    New: HouseBuilder metric 1.2 (customizable)
    44 Posts 14 Posters 19.3k Views 14 Watching
    • ton baetenT
      ton baeten
      Didier,
      I presume you are anything but 'completely mad'.
      Indeed, Macs never use the extension .exe that is pure MS windows (why didn't I think of that).
      I just tried Sketchup.find_support_file("Sketchup") in the ruby console and the result still is: nil
      So, still no solution. The last hour I just tried a couple of things, but found no solution.
      Could you please describe me what files (rubys and/or non-ruby) I need to/should have and where they should be located.
      For now, I have, located in my plugins folder a folder HouseBuilder_metric_1.2.
      This folder contains
      • HouseBuilder_extensions.rb
      • readme.txt
      • HousebuilderTool.rb
      • Housebuilder.rb
      • another folder called 'Housebuilder' containing:
      • a number of png's and gif's
      • HouseBuilder-extension.rb(gif)
      • housebuilder_sections.txt
        As mentioned before, everythings is within one folder. None of the ..rb files are in the plugins folder itself. Maybe that is why nothing can be found to start 'Housebuilder'.
      Open for further info and tests,
      Greetings,
      Ton
      greetings,
      Ton
      • Didier BurD
        Didier Bur
        Hi Ton,
        I'm sorry to say that your files/folders organization is completely wrong...
        A ruby script doesn't find its way by itself, so there are some rules to follow in order to make it work πŸ˜‰
        When I release a package I always save the folders information when building the Zip so the user have just to unzip it in his Plugins folder and that's it. No folder(s) creation needed, no file(s) renaming, no nothing.
        If you delete all "housebuilder" files you have installed and unzip the package again in your Plugins folder, it MUST work.
        After having unziped, you should have:
        • "HouseBuilder_extension.rb" in your Plugins folder, as well as "readme.txt"
        • a folder named "HouseBuilder" under the Plugins folder
        • in this HouseBuilder folder: all Gif's and PNG's, 2 rubbies and "housebuilder_sections.txt"
        If it doesn't work, I give up πŸ€“
        Hope this helps this time πŸ˜‰
        DB
        • ton baetenT
          ton baeten
          Didier,
          Thanks for your info.
          My thinking was that my problems had to do with my file-organisation. So I followed your advice, erased all HouseBuilder files, put the Housebuilder-metric_1.2.zip in my plugins folder and unzipped.... The result (on my Mac) is a new folder (within plugins), called 'HouseBuilder_metric_1.2Folder. No HouseBuilder... files outside that folder, just that new folder. Following your info I moved the HouseBuilder_extensions.rb out of that folder into the open area of my 'plugins'.
          The result I get at restarting SU is :
          no such file to load -- HouseBuilder/HouseBuilderTool.rbError Loading File HouseBuilder_extension.rb
          private method `split' called for nil:NilClass
          I can understand that you have to give up now.
          I try to find some other Mac-users on the forum. Maybe he/she/they can help me out.
          Am I the only Mac encountering this this problem ????
          By the way, I looked on your own website for version 1.2 but I only found version 1.1
          Don't you make it available/downloadebale overthere.
          Thanks and Greetings,
          Ton
          greetings,
          Ton
          • Didier BurD
            Didier Bur
            Hi Ton,
            Don't worry, I don't give up πŸ˜„
            You just have to RENAME your new folder "HouseBuilder".
            Either your Zip app isn't configured as to maintain directory and pathes information (that's why it has renamed the new folder "HouseBuilder_metric_1.2Folder" by itself) or the Mac version of Winzip doesn't work the same way than on PC.
            I'm sure you aren't the only one who uses HB on a Mac, and I've never heard of such problems so far.
            Regards,
            DB
              sabba
              Didier,
              I am using a Mac and have the same issues loading the metric version of Housebuilder as the other mac users here.
              The executable file for SketchUp is typically contained in ../Applications/Google SketchUp 8/SketchUp.app in the root of the system drive. ".app" files are some sort of folder with hidden contents. The path to the executable file within this folder is: ../contents/MacOS/SketchUp.
              The plugins folder is typically ..Library/Application Support/Google SketchUp 8/SketchUp/plugins also in the root of the system drive.
              The line with the offending code must be in one of the obfuscated files. Are there clear text versions of these files available for debugging or has this been solved somewhere else?
              • Didier BurD
                Didier Bur
                Try with the attached file: delete the old one and replace with this one (no need to rename it).
                Tell me if it works,
                HouseBuilder_extension_Mac.rb
                DB
                • deaneauD
                  deaneau
                  your attached file give me the error
                  No such file or directory - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins\HouseBuilder\housebuilder_sections.txt
                    driven
                    hi Didier,
                      #/HouseBuilder/housebuilder_sections.txt
                      $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/"
                    this works on mac
                    • deaneauD
                      deaneau
                      @driven said:
                      hi Didier,
                      this works on mac
                      [attachment=0:2ejy72bt]<!-- ia0 -->housebuilder.jpg<!-- ia0 -->[/attachment:2ejy72bt]
                      hi driven, what the linenumber you insert your code snipped?
                      i use bbedit on mac.
                      tnx deaneau
                      • Didier BurD
                        Didier Bur
                        @driven: $housebuilder_path = Sketchup.find_support_file("Plugins") + "/HouseBuilder/" is working ?? (still no Macs here)
                        In this case, deaneau you just have to download the file below:
                        DB
                          driven
                          @didier bur said:
                          seems to be working, but I've never used, I just loaded to see if the back slashes where the problem or not, had that problem before...
                          the only odd thing is where the generated report file (i.e. ** _wall.txt) ends up it's in the top level HD folder and I had to use Spotlight to find it, but it's all there
                          • sketcpeppe75S
                            sketcpeppe75
                            how can i insert other sections... 16x20cm, 20x24cm 20x28cm... these in program are small for european structure. thank you very much
                              Look in the subfolder, in the file 'housebuilder_sections.txt' there are the lists of section-types and sizes etc...
                              Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...Capture.PNG
                              • sketcpeppe75S
                                sketcpeppe75
                                Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...[attachment=0:36niodui]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:36niodui]
                                thank you very much TIG πŸ˜„)
                                • K
                                  KarlPals
                                  @sketcpeppe75 said:
                                  Make a copy of that file, edit the file to show the sections you want in the single-line as shown for each of the four types; use the same 'syntax' as the original sizes in 'mm' [aaxbb|aaaxbbb|... etc], test it and if it works with your new custom sizes you've cooking-with-gas; if NOT then you've always got the original version to revert to...[attachment=0:e0cz8i6k]<!-- ia0 -->Capture.PNG<!-- ia0 -->[/attachment:e0cz8i6k]
                                  I'm using the TIG version of metric 1.2 plugin. I edited the housebuilder_sections.txt file as described but the new values I entered seem to be ignored by the script. They don't show up on the selection menu.
                                  Thanks,
                                  Karl
                                  • 2 / 3
