    [Tutorial > Modeling] How a Pro Builds a House in SU pt 1
    88 Posts 30 Posters 79.6k Views 30 Watching
    • KrisidiousK Offline
      Krisidious
      you may have problems like this, after applying the texture to the rectangle, then right click on the rectangle and select "texture>Position> then flip, rotate, move until it fits correctly.
      this help?
      By: Kristoff Rand
        titmas
        @krisidious said:
        step 11
        repeat this process for your foundation, your first level and your second level and third...
        by 'repeat' are you referring to steps 1-10 for each page of the plans by importing an image of each page than scale, trace, copy, layer?
          Krisidious
          yes that's what I meant...
          By: Kristoff Rand
          • N Offline
            not registered yet
            Hi Kristoff,
            I only just found this thread and I'm finding it very useful indeed as I'm modelling my house in order to plan various improvements and alterations to services etc. I've got about six versions so far in various stages of completion which I realise is going to cause me major problem. Your tip about layers will be invaluable. Going right back to the beginning, would I be right in assuming that you could treat an imported 2D .DWG file in exactly the same way as you've used a .jpg image ?
            Thanks again for all your great input.
            Bigyin
              Krisidious
              yes you could use the dwg file, although you would explode it and make the actual lines of the dwg into SU lines.
              By: Kristoff Rand
              • N Offline
                not registered yet
                Thanks for that Kristoff. I think I'm gonna restart my model as I have a .DWG that friend produced and following your approach will help me keep the versions much better organised.
                Cheers,
                Bigyin
                  Krisidious
                  Bigyin...
                  start a thread in the gallery and post your work as you go, people will stop by and drop encouraging notes and advice that you can't find by asking, the kind that pops into their head while they see your progress.
                  good luck.
                  By: Kristoff Rand
                  • N Offline
                    not registered yet
                    I am having problems with step 4.
                    What do you mean when you say open the group?
                    If you mean edit, I am editing the group and measuring with the tape measure, but it is not asking me to resize the group?
                    BTW- I am using the free version of SketchUp.
                    Thanks from an aspiring SU user!
                    (Online)
                      Krisidious
                      online...
                      after measuring a lined that you have drawn, you type in the box on the lower right hand of your screen, the measurment that you wish the line to become.
                      does that help?
                      By: Kristoff Rand
                      • N Offline
                        not registered yet
                        I am doing that and it is only making a construction point where the measurement would be?
                        (Online)
                          Online,
                          Don't bother with the construction point!
                          Do as Kris told:
                          Do the measurement, click second time and before doing anything else, just start typing the desired measure (don't put your mouse into the VCB and click - just type) When finished, hit Enter and answer the question that pops up.
                          • N Offline
                            not registered yet
                            Wow, that was easy!
                            I feel dumb now. 😳
                            One more question, how come I am getting this black junk on my screen with zooming in?
                            http://img63.imageshack.us/img63/807/screenhunter01oct101131ou6.gif
                            (Online)
                              Krisidious
                              if you are at scale already... then that's a videocard issue... if it's not to scale it may be clipping, to fix that a known GSU issue, you'll have to turn off the perspective view and use parallel view.
                              By: Kristoff Rand
                              • N Offline
                                not registered yet
                                Well I am at scale already.
                                On the existing plan that I made a material out of, I can zoom all the way in and it is at scale already?
                                (Online)
                                  Krisidious
                                  if you are in the top view... square
                                  and you have parallel view enabled...
                                  and you still have this issue, I would say you need a better videocard or at very least to update your video card drivers...
                                  By: Kristoff Rand
                                  • N Offline
                                    not registered yet
                                    Thank you so much!
                                    (Online)
                                      jaggie4life
                                      Hi there,
                                      i amnt very good at this but im just wondering where to get a picture at the start of the guide if anyone can post one up that would help very much
                                      thanks
                                        jvh
                                        i've got problems with step 6. after right clicking and choosing "use as a material" i don't know how to apply it to the square.
                                          jvh
                                          Thanks James,
                                          That's what I tried. Then I get the materials window, but my plan is not in it, so I can't select and drop it in my square.
                                            J4Media
                                            First off, thanks for this tutorial, its very helpful.
                                            I have followed along through all steps and am at the part where I trace the plan. The problem I'm having trouble with is when i trace the entire perimeter of the plan and connect it to where I started, the lines get thin from their original thick. This then results in a hollow center when i use the offset tool to set the wall thickness of 6".
                                            I am baffled by what I am doing wrong, can someone please help me out?
                                            Thanks in advance for your help.
                                            John
                                            • 4 / 5
