    Roof.rb v1
    80 Posts 20 Posters 16.5k Views 20 Watching
      Here's v1.2. Click here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
      There's now a slight tolerance in checking if the face to make a gable or pyramid roof is rectangular. If the sides are out by less than ~0.2mm in 1000mm it'll still work. However, in that case you might get gables not lining perfectly with the block below.
      I hope this now addresses a few problems. Keep the feedback coming...
        davekn
        Tig
        Tried the version 2 but still no luck.
        Now when I pick the face & edge I dont get the dialogue box I had before about 'needing to pick a face & edge', but nothing else happens - no box to add the information required for eaves etc.
        Tried a rectangle on the floor & a square on the floor.
        Tried all the different types of roof.
        Is there anybody else on the forum who has a Mac & is getting the script to work? I am now worried I am doing something really stupid & missing something out.
        Thanks for all the effort.
        Dave
          alpro
          TIG, the latest version seems to work alot better, only problem I'm having is with the gable roofs, they all seem to come up a little short. Keep up the good work. Thanks again for a great script.
          Mike
          404 Not Found
          (www.sketchucation.com)
          • boofredlayB Offline
            boofredlay
            TIG, v1.2 is working flawlessly on my work computer.
            Thanks.
              dylan
              I did have the same problem as Alpro posted above with the gable roof stopping short. This was intermittent though.
              http://dmdarchitecture.co.uk/
              • Didier BurD Offline
                Didier Bur
                Hi TIG
                Very nice work ! V1.2 is working OK here, both on W2000 and XP.
                It's a pity that I can't translate it to french (script is crypted) 😒 πŸ˜‰
                Regards,
                DB
                  @didier bur said:
                  Hi TIG
                  Regards,
                  Since I've copied your cunning techniques you should be able to crack it easily! ?;^)
                  Please feel free to make a re-encrypted french version, with a suitable change to the header in which you take the blame for the translation! ?:-| Toit.rb ?
                  You could also rework RoofHelp.mht into french - as say ToitAide.mht with the end menu bits reworked to suit, before recrypting...
                  Wait for v1.3 to arrive before doing any translating. The fix for v1.2 itself caused a glitch with the materials for some types of gables that I didn't spot before reissuing it yesterday...
                    Version v1.3 of Roof.rb is now available.
                    It fixes most of the outstanding bug reports. But keep the feedback coming...
                      alpro
                      TIG, v1.3 is working perfectly, thanks for a great script,it should be a big time saver.
                      Mike
                      • W Offline
                        wattsillus
                        The roof script is amazing Tig. It worked as advertised with no hitches. As an architectural illustrator it will get used to death. Your efforts are deeply appreciated,
                        Thank you!!!
                        Robert
                          seasdes
                          V1.3 now offsets a gable roof to the side of the polygon used to define the roof.
                          Sorry
                          Seasdes
                          404 Not Found
                          Using Sketchup Pro 2019
                            Sorry
                            Seasdes
                            A new one - I haven't managed to reproduce that (yet). As you can see from others comments they aren't getting the problem. Does it always do it, or at certain rotations of the rectangle about the origin? What are the setting you use in the dialog and system are you on ?
                            Edit: Found out the cause - looking for a fix. IF you have a manually drawn rectangle - 4 sides, drawn clockwise and the face reversed (down) you get your problem; with the same face if you reverse (up) it before running gable-roof tool the two gable-ends swap over but otherwise the roof is in the right place. Must be trappable and fixable - thinking on it...
                            Looking into it now. It shall be fixed...
                              seasdes
                              Thank you TIG. This is a truly wonderful script that will save me a lot of time
                              Seasdes
                                seasdes
                                @tig said:
                                Sorry
                                Seasdes
                                Edit: Found out the cause - looking for a fix. IF you have amanually drawn rectangle - 4 sides, drawn clockwise and the face reversed (down) you get your problem; with the same face if you reverse (up) it before running gable-roof tool the two gable-ends swap over but otherwise the roof is in the right place. Must be trappable and fixable - thinking on it...
                                Hello TIG
                                The problem that I reported happens all of the time - regardless of how the rectangle is drawn. The problem did not occur in V1
                                Seasdes
                                  davekn
                                  Tig
                                  Still having the same problems with v3 as with the previous versions.
                                  The get slope angle works fine & so the script must be working - but as previously said I don't even get the initial info box when trying to draw any of the roofs.
                                  This must be a Mac thing.
                                  Dave
                                    @davekn said:
                                    Tig
                                    Dave
                                    Are you getting any messages in the Ruby Console Window when you try and run it ?
                                    Are there any other Mac users out there trying this ? Successfully or not ? I don't know of any Mac/PC issues that could be causing this...
                                      dtrarch
                                      Super and very much needed script but the Gable still is iffy for me and some faces that are created square are refused by the script and will not execute.
                                      Here is a jpg and skp for your review.
                                      Dave
                                      404 Not Found
                                        davekn
                                        Tig
                                        The following comments are in the Ruby console
                                        Hipped Roof -
                                        Error: #<NoMethodError: undefined method dialog_hip' for Roof:Class> (eval):210:in hip'
                                        (eval):2749
                                        (eval):210:in `call'
                                        (eval):210
                                        Mansard Roof -
                                        Error: #<NoMethodError: undefined method dialog_man' for Roof:Class> (eval):802:in mansard'
                                        (eval):2750
                                        (eval):210
                                        Gable roof -
                                        Error: #<NoMethodError: undefined method dialog_gable' for Roof:Class> (eval):1514:in gable'
                                        (eval):2751
                                        (eval):802:in `call'
                                        (eval):802
                                        Pyramid roof -
                                        I still get the instruction to pick a rectangular face & edge etc
                                        Dave
                                          tomot
                                          fantastic script TIG!
                                          Please allow me to make the following small observation:
                                          see attachment
                                          http://www.sketchucation.com/forums/scf/sas/Ruby/roof.jpg
                                          my plugins
                                          tomot
                                          • I Offline
                                            Iglesias
                                            Hello,
                                            The problem could be solve making one of the wings a block.
                                            404 Not Found
                                            • 3 / 4
