🔌 Quick Selection | Try Didier Bur's reworked classic extension that supercharges selections in SketchUp Download
Closing Groups and Components after edit
6 Posts 5 Posters 1.1k Views 5 Watching
    rhankc
    Is there a command to close multiple groups and components with one click or menu selection?
    I am working on this house, and I have deep levels of groups and components, when I need to make a minor adjustment to an deep lying entity, that is like ten levels down i want to get back out quick and I have to close each instance. is there a command to close all real fast? I see the close group/component under the Edit menu, but this is a one-at-a-time command.
    thanks
    Hank
      Archi Rag
      u could always keyboard shortcut it (i use 'end') but i guess ur still tapping the same button u can also click outside the component to get out of the grup/component ur editting
      i know it doesnt quite answer the question but its a bit of a solution
      • N Offline
        not registered yet
        The top-level object listed in the Outliner (Window > Outliner) is the file name of the model. Just click on it and you'll pop all the way out of your nested groups.
        -Gully
          rhankc
          thank you gully
          Hank
            Krisidious
            yes what gully said, and don't forget to use your layers too... a quick way to turn off areas just so you can work deeper without being in groups and components
            By: Kristoff Rand
              kdjanz
              Actually, you don't have to go to the top of the outliner - just click in any white space and it will take you out to the top.
              Kelly
