    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 19.3k Views 14 Watching
      sabba
      Didier,
      I am using a Mac and have the same issues loading the metric version of Housebuilder as the other mac users here.
      The executable file for SketchUp is typically contained in ../Applications/Google SketchUp 8/SketchUp.app in the root of the system drive. ".app" files are some sort of folder with hidden contents. The path to the executable file within this folder is: ../contents/MacOS/SketchUp.
      The plugins folder is typically ..Library/Application Support/Google SketchUp 8/SketchUp/plugins also in the root of the system drive.
      The line with the offending code must be in one of the obfuscated files. Are there clear text versions of these files available for debugging or has this been solved somewhere else?
      • Didier BurD
        Didier Bur
        Try with the attached file: delete the old one and replace with this one (no need to rename it).
        Tell me if it works,
        HouseBuilder_extension_Mac.rb
        DB
        • deaneauD
          deaneau
          your attached file give me the error
          Error Loading File HouseBuilder_extension.rb
          No such file or directory - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins\HouseBuilder\housebuilder_sections.txt
            driven
            hi Didier,
              #/HouseBuilder/housebuilder_sections.txt
              $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/"
            this works on mac
            • deaneauD
              deaneau
              @driven said:
              hi Didier,
              this works on mac
              [attachment=0:2ejy72bt]<!-- ia0 -->housebuilder.jpg<!-- ia0 -->[/attachment:2ejy72bt]
              hi driven, what the linenumber you insert your code snipped?
              i use bbedit on mac.
              tnx deaneau
              • Didier BurD
                Didier Bur
                @driven: $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/" is working ?? (still no Macs here)
                In this case, deaneau you just have to download the file below:
                DB
                  driven
                  @didier bur said:
                  seems to be working, but I've never used, I just loaded to see if the back slashes where the problem or not, had that problem before...
                  the only odd thing is where the generated report file (i.e. ** _wall.txt) ends up it's in the top level HD folder and I had to use Spotlight to find it, but it's all there
                  • sketcpeppe75S
                    sketcpeppe75
                    how can i insert other sections... 16x20cm, 20x24cm 20x28cm... these in program are small for european structure. thank you very much
                      Look in the subfolder, in the file 'housebuilder_sections.txt' there are the lists of section-types and sizes etc...
                      Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...Capture.PNG
                      • sketcpeppe75S
                        sketcpeppe75
                        Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...[attachment=0:36niodui]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:36niodui]
                        thank you very much TIG πŸ˜„)
                        • K
                          KarlPals
                          @sketcpeppe75 said:
                          Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...[attachment=0:e0cz8i6k]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:e0cz8i6k]
                          I'm using the TIG version of metric 1.2 plugin. I edited the housebuilder_sections.txt file as described but the new values I entered seem to be ignored by the script. They don't show up on the selection menu.
                          Thanks,
                          Karl
                          • 3 / 3
