    Roof.rb v1
    80 Posts 20 Posters 16.8k Views 20 Watching
      alpro
      TIG, here's a screen shot of my ruby console.
      Mike
      http://www.sketchucation.com/forums/scf/sas/Ruby/errors.jpg
        dylan
        Hi TIG,
        I have tried the script as you asked and have posted the results.
        I tried Gable Ended Roof and Hipped Roof.
        Gable ended I picked the top face and one edge and got the attached error (image 1 & 2).
        Hipped roof I get the following info in the ruby box (image 3)
        Running on XP SP2, SU Pro 6.0.515
        http://www.sketchucation.com/forums/scf/sas/Ruby/3.jpg
        http://www.sketchucation.com/forums/scf/sas/Ruby/2.jpg
        http://www.sketchucation.com/forums/scf/sas/Ruby/1.jpg
        http://dmdarchitecture.co.uk/
          Mike
          I've posted v1.1 that fixes your problem = http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
          Replace the current version with this one.
          At least that error report is fixed. Now for some other errors...
            ...I have tried the script as you asked and have posted the results.
            Hipped roof I get the following info in the ruby box...
            The previous post links to an updated version v1.1 that fixes the A:B glitch. The Gable and Pyramid tools only let you work on a horizontal rectangle. Sometimes what appears to be a rectangle isn't (as far as Ruby is concerned) I'm trying to come up with a 'tolerance' method...
              alpro
              TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in reguards to my computer specs. Thanks.
              Mike
              http://www.sketchucation.com/forums/scf/sas/Ruby/errors2.jpg
                alpro
                Sorry, must of did something wrong the first time, can produce a hip roof now but when I try anything else I get the following. Thanks again, this definitely can be a very useful script.
                Mike
                http://www.sketchucation.com/forums/scf/sas/Ruby/errors3.jpg
                  dylan
                  Thanks TIG, the new script now works perfectly - What a great Ruby!
                    @alpro said:
                    TIG, I'm still getting the same errors, after replacing the current version. Thanks for the quick reply to last post though. Hope you get it figured out, let me know if you need any additional info in regards to my computer specs. Thanks.
                    Mike
                    Are you sure you overwrote v1.0 with v1.1 ?
                    No matter... put this attached file into you Plugins folder. It should fix the problem either way...
                    404 Not Found
                    (www.sketchucation.com)
                      rhankc
                      Tig, just ran a couple gable roofs with the new spin. It worked with the default setup, with pitch entered, I played with the eaves a bit, think she is looking good..
                      I want to congratulate you...humbly...this is like a grand slam. I am really looking forward to putting this roof tool through it's paces. Thanks
                      Hank
                        davekn
                        Hi Tig
                        First off - many thanks for the script it looks great.
                        However at the moment I don't appear to be able get it to do anything at all.
                        I am using an iMAC & Sketchup Pro and when I select a horizontal face on the top of a box & go to the plugins folder & pick roof - hipped roof then nothing happens at all - I don't even get the first dialogue box.
                        If I select a face & gable edge & pick Gable ended roof then I get the message
                        'You must select one horizontal RECTANGULAR [= right-angled] face, and one edge (that's at the 'gable') !' even though this is what I have done. I have tried just about every combination of edges & faces to no avail.
                        If you need any further info then let me know.
                        Regards Dave
                          davekn
                          Have you downloaded v1-1 that fixes some errors ?
                          404 Not Found
                          This should get you somewhere. However, the accuracy of the 'rectangle' checking is perhaps causing some problems and I'm looking at ways of building in some 'tolerance'. Have you simply drawn a rectangle 'on the floor' and tried that ?
                            davekn
                            Hi Tig
                            Yes I downloaded v1 & I have tried drawing a rectangle on the floor but with exactly the same results.
                            I had to rename the the V1 download as I have the problem that all downloads apart from zipped files come in as 'download.php'. The original was okay as it came in a zipped file.
                            I presume the v1 file is still named roof.rb
                            many thanks Dave
                              @davekn said:
                              Hi Tig
                              many thanks Dave
                              Try the v1.1 zip to be sure...
                                davekn
                                Hi Tig
                                Sorry - I have just tried that as well.
                                Same result.
                                Dave
                                • boofredlayB Offline
                                  boofredlay
                                  TIG, version 1.1 only worked on the Hipped and Mansard, not on the Gable or Pyramid. I went to church, went for a walk, tried it again and it works... hmmm.
                                  Anyway, for now all 4 roofs work. Thanks a bunch. I can see me using this one quite a bit.
                                    alpro
                                    TIG, I can get all four roofs to work some of the time, pretty much hit or miss,even tried a rectangle on the floor as you suggested to davekn, it seems to work better when I try to put a roof over a square instead of a rectangle, works pretty much all of the time, so I'm guessing that you are correct in thinking of some rectangle tolerance method. Still a great script though, thanks.
                                    Mike
                                      dylan
                                      Well as I said, on my XP machine they are all working fine with 1.1.
                                      On my vista machine, the hipped roof works ok, none of the others will.
                                      These errors must be making your brain hurt TIG!
                                        They do (aaargh) especially when I don't get any errors on XP or Vista set-ups almost exactly like yours ...
                                        BUT it shall be sorted !
                                          Here's v1.2. Click here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=153&t=1516
                                          There's now a slight tolerance in checking if the face to make a gable or pyramid roof is rectangular. If the sides are out by less than ~0.2mm in 1000mm it'll still work. However, in that case you might get gables not lining perfectly with the block below.
                                          I hope this now addresses a few problems. Keep the feedback coming...
                                            davekn
                                            Tig
                                            Tried the version 2 but still no luck.
                                            Now when I pick the face & edge I dont get the dialogue box I had before about 'needing to pick a face & edge', but nothing else happens - no box to add the information required for eaves etc.
                                            Tried a rectangle on the floor & a square on the floor.
                                            Tried all the different types of roof.
                                            Is there anybody else on the forum who has a Mac & is getting the script to work? I am now worried I am doing something really stupid & missing something out.
                                            Thanks for all the effort.
                                            Dave
                                            • 3 / 4
