    Modo renders
    37 Posts 18 Posters 5.6k Views 18 Watching
      robmoors
      Hey I recognise those chairs in the last image, Compasso d'Oro Sidechairs right?
      Rob Moors
      Architecture Student
      • Mike LuceyM
        Mike Lucey
        5 star work there Jeff. You are able to
        leverage Modo well.
        Mike
          jeff jacobs
          Yea, I think you're right. They won't be the final chair, I just need something light that looks stackable for this early rendering. They will probably end up being some sort of clunky sled base chair that can stand up to a lot of abuse. We haven't spec'd the exact furniture yet.
          Thanks Mayor. I'm trying. I know there is some dispute regarding too much realism (it's like the sheep farmers battling the cattle ranchers πŸ˜„ ), but my clients demand my images be as realistic as possible. They are spoiled!
          Here's another I did today. It was to test a few materials. It's a combination of my work and components from all sorts of sources. I was really focusing on getting the light and floor materials right. Ignore the repeating texture on the stone wall. I'll fix that later! 😳
          Switching to the new intel macs really made a big difference in the complexity if the material that i can use. The speed is really unbelievable.
          This image also uses a trick that I picked up at from Yazan at the Modo forum. Duplicate your image in another layer in Photoshop and then use the "high pass" filter on it. Then switch it to overlay and adjust the percentage of opacity to the level or look you desire. Really adds a nice high-key sharpness to the image. This is similar to other techniques you have seen before but is a little different look.
          http://img504.imageshack.us/img504/8435/room2sj3.jpg
            Shaun Tennant
            Jeff, that really is awesome, and your clients are spoiled - they have you!
            Thanks for the high pass tip - I'ma try that out just to see what I end up with... I think that the materials in this one all look amazing by the way - very convincing render.
            P: Shaun Tennant
            Whether they find a life there or not, I think Jupiter should be called an enemy planet.
            • Jack Handey
            • EdsonE
              Edson
              hi jeff,
              pleased to meet you. hats off to you. awesome work.
              http://www.mahfuz.arq.br
                alan wood
                Jeff
                Beautiful work. Quality stuff.
                Love the tips all essential stuff to pass on to a person new to the craft.
                thanks
                Alan
                • C
                  cheffey
                  Excellent work Jeff.
                  I find it hard to imagine that that work is coming right out of sketchup.
                  absolutely hands down some of the best arch-viz renders i've seen.
                  i wish i could hate you for it... but you are too nice of a guy. πŸ’š
                  BROS RŌMAN BRΓ„UN
                    robmoors
                    @Jeff,
                    It's really nice to see my models come back in scene's by other by people. πŸ˜„
                    On the render itself, it's very well done, Lighting is excelent what I also try every now and then is a small emboss on the highlights and the darks in the image and put them on darken en lighten in photoshop. It creates a subtile difference and a little sharpness in the overall image:
                    Original Render:
                    Small Edit:
                    http://img91.imageshack.us/img91/9048/untitled1hr7.jpg
                    Rob Moors
                      jeff jacobs
                      That looks good Rob. I've been trying different tricks in photoshop. This looks like another good one. You do both the highlights and the shadows?
                      What object in the scene yours? I always try to give credit whwn it's not a formfonts and I know the source.
                        robmoors
                        Yes both the highlights and the shadows,
                        Offcourse with opposite emboss angles on the different layers, put the highlight layer on lighten and the shadows on darken. (soft light works from time to time but you just have to scroll through the blending modes to see what is most fitting).
                        Ow yes and a sharpen filter also often contributes to the final render.
                        http://img84.imageshack.us/img84/5623/nr1hk4.th.jpg
                        http://img216.imageshack.us/img216/1013/nr2xp0.th.jpg
                        I use a lot of the techniques I learned when I still was doing a lot of digital art (mostly terraspace http://blaze2x.deviantart.com/gallery/). You learn a lot about mattepainting and you sure as hell get familiar with photoshop.
                        As to the object, it is a FormFonts resource it's my Compasso D'oro Sidechair. But no credit is needed that is what FormFonts is for right πŸ˜„.
                        Edit:
                        Btw Im sorry for the insanely large screenshots forgot to press the ALT - printscreen button.
                        And Jeff if you ever find the chance to make a video tutorial or just a tutorial guiding us through your rendering process (From SketchUp to modo to the final render with some post processing, offcourse leaving out the moddeling part πŸ˜›) I would really appreciate it, it would also make a nice contribution to these fora.
                        Rob Moors
                          jeff jacobs
                          Rob,
                          Nice chair.
                          I'll give the emboss trick a try. I did a simple single layer emboss before I saw your latest response. That gives me a clearer picture of your technique. Very cool.
                          I could try a video sometime. I'm really pretty new to it. Probably not doing it right.
                          Here is another view I did yesterday. Starting to add some "stuff" here and there.
                          http://img522.imageshack.us/img522/6857/untitled9zz7.jpg
                            robmoors
                            Hmm the first one had more warmth to it, probably because of the red wall on the left. I kind off miss that in this render.
                            A video or some screenshot anything really would be more than welcome. I have to finish a pair of decent renders in 2 weeks of a building I am currently designing, and after seeing your renders I would love to do it with modo and a good tutorial πŸ˜„.
                            Rob Moors
                              alan wood
                              Jeff
                              This work is just amazing. I would second the last for a tutorial as there is so much stuff a beginner like myself would learn. I dare say those in the highly skilled bracket would as well because these images just jump out at you as so full of quality.
                              thanks for posting
                              Alan.
                                mateo soletic
                                I must have missed this one, Looks like
                                Ill be buying Modo soon.
                                Amazing work Jeff.
                                Concept Illustrations
                                • F
                                  firkins
                                  Jeff,
                                  These renders are just incredible. You achieve a level of reality in the quality of light that I just haven't been able to achieve. Do you attribute that to the quality of materials that you use or the render settings you use, or is it just the Modo app itself that creates such realism? I'm stumped and stupified! Shocked
                                  Regards,
                                  Michael
                                  %(#000080)["Those who would give up Essential Liberty
                                  to purchase a little Temporary Safety,
                                  deserve neither Liberty not Safety."]
                                  Ben Franklin
                                    Jackson
                                    Jeff,
                                    You're killing me with these renders!
                                    Jackson
                                    Jackson
                                      jeff jacobs
                                      @firkins said:
                                      Jeff,
                                      These renders are just incredible. You achieve a level of reality in the quality of light that I just haven't been able to achieve. Do you attribute that to the quality of materials that you use or the render settings you use, or is it just the Modo app itself that creates such realism? I'm stumped and stupified! 8O
                                      Regards,
                                      Thanks Michael and Jackson,
                                      I don't know. Lots of experimenting with light colors and ambient light. I also make my own HDRI's. While not true HDRI's they work fairly well for lighting . I adjust these quite a bit depending on a scene's needs.
                                      Some of the materials are made from the free Arroway textures. These are low-rez so there is nothing special there.
                                      I try to keep the compositions interesting and the lighting always errs on the warm side. There is some post processing in Photoshop involved. Sharpening, duplicating and adjusting layers, some attempts at tone-mapping etc. Probably more luck than skill. πŸ˜„
                                        alan wood
                                        Jeff
                                        You said 'probably more luck than skill'
                                        I love the expression 'the harder you work, the luckier you get'
                                        Alan
                                          AndreaGlucker
                                          Hello Jeff
                                          May I ask you what your workflow from SU to Modo is, fbx/obj? Do you fully texture in Modo? How do the "SU materials" get imported into Modo, I mean, does it work well?
                                          Sorry, I am pestering you with these questions, first about Maxwell, now Modo... just came across this thread here and thought "this looks interesting", maybe I need Modo, not Maxwell.
                                          If you had to compare the two, in conjunction with SU, what would you say?
                                          Regards from London, Andy.
                                          • N
                                            not registered yet
                                            excellent work Jeff.
                                            I had test run Modo before and heard that they render quickly
                                            As an example of your images.How long did it render?
                                            P: EQC
