    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 19.3k Views 14 Watching
    • Didier BurD
      Didier Bur
      Hi Daniel,
      Done. See depository and replace houseBuilderTool.rb in your HouseBuilder folder.
      Cheers,
      DB
        Daniel S
        Thank you Didier! I have no more the "beep" πŸ˜„
        And all the rest works perfect.
        Thank you again,
        Daniel S
        • kmeadK
          kmead
          Still not enjoying the love. Still suffer the same error on a Mac. Its no fun being a minority... πŸ˜‰
          I created Dilbertville, sorry about that...
          • Didier BurD
            Didier Bur
            Hi Kmead,
            Let's try something else:
            Could you open the Ruby console and type:
            a = Sketchup.find_support_file("Sketchup.exe") ENTER
            and then type:
            a + "Plugins\HouseBuilder\" ENTER
            Please post the 2 results you've got, just to check if really it's a path problem or a backslash string problem or ❓
            Let's debug online... πŸ˜†
            DB
            • ton baetenT
              ton baeten
              Didier,
              Since I have the same problem as Kmead on my Mac (with OSX 10.4.9), I followed this thread with great interest. I did what you adviced him to do. The results are: nil and Error: #<NoMethodError: undefined method `+' for nil:NilClass> (eval)
              But, maybe the problem is of an other nature:
              It was adviced to put everything concerning HouseBuilder in a separate folder under ..../plugins. So I did. Well, this is the only ruby to be stored in this way.
              There are more rubies extracting information from separate folders located in the pluginsfolder, but they all have an "open" xxxxx.rb file in the pluginsfolder (as a startingpoint !?), except Housebuilder.
              I am just a 'simple' Mac SU pro user, using a lot of rubies, so anything but a ruby-specialist. The only thing I can offer is help in performing any 'test' you would ask me for.
              with appreciation and greetings,
              Ton
              greetings,
              Ton
              • Didier BurD
                Didier Bur
                Hi Ton,
                Thanks for helping me track the bug πŸ˜‰
                If I'm not completely mad, I understand from your results that the method "find_support_file" doesn't work the same way on a Mac than on a PC 8O
                BUT just an idea comes to mind now: the Sketchup executable on Mac is not named "sketchup.exe" (no file extensions on Mac, right ?)
                That's why the method returns nil, eh eh...
                Could you try (sorry, no Mac here...) in the Ruby console:
                Sketchup.find_support_file("Sketchup")
                If it returns something else than nil, problem is solved. πŸ˜„
                Thanks again for helping,
                DB
                • ton baetenT
                  ton baeten
                  Didier,
                  I presume you are anything but 'completely mad'.
                  Indeed, Macs never use the extension .exe that is pure MS windows (why didn't I think of that).
                  I just tried Sketchup.find_support_file("Sketchup") in the ruby console and the result still is: nil
                  So, still no solution. The last hour I just tried a couple of things, but found no solution.
                  Could you please describe me what files (rubys and/or non-ruby) I need to/should have and where they should be located.
                  For now, I have, located in my plugins folder a folder HouseBuilder_metric_1.2.
                  This folder contains
                  • HouseBuilder_extensions.rb
                  • readme.txt
                  • HousebuilderTool.rb
                  • Housebuilder.rb
                  • another folder called 'Housebuilder' containing:
                  • a number of png's and gif's
                  • HouseBuilder-extension.rb(gif)
                  • housebuilder_sections.txt
                    As mentioned before, everythings is within one folder. None of the ..rb files are in the plugins folder itself. Maybe that is why nothing can be found to start 'Housebuilder'.
                  Open for further info and tests,
                  Greetings,
                  Ton
                  greetings,
                  Ton
                  • Didier BurD
                    Didier Bur
                    Hi Ton,
                    I'm sorry to say that your files/folders organization is completely wrong...
                    A ruby script doesn't find its way by itself, so there are some rules to follow in order to make it work πŸ˜‰
                    When I release a package I always save the folders information when building the Zip so the user have just to unzip it in his Plugins folder and that's it. No folder(s) creation needed, no file(s) renaming, no nothing.
                    If you delete all "housebuilder" files you have installed and unzip the package again in your Plugins folder, it MUST work.
                    After having unziped, you should have:
                    • "HouseBuilder_extension.rb" in your Plugins folder, as well as "readme.txt"
                    • a folder named "HouseBuilder" under the Plugins folder
                    • in this HouseBuilder folder: all Gif's and PNG's, 2 rubbies and "housebuilder_sections.txt"
                    If it doesn't work, I give up πŸ€“
                    Hope this helps this time πŸ˜‰
                    DB
                    • ton baetenT
                      ton baeten
                      Didier,
                      Thanks for your info.
                      My thinking was that my problems had to do with my file-organisation. So I followed your advice, erased all HouseBuilder files, put the Housebuilder-metric_1.2.zip in my plugins folder and unzipped.... The result (on my Mac) is a new folder (within plugins), called 'HouseBuilder_metric_1.2Folder. No HouseBuilder... files outside that folder, just that new folder. Following your info I moved the HouseBuilder_extensions.rb out of that folder into the open area of my 'plugins'.
                      The result I get at restarting SU is :
                      no such file to load -- HouseBuilder/HouseBuilderTool.rbError Loading File HouseBuilder_extension.rb
                      private method `split' called for nil:NilClass
                      I can understand that you have to give up now.
                      I try to find some other Mac-users on the forum. Maybe he/she/they can help me out.
                      Am I the only Mac encountering this this problem ????
                      By the way, I looked on your own website for version 1.2 but I only found version 1.1
                      Don't you make it available/downloadebale overthere.
                      Thanks and Greetings,
                      Ton
                      greetings,
                      Ton
                      • Didier BurD
                        Didier Bur
                        Hi Ton,
                        Don't worry, I don't give up πŸ˜„
                        You just have to RENAME your new folder "HouseBuilder".
                        Either your Zip app isn't configured as to maintain directory and pathes information (that's why it has renamed the new folder "HouseBuilder_metric_1.2Folder" by itself) or the Mac version of Winzip doesn't work the same way than on PC.
                        I'm sure you aren't the only one who uses HB on a Mac, and I've never heard of such problems so far.
                        Regards,
                        DB
                          sabba
                          Didier,
                          I am using a Mac and have the same issues loading the metric version of Housebuilder as the other mac users here.
                          The executable file for SketchUp is typically contained in ../Applications/Google SketchUp 8/SketchUp.app in the root of the system drive. ".app" files are some sort of folder with hidden contents. The path to the executable file within this folder is: ../contents/MacOS/SketchUp.
                          The plugins folder is typically ..Library/Application Support/Google SketchUp 8/SketchUp/plugins also in the root of the system drive.
                          The line with the offending code must be in one of the obfuscated files. Are there clear text versions of these files available for debugging or has this been solved somewhere else?
                          • Didier BurD
                            Didier Bur
                            Try with the attached file: delete the old one and replace with this one (no need to rename it).
                            Tell me if it works,
                            HouseBuilder_extension_Mac.rb
                            DB
                            • deaneauD
                              deaneau
                              your attached file give me the error
                              No such file or directory - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins\HouseBuilder\housebuilder_sections.txt
                                driven
                                hi Didier,
                                  #/HouseBuilder/housebuilder_sections.txt
                                  $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/"
                                this works on mac
                                • deaneauD
                                  deaneau
                                  @driven said:
                                  hi Didier,
                                  this works on mac
                                  [attachment=0:2ejy72bt]<!-- ia0 -->housebuilder.jpg<!-- ia0 -->[/attachment:2ejy72bt]
                                  hi driven, what the linenumber you insert your code snipped?
                                  i use bbedit on mac.
                                  tnx deaneau
                                  • Didier BurD
                                    Didier Bur
                                    @driven: $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/" is working ?? (still no Macs here)
                                    In this case, deaneau you just have to download the file below:
                                    DB
                                      driven
                                      @didier bur said:
                                      seems to be working, but I've never used, I just loaded to see if the back slashes where the problem or not, had that problem before...
                                      the only odd thing is where the generated report file (i.e. ** _wall.txt) ends up it's in the top level HD folder and I had to use Spotlight to find it, but it's all there
                                      • sketcpeppe75S
                                        sketcpeppe75
                                        how can i insert other sections... 16x20cm, 20x24cm 20x28cm... these in program are small for european structure. thank you very much
                                          Look in the subfolder, in the file 'housebuilder_sections.txt' there are the lists of section-types and sizes etc...
                                          Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...Capture.PNG
                                          • sketcpeppe75S
                                            sketcpeppe75
                                            Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...[attachment=0:36niodui]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:36niodui]
                                            thank you very much TIG πŸ˜„)
                                            • 2 / 3
