    Attributes - Export / Create More / Linking with Database ?
    38 Posts 10 Posters 8.8k Views 10 Watching
    • H
      Howard leslie
      TIG,
      V 1.1 really is excellent.
      It's extremely useful being able to run this script on a selection from a model.
      I think many people will find this script useful
      For an example see:
      viewtopic.php?f=22&t=3429
      (your script could now be in Siberia !!!)
      Currently I'm running the script on a model containing many components.
      Originally some of these components were contained within other components (nested) others were grouped together.
      I found that the script does not drill down into nested components or grouped components.
      Not a huge problem as a workaround is to explode the larger components and groups.
      However, would it ever be possible to have the script drill down into more complex (nested) components and groups to get at the buried ones ???
      Thanks once again for all your help
      Regards
      Howard Leslie
        Jim
        I wrote this Outliner exporter for a specific purpose, but it may be of use to someone.
        Error 404 (Not Found)!!1
        (sketchuptips.blogspot.com)
          TIG,
          For an example see:
          http://www.sketchucation.com/scf/viewtopic.php?f=22&t=3429
          Not a huge problem as a workaround is to explode the larger components and groups.***
          Regards
          Howard Leslie
          The script first reports ALL component definitions and how many times they are placed/used, of course this might include components nested inside other components etc. It then makes a report of all placed Instances that are accessible directly within the model. An alternative is to select a collection of objects containing some instances and it'll offer the option of reporting just on those.
          ***No need to explode anything... IF you have component instances inside groups or within other components then you can simply edit that group/component and select all - you then run the script and will get the chance to make a report of just the instances in that selection.
          It COULD mine down into all component instances definition or groups and report on the internal bits... but you have to stop somewhere. Simply clicking the group/component to edit and Ctrl+A to select all before running it will give you a list of what instances are there...
          I have previously made 'group_miner.rb' that does just that iterative delving into nested things BUT unless there's a massive clamour for it I won't be adjusting this script immediately...
            I decided that adding the 'mining' ability wasn't too hard... so here's v1.2
            404 Not Found
            (www.sketchucation.com)
            You now get the chance to 'mine' down through nested-groups/components to get a report on all instances found - either 'all' or in an initial selection.
            • G
              gata
              I am getting an error message. There is a conflict with RpTools.
              C:/Program Files/Render Plus Systems/RpTools/test-Component+Report.csv NOT available for writing (it might be open) !
              Exiting...
              RpTools puts a menu item called Model Report in the Tools menu. It offers the option to create a text or Excel file. The file is saved in the program file. The file it creates is called test_report.txt (or csv).
              This error message occurs whether or not I used Model Report to create a file.
              • H
                Howard leslie
                TIG,
                Thanks for putting this mining ability into the Reporting Tool.
                However, I'm also getting a similar error message to the one described by gata
                (see attached)
                Regards
                Howard L'
                http://www.sketchucation.com/forums/scf/sas/SketchUp/err_msg.jpg
                  TIG,
                  (see attached)
                  Regards
                  Howard L'
                  Well at least you are getting that error !!! - I've been trying to get it for some time - without success ! It's not a clash with other scripts (I think) - where was the 'test' skp saved ?
                  I added an extra bit in when I made the 'miner' that tries to check if the report file is open before you start to write to it. For example you make a report and open it, you leave it open and try to make a second report - this time it can't write to the file since you already have it open in another program. It fails dumping errors into the Ruby Console. I've tried to trap this in an error message - with little success.
                  Here's v1.3 that has that part disabled till I get it going better. Meanwhile it works as advertised. IF it doesn't end with the closing message saying what it's written where then chances are it's failing because the older report is still open and you forgot to close it...
                  404 Not Found
                  • G
                    gata
                    I'm getting your files now - in C:\Program Files\Render Plus Systems\RpTools
                    RpTools reports go to the same directory. Their files are named test_report.txt (and csv).
                    No error messages appear in the Ruby console.
                    I did not get a closing saying the files were written - even the first time I successfully tried it here. I had opened the files in Excel to see how they look (had to move over the column a bit) then closed Excel.
                    I ran your script a second time and still did not get the closing message. The only message I get is one saying it will save the files to the RpTools directory.
                    XP Pro, SP2.
                      XP Pro, SP2.
                      The older/simpler ComponentReporter.rb made a csv [comma] and a txt [tab] file, BUT that went into the model's folder and were named as the ModelName-ComponentReport.XXX
                      The new version only makes the csv file and has a '+' sign after Component in the file name. Clearly what you are running isn't my script. I don't have the RpTools so I don't know what they do. If there is 'Class' clash it might cause my menu item to run something in their script...
                      To test this make a backup copy of my ComponentReporter+.rb script, open the original in Notepad [or another plain text editor BUT NOT a word-processor !]. Find and replace Reporter (which is the Class) with say ReporterPlus for every instance thus:
                      class Reporter >>> class ReporterPlus
                      def Reporter::components_plus >>> def ReporterPlus::components_plus
                      def Reporter::miner(ents) >>> def ReporterPlus::miner(ents)
                      xlist=Reporter.miner(elist) >>> xlist=ReporterPlus.miner(elist)
                      full_list=Reporter.miner(all_list) >>> full_list=ReporterPlus.miner(all_list)
                      UI.menu("Plugins").add_item("Component+ Report"){Reporter.components_plus} >>> UI.menu("Plugins").add_item("Component+ Report [TIG]"){ReporterPlus.components_plus}
                      Note when you scroll to near the end and find the menu string - you should add something onto the text like [TIG]. Save the file and re-run.
                      You should now get an item in the Plugins menu with the [TIG] in itthat runs my script alone...
                      • G
                        gata
                        TIG, I made all your edits and still get your csv files in RpTools directory.
                        I used to have the old ComponentReporter.rb, but renamed it with TXT then removed it from the Plugin directory altogether.
                        And I forgot, RpTools Model Report does produce an announcement message after its file is created whereas your plugin only announces where the file will go.
                        http://www.sketchucation.com/forums/scf/sas/SketchUp/ComponentReporter+issue.jpg
                        • H
                          Howard leslie
                          TIG / Jim,
                          Thanks very much for all your hard work and time spent on writing these scripts.
                          They are both very useful
                          TIG,
                          ComponentReporter+
                          V 1.1
                          I'm finding that this runs no problem. (but no mining ability).
                          V 1.2
                          I'm not sure what the V1.2 error message refers to either, as I did not have any existing *.csv file open when I ran the script - that was actually the first thing I checked.
                          V 1.3
                          I'm finding that this runs OK. NO error messages.
                          I'm finding that it mines down into the Model - 1 Level of nesting.
                          The ultimate version of this script would mine down to drag out all components from the whole model - however deep they are nested inside groups / other components. Is this possible ??? - it would be brilliant if you could implement this.
                          I'm using the V 1.1 of the script until then as the model I'm working on has been exploded down somewhat and the script runs really well.
                          Thanks once again to both of you.
                          Regards
                          Howard Leslie
                            Seems like RpTools is screwing up the model's folder-path which is what my script uses so as to know where to save the model's reports. It's clear from you screen-shot that your model 'gata' isn't in the RpTools reports folder.
                            Please copy and paste the following into the Ruby Console and publish what is given.
                            First:
                            Sketchup.active_model.title
                            This should given the model name without the .skp extension - e.g. 'gata'
                            Second:
                            mpath=Dir::pwd
                            This is your working directory, and should normally be the model's folder - I suspect that RpTools is changing this to suit itself.
                            Third:
                            Sketchup.active_model.path
                            Check that RpTools doesn't mess with this...
                            This is the model's folder - I will change my script to use this by default.
                            • Al HartA
                              Al Hart
                              Rptools does a Dir.chdir before loading a Ruby Extension DLL. (This causes the DLL to search for other DLL's is uses in its own path.)
                              It should have changed the folder back after loading the DLL, but somehow the line:
                              Dir.chdir(scur_folder)
                              got lost.
                              I will put it back for future versions of RpTools.
                              However, there may be other Ruby scripts, or other activities which change the current folder. So it might be a good idea to have ComponentReporter.rb specify a specific folder to save the file into.
                              1. You could grab a copy of the current directory when ComponentReporter.rb first loads with: (ComponentsReporter.rb will load before RpTools_loader.rb because it comes first alphabetically)
                              $srpc_cur_folder = Dir.getwd
                              and then reset the folder before saving the file with
                              Dir.chdir($srpc_cur_folder)
                              or add the folder name to the .CSV file name before saving it.
                              1. You should be able to get the Windows My Documents folder with code along the lines of:
                              require "Win32API" # you would have to put Win32API into the SketchUp Tools folder
                              SHGetSpecialFolderPath     = Win32API.new('shell32', 'SHGetSpecialFolderPath', 'LPLL','L')
                              my_docs_folder = " "*512 # build buffer for file name
                              CSIDL_MYDOCUMENTS             = 0x000c
                              SHGetSpecialFolderPath.call(0, my_docs_folder, CSIDL_MYDOCUMENTS, 0)
                              But I wasn't quite able to get this to work. I wound up writing a ruby DLL to fetch the path of the current folder.
                              Al Hart
                              IRender nXt from Render Plus
                              • G
                                gata
                                Ruby console results.
                                This file contains my kitty and other creatures. Nesting of groups and components is necessary in part to avoid inadvertently selecting and working on the wrong geometry and parts. Day job typically involves all milwork/woodwork for homes with 20' ceilings and 12 air conditioners. Some elements do get hand sculpting.
                                This deep mining accounting stuff could be useful to help manage stuff.
                                http://www.sketchucation.com/forums/scf/sas/SketchUp/test_results.jpg
                                  I've rewritten the Component+Reporter to get the model's directory another way, which then avoids any such problems.
                                  Miner now goes all the way...
                                  Also took the chance to trap for commas in the names into ';' otherwise = messed up .csv files. Although it allowed, it's still best to avoid commas in Component, Group and Layer names.
                                  Also made a 3rd report on 'parentage' a la Outliner...
                                  Also sorted out the File Already Open Error...
                                  v1.4 is here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=6687#p6687
                                  • G
                                    gata
                                    TIG, Your files go to the right directory now 😄 😄 No message that the files were completed though - if you still coded for that.
                                    It might be more useful if your three files were three pages in one Excel document.
                                    I noticed that you cannot save adjusted column widths in the csv format. Interesting. I suppose such limitations disallows pages in csv too.
                                    Also, area doesn't have units listed.
                                      You should always get a dialog at the end telling you where the three files went ?
                                      It is difficult to make multi-page csv's - that's why you get three !
                                      The easy way to use a .csv file with formatting is to make a separate full blown Excel .xls file - using the same name seems logical (XXX-Component+Report.csv and XXX-Component+Report.xls). Then open the cvs and xls. We need to link them so that the xls keeps its formatting while the csv can be rewritten and the data reflected in the linked xls without loss of formatting [There's Excel help on this too]. Here's how..
                                      Open both files.
                                      Have the csv at the front.
                                      Select the cells in the csv that you want to link into the xls.
                                      Ctrl+C to copy.
                                      Switch to xls window.
                                      Menu > Edit > Paste Special...
                                      In the dialog click the bottom 'As Link' button.
                                      Now the csv is linked into the xls.
                                      Format the xls as you wish.
                                      Whenever the csv changes the xls will too when it next opens.
                                      You'll need to edit the blank fields that come mover as '0' and if the csv rows increase you'll need to re-link the csv into the xls...
                                      See Excel Help for more details...
                                      Areas. The XYZ dims are in current units BUT the areas report in the system default 'sq inches'. I'll adjust it to come in current units - look out for an update...
                                        Here's v1.5
                                        http://www.sketchucation.com/forums/scf/viewtopic.php?p=6688#p6688
                                        Areas are now in current units... however there is guidance on how to set areas to sq m if you work in mm etc...
                                        • G
                                          gata
                                          Due to the excitement of the moment I thought the written to announcement showed up at the beginning - not the end. All is well.
                                          TIG, looks like you, Al, and vendmr are giving me a reason to delve into Excel. The ability to make custom, update-able XLS could indeed be very useful.
                                          Recent we made a bunch of custom doors and jams. On the most part the rough opening measures and count recorded in an Excel file where correct. But somehow the people fabricating everything were often given drawings with incorrect sizes and hinge side location.
                                          Some of my current projects includes domed ceilings and adding faux beams to a groin vault. If thing were originally laid out in SU, I wouldn't have to fudge things to fit now.
                                          • H
                                            Howard leslie
                                            TIG,
                                            ComponentReporter+ V 1.5
                                            Outstanding script.
                                            The parentage / outliner type report - very useful addition also.
                                            The deep mining ability seems to work well after an initial (tough) trial:
                                            42 MB Model (this includes 2 x Xref'd models)
                                            Layers 30
                                            Component Definitions 921
                                            Component Instances 7650
                                            Groups 3410
                                            V 1.5 went to work - 30 seconds in total to produce all reports (ie very quick).
                                            So far the script looks really good and appears to be working well.
                                            A Massive Thank You for all your hard work in producing this script.
                                            Regards
                                            Howard Leslie
                                            • 2 / 2
