    Roof.rb v1
    80 Posts 20 Posters 16.5k Views 20 Watching
      alpro
      Sorry, must of did something wrong the first time, can produce a hip roof now but when I try anything else I get the following. Thanks again, this definitely can be a very useful script.
      Mike
      http://www.sketchucation.com/forums/scf/sas/Ruby/errors3.jpg
        dylan
        Thanks TIG, the new script now works perfectly - What a great Ruby!
        http://dmdarchitecture.co.uk/
          @alpro said:
          TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in regards to my computer specs. Thanks.
          Mike
          Are you sure you overwrote v1.0 with v1.1 ?
          No matter... put this attached file into you Plugins folder. It should fix the problem either way...
          404 Not Found
          (www.sketchucation.com)
            rhankc
            Tig, just ran a couple gable roofs with the new spin. It worked with the default setup, with pitch entered, I played with the eaves a bit, think she is looking good..
            I want to congratulate you...humbly...this is like a grand slam. I am really looking forward to putting this roof tool through it's paces. Thanks
            Hank
              davekn
              Hi Tig
              First off - many thanks for the script it looks great.
              However at the moment I don't appear to be able get it to do anything at all.
              I am using an iMAC & Sketchup Pro and when I select a horizontal face on the top of a box & go to the plugins folder & pick roof - hipped roof then nothing happens at all - I don't even get the first dialogue box.
              If I select a face & gable edge & pick Gable ended roof then I get the message
              'You must select one horizontal RECTANGULAR [= right-angled] face, and one edge (that's at the 'gable') !' even though this is what I have done. I have tried just about every combination of edges & faces to no avail.
              If you need any further info then let me know.
              Regards Dave
                davekn
                Have you downloaded v1-1 that fixes some errors ?
                404 Not Found
                This should get you somewhere. However, the accuracy of the 'rectangle' checking is perhaps causing some problems and I'm looking at ways of building in some 'tolerance'. Have you simply drawn a rectangle 'on the floor' and tried that ?
                  davekn
                  Hi Tig
                  Yes I downloaded v1 & I have tried drawing a rectangle on the floor but with exactly the same results.
                  I had to rename the the V1 download as I have the problem that all downloads apart from zipped files come in as 'download.php'. The original was okay as it came in a zipped file.
                  I presume the v1 file is still named roof.rb
                  many thanks Dave
                    @davekn said:
                    Hi Tig
                    many thanks Dave
                    Try the v1.1 zip to be sure...
                      davekn
                      Hi Tig
                      Sorry - I have just tried that as well.
                      Same result.
                      Dave
                      • boofredlayB Offline
                        boofredlay
                        TIG, version 1.1 only worked on the Hipped and Mansard, not on the Gable or Pyramid. I went to church, went for a walk, tried it again and it works... hmmm.
                        Anyway, for now all 4 roofs work. Thanks a bunch. I can see me using this one quite a bit.
                          alpro
                          TIG, I can get all four roofs to work some of the time, pretty much hit or miss,even tried a rectangle on the floor as you suggested to davekn, it seems to work better when I try to put a roof over a square instead of a rectangle, works pretty much all of the time, so I'm guessing that you are correct in thinking of some rectangle tolerance method. Still a great script though, thanks.
                          Mike
                            dylan
                            Well as I said, on my XP machine they are all working fine with 1.1.
                            On my vista machine, the hipped roof works ok, none of the others will.
                            These errors must be making your brain hurt TIG!
                              They do (aaargh) especially when I don't get any errors on XP or Vista set-ups almost exactly like yours ...
                              BUT it shall be sorted !
                                Here's v1.2. Click here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
                                There's now a slight tolerance in checking if the face to make a gable or pyramid roof is rectangular. If the sides are out by less than ~0.2mm in 1000mm it'll still work. However, in that case you might get gables not lining perfectly with the block below.
                                I hope this now addresses a few problems. Keep the feedback coming...
                                  davekn
                                  Tig
                                  Tried the version 2 but still no luck.
                                  Now when I pick the face & edge I dont get the dialogue box I had before about 'needing to pick a face & edge', but nothing else happens - no box to add the information required for eaves etc.
                                  Tried a rectangle on the floor & a square on the floor.
                                  Tried all the different types of roof.
                                  Is there anybody else on the forum who has a Mac & is getting the script to work? I am now worried I am doing something really stupid & missing something out.
                                  Thanks for all the effort.
                                  Dave
                                    alpro
                                    TIG, the latest version seems to work alot better, only problem I'm having is with the gable roofs, they all seem to come up a little short. Keep up the good work. Thanks again for a great script.
                                    Mike
                                    404 Not Found
                                      boofredlay
                                      TIG, v1.2 is working flawlessly on my work computer.
                                      Thanks.
                                        dylan
                                        I did have the same problem as Alpro posted above with the gable roof stopping short. This was intermittent though.
                                        • Didier BurD Offline
                                          Didier Bur
                                          Hi TIG
                                          Very nice work ! V1.2 is working OK here, both on W2000 and XP.
                                          It's a pity that I can't translate it to french (script is crypted) 😒 πŸ˜‰
                                          Regards,
                                          DB
                                            @didier bur said:
                                            Hi TIG
                                            Regards,
                                            Since I've copied your cunning techniques you should be able to crack it easily! ?;^)
                                            Please feel free to make a re-encrypted french version, with a suitable change to the header in which you take the blame for the translation! ?:-| Toit.rb ?
                                            You could also rework RoofHelp.mht into french - as say ToitAide.mht with the end menu bits reworked to suit, before recrypting...
                                            Wait for v1.3 to arrive before doing any translating. The fix for v1.2 itself caused a glitch with the materials for some types of gables that I didn't spot before reissuing it yesterday...
                                            • 3 / 4
