any work on this since my last update (as the dates are all wrong after the forum transfer I've no idea when that was - a few months at least!), but I just haven't had the time to do this or much other su work for that matter
                                        Perhaps I will finish it one day...
                                        Richard
                                          Aegedus
                                          Hi there,
                                          I can only be in admiration for this great modelizing work !!
                                          Anyway, I dare be doubtful about using SU in this case ... I'm just a beginer using Sketchup but I'm originaly (long time ago) specialised in CAM (for Computer Aided MAnufacturing or Machining) operations (using CATIA and Applicon Bravo).
                                          This modelizing work for assembly/conception is a common task using enhanced solutions, even some free solutions emerging from the free community (some say they're pretty much useable, but I never) ...
                                          I think positionning, exploded view generation or assembly could be really painful using SU.
                                          Is my question relevant ??
                                          Aegedus
                                          • T
                                            tomislavm
                                            This model is incredible!
                                            • 2 / 4
