    [Tutorial > Modeling] How a Pro Builds a House in SU pt 1
    88 Posts 30 Posters 82.8k Views 30 Watching
      titmas
      @krisidious said:
      step 11
      repeat this process for your foundation, your first level and your second level and third...
      by 'repeat' are you referring to steps 1-10 for each page of the plans by importing an image of each page than scale, trace, copy, layer?
      • KrisidiousK Offline
        Krisidious
        yes that's what I meant...
        By: Kristoff Rand
        • N Offline
          not registered yet
          Hi Kristoff,
          I only just found this thread and I'm finding it very useful indeed as I'm modelling my house in order to plan various improvements and alterations to services etc. I've got about six versions so far in various stages of completion which I realise is going to cause me major problem. Your tip about layers will be invaluable. Going right back to the beginning, would I be right in assuming that you could treat an imported 2D .DWG file in exactly the same way as you've used a .jpg image ?
          Thanks again for all your great input.
          Bigyin
            Krisidious
            yes you could use the dwg file, although you would explode it and make the actual lines of the dwg into SU lines.
            By: Kristoff Rand
            • N Offline
              not registered yet
              Thanks for that Kristoff. I think I'm gonna restart my model as I have a .DWG that friend produced and following your approach will help me keep the versions much better organised.
              Cheers,
              Bigyin
                Krisidious
                Bigyin...
                start a thread in the gallery and post your work as you go, people will stop by and drop encouraging notes and advice that you can't find by asking, the kind that pops into their head while they see your progress.
                good luck.
                By: Kristoff Rand
                • N Offline
                  not registered yet
                  I am having problems with step 4.
                  What do you mean when you say open the group?
                  If you mean edit, I am editing the group and measuring with the tape measure, but it is not asking me to resize the group?
                  BTW- I am using the free version of SketchUp.
                  Thanks from an aspiring SU user!
                  (Online)
                    Krisidious
                    online...
                    after measuring a lined that you have drawn, you type in the box on the lower right hand of your screen, the measurment that you wish the line to become.
                    does that help?
                    By: Kristoff Rand
                    • N Offline
                      not registered yet
                      I am doing that and it is only making a construction point where the measurement would be?
                      (Online)
                        Online,
                        Don't bother with the construction point!
                        Do as Kris told:
                        Do the measurement, click second time and before doing anything else, just start typing the desired measure (don't put your mouse into the VCB and click - just type) When finished, hit Enter and answer the question that pops up.
                        • N Offline
                          not registered yet
                          Wow, that was easy!
                          I feel dumb now. ๐Ÿ˜ณ
                          One more question, how come I am getting this black junk on my screen with zooming in?
                          http://img63.imageshack.us/img63/807/screenhunter01oct101131ou6.gif
                          (Online)
                            Krisidious
                            if you are at scale already... then that's a videocard issue... if it's not to scale it may be clipping, to fix that a known GSU issue, you'll have to turn off the perspective view and use parallel view.
                            By: Kristoff Rand
                            • N Offline
                              not registered yet
                              Well I am at scale already.
                              On the existing plan that I made a material out of, I can zoom all the way in and it is at scale already?
                              (Online)
                                Krisidious
                                if you are in the top view... square
                                and you have parallel view enabled...
                                and you still have this issue, I would say you need a better videocard or at very least to update your video card drivers...
                                By: Kristoff Rand
                                • N Offline
                                  not registered yet
                                  Thank you so much!
                                  (Online)
                                    jaggie4life
                                    Hi there,
                                    i amnt very good at this but im just wondering where to get a picture at the start of the guide if anyone can post one up that would help very much
                                    thanks
                                      jvh
                                      i've got problems with step 6. after right clicking and choosing "use as a material" i don't know how to apply it to the square.
                                        jvh
                                        Thanks James,
                                        That's what I tried. Then I get the materials window, but my plan is not in it, so I can't select and drop it in my square.
                                          J4Media
                                          First off, thanks for this tutorial, its very helpful.
                                          I have followed along through all steps and am at the part where I trace the plan. The problem I'm having trouble with is when i trace the entire perimeter of the plan and connect it to where I started, the lines get thin from their original thick. This then results in a hollow center when i use the offset tool to set the wall thickness of 6".
                                          I am baffled by what I am doing wrong, can someone please help me out?
                                          Thanks in advance for your help.
                                          John
                                            John,
                                            Thick lines are called "profiles" and are merely used to either indicate that they do not close a coplanar face or to give some "perspective look" to your model (meaning that the outlines and front edges of a 3D model are usually displayed with them).
                                            I personally don't like profiles and even turn them off (Style window > in mode > edit > edge settings).
                                            Now when you just simply close a face (tracing over the image) they should not turn into thin lines (that are called edges when surrounding a face) since they are still the "outlines" of your face.
                                            Is there a face created at all? If not, you have done something wrong, i.e. I assume that your lines are not on the same (red/green, horizontal) plane. This is essential for SU to be able to create a face.
                                            Try (at the same style setting as above) to set the line display to "color by axis" to see if your lines are coplanar (all lines on the red or green axis should be coloured red/green now). Of course if you modeled completely out of axis, this won't help.
                                            Also try to put a text label onto every endpoint you drew. By default it will give you the coordinates. If you hit enter twice, that will be the text label. Wherever you se a different value of the last number (the z - blue - axis) it means that you are not coplanar.
                                            Or just post your model here for us to see.
                                            • 3 / 5
